Author Topic: Not bio related so sorry, but quite a useful wheeze.  (Read 2968 times)
« on: August 29, 2013, 11:25:47 PM »
Hope Pete the Je, Jeee, Je ... American car doesn't read this!
Just want to pass this idea on as others might find it useful.
Having a spot of bother with the Disco.  Changed the water pump a while back and was obviously not careful enough putting the hoses back because despite being in it's allotted clip, the heater hose was touching the water pump pulley and the hose lost.  I didn't notice it starting to get hot, it behaved perfectly normally until I noticed the temperature gauge was off the scale.  Not a drop of water left in the engine and it was VERY hot.  Let it cool down a bit added water and limped home.
Investigations the following day revealed yet another blown head gasket and warped head.  Had the head skimmed and was prepairing to put it together when I noticed what looked suspiciously like a crack in the block.  Getting rather worried now ... new engine time.
Then I remembered seeing dye being used as a penetration test to detect cracks.  Jump on the internet and most of the kits are silly money (although one place did later phone me back with a price of 30 quid ... still expensive for three aerosol cans), so after a little lateral thinking I came up with IPA, cyan ink jet printer ink and talcum powder.
I carefully fractured a piece of aluminium so I knew is was cracked, cleaned it with IPA, applied the ink and gave it a little while to soak in.  I then wiped off the excess ink, cleaned with an IPA dampened rag and applied the talc.
After about 30 seconds a red line where the crack was appeared in the dusting of talc, along with a couple of others which I couldn't see.  Well chuffed at this I repeated the process on the Disco block and no red line.  I'm not saying it's fool proof, but I recon it's a pretty good indication that the head's OK ... breaths a sigh of relief!
Re: Not bio related so sorry, but quite a useful wheeze.
« Reply #1 on: August 30, 2013, 12:07:02 AM »
Neat trick.
How many times have you had the head off a Discovery now?
« Reply #2 on: August 30, 2013, 12:18:54 AM »
If you're comfortable taking the head off maybe it's time to try another manufacturer's vehicle?  Just sayin'...
« Reply #3 on: August 30, 2013, 12:27:40 AM »
Neat trick.
All the bolts come undone really easily.
« Reply #4 on: August 30, 2013, 12:32:52 AM »
I hear what you say, but it's like an old, favourite jumper.  It's got a few holes, it smells a bit and you have to keep repairing it, but it suits you, is comfy and you're very attached to it.
« Reply #5 on: August 30, 2013, 06:23:50 AM »
I think you are on to a winner if you are comfortable enough to whip the head off like that.
Offline Bill
« Reply #6 on: August 30, 2013, 10:29:29 AM »
Neat trick.
I bet your using wingnuts by now
Both sold
« Reply #7 on: August 30, 2013, 11:41:18 AM »
Neat trick.
What a great idea!
« Last Edit: August 30, 2013, 12:37:27 PM by Julian »
Online Head Womble
« Reply #8 on: August 30, 2013, 11:05:25 PM »
Doing all this repare work on the disco keeps you busy Julian,
just think, if you had relyable transport you could have that extension finished by now.
« Reply #9 on: August 31, 2013, 01:16:36 AM »
It's nearly finished, carpets went down on Wednesday ... just got the back porch, a bit of floor tiling and the patio to do.  Three weeks work for most people ... about a year and a half for me.
Got the Disco back together again only to find the water pump bearings are rattling ... this is the pump that's guaranteed for two years but has lasted three weeks!
Online Head Womble
« Reply #10 on: August 31, 2013, 10:23:35 PM »
Britpart by any chance ?
« Reply #11 on: August 31, 2013, 11:11:28 PM »
Yup, Britpart, at a whopping 14 quid.  I wanted a genuine one but he didn't have any in stock at the time.  This morning he didn't have either in stock, so I bought an expensive one from a local motor factor which is identical to the 14 quid one ... hobsons choice I'm afraid.  Still it's back on the road now, just wondering for how long.
