Author Topic: Multistage pump failure?  (Read 2749 times)
« on: August 15, 2013, 10:13:04 PM »
Ive just had my pump fail mid-batch.
It still pumps, but more like a pour, rather than a gush.
Its too late now to investigate (i swapped in an identical spare) but what should i be looking for?
notes -
Pump has been getting slightly more noisy for some time.
Motor is certainly still spinning fine
Looking in the input port, i could see some blackened stuff, like bits of straw, or sawdust, around the first visible plate (this leads me to suspect more further inside)
The pump is a Grunfoss multistage.  I forget the model, but ill look it up.
Is there anything to watch out for before i start taking it apart?
Thank you,
julian
Re: Multistage pump failure?
« Reply #1 on: August 15, 2013, 10:54:22 PM »
They don't like pumping fibrous debris - it sticks in the impeller eyes and on the diffuser edges.  I bet it's clogged with gunk - nothing a quick clean shouldn't sort.  I use a length of copper wire from an electrical cable to poke clean the impellers and diffusers.
« Reply #2 on: August 15, 2013, 11:04:16 PM »
Do i just take the front off it, and all will be on display, or will i need to look at diagrams etc?
You have to clean yours often?
« Reply #3 on: August 15, 2013, 11:12:11 PM »
I'm not sure on the Grundfos ones as I've not got one, but the Calpeda ones the case comes off, then a locking nut on the motor shaft, and then all the impellers and diffusers easily slide off the shaft (which is splined).  Have to pay attention to the order for re-assembly purposes.
No I don't have to clean mine often at all, but I do course filter and settle my WVO before it goes in the processor, so usually very little in the way of contaminants.
« Reply #4 on: August 16, 2013, 07:52:24 AM »
pretty straightforward just remove the 4 screws. easy access to impeller.
tried to buy a new impeller for a 80 grufos pump that i found but was told that they don't sell parts for them as they never go wrong
« Reply #5 on: August 16, 2013, 08:40:20 AM »
I have spare impellers for my multistagers (from a three phase pump of the same type) but they never fail in any way.  The only problem I've seen is worn bearings on the pump motors and expanded sealing o-ring between the pump housing and body (now replaced with Viton) - very little else to go wrong really!
« Reply #6 on: August 16, 2013, 10:25:37 AM »
Yes, I've had this problem too. Thankfully no more since I fitted a 100 micron filter to the processor inlet.
As above. Take it apart and be methodical - lay everything out in the order in which it came off. Take photos if you need to.
« Reply #7 on: August 16, 2013, 10:30:58 AM »
Definitely take photos.  For the wiki :)
