Author Topic: Are you thinking about winter yet?  (Read 11360 times)
« on: June 21, 2013, 09:43:25 AM »
Sadly, im already stressing about it!
Im determined to get better prepared for it this time.  Last winter i made it through on 100% bio, with no additives, but i was only able to do that due to some chance oil scores.
Still, its no fun processing in the winter at all, not to mention harder (due to heat losses, colder start points, longer settling, etc. etc.)
So, if youre planning ahead, what are you doing?
Im -
Currently not using any liquid oil - just stock piling it for the winter.
Processing all my solid oil whilst the weather is fine, no matter if i need it or not (easier to store when processed - and if i need it for the house boiler, itll be there)
Then ill move on to the liquid oil, process all of that, and store it for winter car use.
Not much of a plan, but id be interested if anyone else has any tips or tricks they use for getting through the varying seasons?
Offline Jmg
    • Veg site
Re: Are you thinking about winter yet?
« Reply #1 on: June 21, 2013, 10:29:36 AM »
I always planning to do winter better but so far I never have. Too lazy to filter any more often and too busy/cheap to get a few gallons of mis fuel/winterizer in stock.
« Reply #2 on: June 21, 2013, 10:30:59 AM »
Trouble with only using the solids and leaving the liquids for winter is that when you need to use it the liquid stuff will have turned solid in the cold.
Best way of doing it is if you start stockpiling all the good liquid stuff in the winter for next winter. Its probably not practical for most people due to storage or lack of a surplus.
« Reply #3 on: June 21, 2013, 11:24:16 AM »
No, I'm still waiting for the last one to end.
« Reply #4 on: June 21, 2013, 01:54:32 PM »
Only with a sense of dread and uprated storage (and hopefully soon processing) facilities!
« Reply #5 on: June 21, 2013, 09:36:26 PM »
Other than getting central heating in the biodiesel end of the workshop and lining the roof with kingspan/celotex, nothing really.
The workshop is never that cold in winter but this year it should be a lot warmer. I will be buying a drum of Wintron around September I suspect and start introducing that as the weather gets colder.
« Reply #6 on: June 21, 2013, 10:06:53 PM »
no worries here  8)
« Reply #7 on: June 21, 2013, 10:37:53 PM »
Yup, starting to think about it now. Longest day today, a few weeks and the nights will be noticeably drawing in.  Won't be long before the mornings will be shrouded in thick fog.
Main ambition, fit thermal store for central heating. Get processing bio. Heat bio storage tank off thermal store, get heated and insulated tank on truck.
Once I've done that, I'll get fat and hibernate.
A coolant system heater would be nice, but if I get that far, it will be a big bonus.
« Reply #8 on: June 21, 2013, 11:04:33 PM »
Maybe you could re-launch your winteriser offer Julian. Now seems like a good time
« Reply #9 on: June 21, 2013, 11:28:04 PM »
be more worried that caravan is insulated lol
no it aint funny, i lived that life for a long time once...
« Reply #10 on: June 21, 2013, 11:33:24 PM »
Caravan is pretty well insulated, only keep it warm. Two inches of kingspan in the walls, four in the ceiling.
The biggest problem is keeping a constant heat. No matter how hot the fire gets at night it is still cold in the morning. Its not my leccy supply, so I don't want to go down that route, and I used over £100 worth of heating oil last year. I can put the thermal store together for not much more than that, and heat with a turk burner running on WMO.
It will be nice to get up in the morning and have it warm. Hate stepping out the shower when it 3C..............
« Reply #11 on: June 22, 2013, 12:12:23 AM »
Funny, being a filterer, I work the other way.
I filter and stockpile as much as I can in the winter because I know I can use it at any time of year and in the summer I only filter what I'm going to use straight away in case it goes lumpy if we get a cold snap.
I've also learn't to write the temperature that I filtered at on the containers.
« Reply #12 on: June 22, 2013, 09:17:02 AM »
As you found out Nige, it is a real pain in the backside for no real gain or, if you do try to make a gain, you get slated for it.
I think I might just bite the bullet, by a 25litre drum for myself and then if a few friends want some then they can but I'm not sure I'll bother with trying to offer a bulk purchase again.
« Reply #13 on: June 22, 2013, 09:33:08 AM »
i would guess your windows are single glazed maybe? as you loose loads of heat there...
i have sealed windows up in the winter with polythene, taped round
« Reply #14 on: June 22, 2013, 09:38:01 AM »
i like you always watch the ambient temp and if filtered in hot weather try use it up...
but i filter half way (2x bed sheets + dewatered + settled 1 week + 50m with j cloth + 20m) and leave it in my tanks, so it still has 2 sets of filters to go through before out into car and can settle more.
i got 160 ltrs of oil thats still settling after 2 years! backup oil
« Last Edit: June 22, 2013, 09:40:34 AM by Aliis volat propriis »
