Author Topic: Adding the chems. Am I right about this?  (Read 2392 times)
« on: July 12, 2013, 10:10:18 PM »
I'm going for a two stage no tit.
So I make up the methanol and ASM, as per the Wiki.
The way I follow it, I add around three quarters of what I have made up. Then process and test for conversion. Then calculate how much more of the remaining chems to add, from the unconverted percentage.
Am I barking up the right tree?
Re: Adding the chems. Am I right about this?
« Reply #1 on: July 12, 2013, 10:41:26 PM »
Not quite Andrew.
Whatever your batch size use 80% of the methanol you would normally use for stage one. ie for 100 lt batch methanol, until you have the confidence and experience to trim it down, would be 20lt.  So 80% of that would be 16lts for stage one. The balance of 4 lts you would use for stage 2
Stage 1
ASM = 4gms/lt X 5 X Batch size
100lt batch would be  4 x 5 x 100 = 2000ml
Add that 2000ml to 16lts of methanol.
Stage 2 is determined by the dropout.
« Last Edit: July 12, 2013, 10:50:35 PM by nigelb »
« Reply #2 on: July 12, 2013, 10:46:06 PM »
You are barking up the right tree.  But instead of making it all up up-front for a whole batch and then only putting 75% in, work out how much ASM/Meth you would use total but knock off 25%.
Then when you do the second stage you can mix the next 25% right for the second stage (otherwise if you pre-mixed - that 25% left may be too weak/strong).
On a side note, I'm just back from the shed, that palm you gave me has given one of the clearest 3/27 passes I've seen. :)
« Last Edit: July 12, 2013, 10:58:42 PM by Tony »
« Reply #3 on: July 12, 2013, 10:56:37 PM »
Ok guys, thank you very much, I've got it.
Good about the palm, coz thats what I'm going to be using.
I can't believe I've been pratting about all day with processor. I wanted to de water tonight. It'll have to be the morning now.
« Reply #4 on: July 13, 2013, 10:40:36 AM »
Quote
Palm is good stuff for biodiesel - just not in the winter :)
« Reply #5 on: July 13, 2013, 11:38:19 AM »
Its 30C in the shade. The processor is not in the shade..........
Might wait a while.
« Reply #6 on: July 13, 2013, 01:17:36 PM »
Free reaction heat :) Maybe you need a gazebo?
« Reply #7 on: July 13, 2013, 02:21:10 PM »
Gazebo could be a good idea, I think I have one somewhere.
I think I've got sun stroke already, after yesterday. I'd rather work till the early hours of the morning.  It was still 19C at midnight last night. It'll be warmer tonight.
