Author Topic: 12 volt inline fuel valve  (Read 3895 times)
« on: August 16, 2013, 07:16:02 PM »
hi all
anyone know where i can get an inline 12v soliniod valve for fuel, been looking about but cant seem to locate one?
just need an inline one not a 3 way job. with 8mm ID if poss...
thx...
Re: 12 volt inline fuel valve
« Reply #1 on: August 16, 2013, 07:49:07 PM »
You mean like a shutoff valve?
IIRC, the Ford Escort Diesel had one fitted, the mark three versions. I thought there was a citroen with one fitted as well, but I don't recall which one.
My mistake, I believe what you are looking for is called an overrun valve, more likely to be fitted to a petrol, with early injection system on it.
Guess what? I can't find one either............
I give up, its not called an over run valve either, that's something entirely different.
I'm sure there was an electronic control valve in the fuel line on older diesel Escorts.
For all the use this my post is, I may as well delete it......:P
« Last Edit: August 16, 2013, 08:02:07 PM by greasemonkey »
« Reply #3 on: August 16, 2013, 09:24:39 PM »
Bleedin' 'ell! I searched for them as well, and all I came up with was cuttoff valves that fit in a diesel pump. I swear different peoples computers give different results with the same search term.
« Reply #4 on: August 17, 2013, 09:44:00 AM »
this is exactly the reason i posted up here, like you GM i searched varying names and got zip, nice one keef!
and GM nice one for trying dude....
« Reply #5 on: August 17, 2013, 11:51:14 AM »
What about the red fuel cutoff valve you get in PSA cars,
you should have one on the 406 (top right as you look under the bonnet).
Or is this an electronic shutoff, not sure actually.
« Reply #6 on: August 17, 2013, 12:02:24 PM »
Murphy Valves do them, have a look here . . . . http://www.fwmurphy.co.uk/products/valves/valves.htm
The very top on that page.
Offline BANDIT2
« Reply #7 on: August 18, 2013, 04:15:46 PM »
You loosing your touch Paul?
http://www.ebay.co.uk/itm/Petrol-diesel-solenoid-shut-cut-off-valve-12V-autogas-conversions-liquid-air-/161071512011?pt=UK_Cars_Parts_Vehicles_Other_Vehicle_Parts_Accessories_ET&hash=item25809c39cb
http://www.ebay.co.uk/itm/Electric-12v-Fuel-CUT-OFF-Solenoid-Valve-6-0mm-dia-/390394136922?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5ae54dc95a
http://www.ebay.co.uk/itm/New-Brass-12V-DC-1-4-Electric-Solenoid-Valve-Water-Air-Fuels-Gas-Normal-Closed-/130928375562?pt=LH_DefaultDomain_3&hash=item1e7bf0770a
Don't like them hosetails on the first one-moulded placcy  :-\
second one-pricey but more suitable-swop out the hosetails for bsp compression fittings-suit my nylon airline fuel pipes better.
Chinky one is cheap! will take compression fittings or whatever you want by the look of it...but....2.5mm bore size???-cold veg would stuggle to go through that. Bio wouldn't go through quick enough on anything but idle either.
Just thinking out aloud-anti theft device for the Landy 110?
Offline BANDIT2
« Reply #8 on: August 18, 2013, 04:18:20 PM »
Any idea of the price Jules?
« Reply #9 on: August 18, 2013, 06:42:10 PM »
There's loads more on there, those were just the first three that came up.
If you're thinking anti-theft, buy a three way and route the spare outlet to pump fuel over the thief's head.
« Last Edit: August 18, 2013, 06:46:33 PM by Keef »
