Author Topic: Borosilicate sight glasses  (Read 3105 times)
« on: August 04, 2013, 02:51:51 PM »
I've found a source of borosilicate tubing in 22mm OD ... surprisingly off ebay.  The chap advises wall thickness is 1.5mm, but he may be able to get thicker.  Price is £10 each plus p+p for a 1.5m length (although the ebay add states 750mm for posting purposes) ... I guess he may be able to cut to size.
RM kindly gave me some nylon tube but I think it may be too smaller diameter, so I'm tempted to give this 22mm a try as my perspex tube is on it's last legs.  Is anyone else interested as the guy hinted that he may be able to offer a discount on quantity ... don't know the quantity or discount yet.
Two plans for installing spring to mind ... compression fitting with two 'O' rings in place of the olive (as I've used to good effect on my perspex tube for several years), or a flange top and bottom, each with gaskets to the tube ends, and studding clamping the flanges on the tube.  Top flange could include a tundish (for returning samples to the processor etc) and the bottom with a threaded hole to take a fitting.
Re: Borosilicate sight glasses
« Reply #1 on: August 04, 2013, 03:45:32 PM »
put me down for one please. still have to build the new processor but will need a site glass at some point. ,especially as i intend to use the acid neutralising method.
« Reply #2 on: August 04, 2013, 05:20:42 PM »
I may be a bit off topic here but I use braided pvc for my sight tube. I only ever have veg oil in there...not bio...not meth...not WVO...but pure veg. With SVO it does not deteriorate.
I know this may only relate to volume in the reactor which is the reason for posting. I only put pure veg in the tube to tell me the level of wvo in the tank.
If you use the sight tube to give an indication of what's going on inside the reactor then you could be on a bit of a loser due to flow through the sight tube. IMHO..forget it!
« Reply #3 on: August 04, 2013, 05:56:36 PM »
Hmm, more than one way to skin a cat, Nige!
All depends on your valving arrangement, yours sounds rather restrictive.  I can empty and refresh my sight tube whilst the processor is running.  I use it to return samples to the processor frequently and, on occasions, to add water, acid and catalyst.  I consider it one of the most useful components on my plant!
PVC sweats bio and goes translucent ... tried that.  Acrylic crazes over time, goes brittle and slightly translucent.  I'm going to give glass a try, may well be a better alternative ... unless we try new things we'll never progress!
I read it ... but I'm afraid "The future isn't always to be found in the past"!
« Reply #4 on: August 04, 2013, 09:22:55 PM »
whats its properties like? is it glass like or can it bend? does it shatter?
« Reply #5 on: August 04, 2013, 09:37:16 PM »
Its the stuff laboratory glass is made of
« Reply #6 on: August 04, 2013, 10:19:01 PM »
Using Borosilicate glass may well be an alternative material for use as a sight tube in a multiport scenario in your case Julian and I'm sure that in your plant it will be seen as progress but for me a sight tube is just that...a tube for seeing the volume of oil in the processor.
I cant even to begin to imagine how you manage to pour liquids down such a narrow tube without exposing yourself to all sorts of spills and potential dangers. My venturi sucks everything up from a safe low position.
On my plant, some things don't need improving.
« Reply #7 on: August 04, 2013, 10:22:36 PM »
As Okawoodtv says.  It's basically Pyrex glass.  Happy at high temperatures and with temperature changes.  Generally pretty tough stuff.  The trade name of this stuff is Duran.
