Author Topic: heat exchanger sizing  (Read 2565 times)
« on: August 01, 2013, 06:49:10 PM »
I want to connect a combi boiler to to the log burner central heating system
the combi will be used only for hot water in the summer and occasional C H
The combi boiler is rated at 9.2 to 24 k watts
there are three large and three medium radiators on the system
how large a heat exchanger will I require
I have three heat exchangers from worcester 25cdi combis
will this be sufficient
Re: heat exchanger sizing
« Reply #1 on: August 01, 2013, 07:39:07 PM »
Despite just recently sizing a pair of 850kW heat exchangers, I actually have no idea how to tackle this.
Is anyone able to throw some maths at it rather than rules of thumb?
(I do like maths. :o )
« Reply #2 on: August 01, 2013, 08:44:22 PM »
I've been trying to work this sort of thing out as well. So far, I have no idea.............
« Reply #3 on: August 01, 2013, 09:14:59 PM »
go on ebay, get a massive one, job done
there's nothing to loose by using one which is too big :-)
« Reply #4 on: August 01, 2013, 10:00:18 PM »
Getting a massive one from the bay is a possibility but I am a tight old git
the three I have now [ measuring 310x75x50 mm 18 plate HE ] cost me the
princely sum of £3.00 from my friendly recycler and if I can series parallel
a few together it will save me cash I do not wont to spend
May try three in parallel and if the boiler cyclicals to much I will
add three more
maths is fine but the suck it and see method works as well
