Author Topic: What would put on your control panel?  (Read 6365 times)
Re: What would put on your control panel?
« Reply #15 on: June 18, 2013, 09:21:10 PM »
Being VERY envious, at least I can't put a plug on the end of a lead were as Jules seems to have a problem with that.
I can - here is the one on my processor  :)
32A plug on 6sq.mm. SY-Flex cable
and this is the socket it plugs in to
« Reply #16 on: June 18, 2013, 09:38:05 PM »
Oooh yes I've got one of those :)
Would be a handy place to plug in the welder if I made an adapter I think.
« Last Edit: June 18, 2013, 09:40:09 PM by Tony »
« Reply #17 on: June 18, 2013, 09:51:50 PM »
OK so I'm a fine one to talk, but, I thought you were going to keep things clean Jules.
« Reply #18 on: June 18, 2013, 09:56:01 PM »
That is clean . . . . .  for me!
« Reply #19 on: June 18, 2013, 09:59:17 PM »
Jule's panel has inspired me to think about mine.  Not so sure on the PLC now, not when I've got a nice little Raspberry Pi.
Thinking about this:
http://www.ebay.co.uk/itm/MAX31855-K-Type-Thermocouple-Module-arduino-FTDI-Basic-compatible-MAX6675-/121122475385
(The Pi has SPI on one of the connectors with two chip selects, enough for reading two K-type thermocouples).
And I really like this:
http://www.ebay.co.uk/itm/110941667834
Shame it is so fiendishly expensive.  Though there are other cheaper relay boards.
I really like the idea of turning the heat and possibly a circulation pump on from work, monitoring the temp and having it up to reaction temp when I get home.  And then keeping an eye on it from the living room :)
Naturally would have to have some hard-wired deadlocks against liquid level and overtemp and the like.
Would be nice to find a USB/SPI/I2C pressure sensor too.
« Reply #20 on: June 18, 2013, 10:25:39 PM »
This is something that I've been thinking about, geting things up to temp before I arive would save me so much time.
But I can't plan anything past the 5th or 6th at the mo.
« Reply #21 on: June 18, 2013, 10:40:51 PM »
Ah yes good point.  I'm not sure you'll be able to use a computer after the... well... weather's quite nice at the moment don't you think? *reassuring grin*
« Reply #22 on: June 18, 2013, 10:55:54 PM »
The.......... what ?
Spill the beans young Tony or the gear pump gets it.
There's only one way to get to a pumpaphile, right where it hurts.
« Reply #23 on: June 18, 2013, 11:33:05 PM »
Now I'm stuck between a womble and a hard place!
