Author Topic: Why has my pipe bender done this?  (Read 3665 times)
Offline Rossey
« on: June 14, 2013, 06:51:29 PM »
Re: Why has my pipe bender done this?
« Reply #1 on: June 14, 2013, 06:59:36 PM »
was the metal bit inserted?
Offline Rossey
« Reply #2 on: June 14, 2013, 07:01:28 PM »
The flat bit the goes under the roller?
« Reply #3 on: June 14, 2013, 07:02:54 PM »
its flat one side and curved for pipe the other side, think it comes with a 15 / 22 / 28mm formers
« Reply #4 on: June 14, 2013, 07:10:37 PM »
'cause you pulled the pipe as well as the handle.
Try another bend bot DON'T touch the pipe, only the handles
« Reply #5 on: June 14, 2013, 07:25:02 PM »
Exactly what Jim said.
« Reply #6 on: June 14, 2013, 07:32:52 PM »
yeah what jim said :)
Offline Rossey
« Reply #7 on: June 14, 2013, 08:05:32 PM »
Yep he's right caught myself pulling the pipe aswel
There not designed for small people, done a swan neck tho just a couple of crinkles.
« Reply #8 on: June 14, 2013, 08:49:58 PM »
I never touch the pipe - ive found that if i pull the bend too quick, i get ripples - which ive never really understood!
Offline BANDIT2
« Reply #9 on: June 14, 2013, 08:53:53 PM »
use that pipe in the pic as a feed to the eductor-it'll improve mixing
probably ::)
Running [if I get enough veg] Defender 200TDI and Winnebago Lesharo (now gone)Range Rover P38 ,and a space heater on home made bio.
« Reply #10 on: June 14, 2013, 09:19:08 PM »
Or not but it will create a lot of turbulence and resistance to the flow.
