Author Topic: Got a very wierd problem with car  (Read 5795 times)
Re: Got a very wierd problem with car
« Reply #15 on: June 23, 2013, 04:39:40 PM »
Offline CHUNDER
« Reply #16 on: June 24, 2013, 10:04:34 AM »
Losse screw and delusions of humanity ???? stragight jaket job this one
Offline high compression ii
« Reply #17 on: June 24, 2013, 12:59:39 PM »
It'll be the Nut Loosening Pixies.....
Little buggers they are! I had a Fraud Crappi 3.0L years ago (Yup, Sad, I know....) and the starter bolts would loosen off over a week or so, allowing the starter to shift and make awful noises when starting.
Tried all sorts. Even bought proper new Fraud bolts and lock-washers for it. They lasted a month before they too fell out...
Never ever did cure it....
Sold the thing for more than I bought it and bought a 2.0L DOHC Toyota Celica RA40--which was faster and more economical than the Fraud--Loved that car!
« Last Edit: June 24, 2013, 01:02:16 PM by high compression ii »
In The Thermionic Past
« Reply #18 on: June 25, 2013, 09:22:48 PM »
anyway you thread stealing lot you...
PROBLEM FIXED!
eventually found the problem another 2 bolts had felt out (never to be seen again)
when engaging the clutch the gearbox moved off the engine 10 mm  :o
« Reply #19 on: June 25, 2013, 09:43:01 PM »
Great news it's fixed mate.
10mm of movment is a hell of a lot, I'm suprised the clutch was working properly.
« Reply #20 on: June 25, 2013, 09:47:11 PM »
dont forget couple bolts still left in so opposite end of bell housing was moving under load
crazy hehehe, drove it 2 and half hours today like that
hardcore vegger
Offline CHUNDER
« Reply #21 on: June 25, 2013, 11:46:19 PM »
Jeeeysus  I have always said French cars are a group of individual parts that only move together out of simpathy but don't nesesarily stop all at the same time when brakes applied.
Add a lose screw behind the wheel  and all you've got is a time bomb wating to give you a Gotcha  :o :o :o :o :o :o :o
