Author Topic: Spun wound filters and FPHE  (Read 4020 times)
« on: July 01, 2013, 05:30:19 PM »
I was thinking of adding a FPHE to the Delica to warm the fuel in winter, before the 10" filter.  But would coolant temp raise the biodiesel to a level where the spun wound element would disintegrate?  I have to confess I don't know what temp they are good up to.
« Last Edit: July 01, 2013, 05:32:23 PM by Tony »
Offline Rossey
Re: Spun wound filters and FPHE
« Reply #1 on: July 01, 2013, 06:10:18 PM »
Mine are the clear bowl type and says 45c max
« Last Edit: July 01, 2013, 08:31:54 PM by Rossey »
« Reply #2 on: July 01, 2013, 06:17:06 PM »
Heated filter on the Disco can get up to 60+°C on occassions.  Hottest temperatures seem to occur after a long run when the car's stopped for a little while and then started again.
I know you went to a lot of trouble putting the filter in, but have you considered fitting a LR type housing ... filters are around £2.50 each to replace.
« Reply #3 on: July 01, 2013, 06:22:26 PM »
The landrover filters that are £2 are the brit part ones, which, so far as ive been able to tell, are possibly not great at elevated temps?
The 'heated' ones are made by bosch and come in at £5.50 ex from paddocks.
« Reply #4 on: July 01, 2013, 06:42:28 PM »
I've not had any trouble with the Paddocks ones.
« Reply #5 on: July 01, 2013, 08:58:30 PM »
my van FPHE gets to 85c i have a temp probe on it and the sausage filter takes it
« Reply #6 on: July 01, 2013, 09:42:57 PM »
Hi Tony
I have a couple of FPHE's you can have, got some other buts too that may help your truck run better.
Also got a decent CCTV capture card with proper software for you.
