Author Topic: What would you do?  (Read 2737 times)
What would you do?
« on: July 04, 2013, 05:23:24 PM »
I have a problem with my processor. The inverter drive that drives my three phase pump has given up the ghost.
I can either buy a new drive (£140) or I can buy a new single phase pump from JGS (£91)
The new pump is obviously cheaper, however, it would mean modification of my pipework to make it fit. The advantage of having a drive is that it has all sorts of protection devices to ensure the pump doesn't overload. And I can run it at variable speed. And I don't need to change my pipework.
Should my three phase pump ever die, they are cheap to come by.
What would you do?
Re: What would you do?
« Reply #1 on: July 04, 2013, 06:08:13 PM »
Probably replace the inverter.  Less than 50 quid extra by the time you add in fittings, pipe, electrics and your time.
Seems a small price for the advantages you describe.
Is it economical to repair the inverter?
Offline jondanbob
« Reply #2 on: July 04, 2013, 06:11:32 PM »
invertek inverters are really good, cheap inverters your just asking  for trouble really, especially those nasty ones on ebay yuck!
« Reply #3 on: July 04, 2013, 06:15:28 PM »
Yes, I agree. It was invertek that I intended to get. I've just installed a 36kW version at work and I'm very impressed with the build quality and functionality.
I have repaired the inverter drive once already, but this time It's completely goosed. It was built in the 80's and I did find it in a skip, so I think it's done it's job!
And Welcome btw. :)
« Last Edit: July 04, 2013, 06:19:20 PM by therecklessengineer »
« Reply #4 on: July 04, 2013, 06:25:02 PM »
Hehe yes welcome - I vote replace the inverter!
Offline jondanbob
« Reply #5 on: July 04, 2013, 06:35:27 PM »
thanks, thought there is more action here than on paddys forum
what size inverter are you after i have a few siemens inverters, only downside a bugger to set up
« Last Edit: July 04, 2013, 06:38:34 PM by jondanbob »
« Reply #6 on: July 04, 2013, 10:11:52 PM »
This is all a bit beyond me, but the other day, somewhere on the web, there were ex military 3ph inverters, selling for around £25 IIRC. They were on an army surplus retailer site. I'm pretty sure they said they were early 1980s.
I have absolutely no idea what the site was though.
« Reply #7 on: July 10, 2013, 02:25:39 PM »
Replace the inverter and buy a spare one.
You can guarantee that something like that will go belly up mid way through a batch leaving your whole plant full of partially converted liquid.
I have a spare pump for mine. Not quite the same as the processor pump but it will fit the pipework and means I can rescue it halfway through if needed and get it pumped out.
