Author Topic: Air pumps for bubbling  (Read 4441 times)
Offline Rossey
« on: June 02, 2013, 08:04:30 PM »
I'm looking for a bubble pump, any advice on what to choose?
I will be doing 80-100 batches.
Do I buy an air stone or make a ring of copper pipe with small holes in?
I will also be making a ventilation system on the bubble tank, can anyone see a problem with using vacuum cleaner hose?
« Last Edit: June 02, 2013, 08:09:09 PM by Rossey »
Re: Air pumps for bubbling
« Reply #1 on: June 02, 2013, 09:05:38 PM »
Even a basic low flow air pump will do, I used one for ages, but more airflow will speed it up, and just a bit of copper pipe with end sealed and a few holes drilled in is good enough, it don't have to be round just to let air out.
« Reply #2 on: June 02, 2013, 09:10:56 PM »
Something like this is ideal. There are all sorts of different lt/min ratings to suit any budget. If you plan on using a stone make sure it's ceramic and not composite.
http://www.ebay.co.uk/itm/280-LTR-PISTON-AIR-PUMP-KOI-POND-FISH-AQUARIUM-TANKS-/390590673721?pt=UK_HomeGarden_Garden_PondsWaterFeatures_UK&hash=item5af104b339
Ceramic stones like this:
http://www.ebay.co.uk/itm/2-off-120-x-20mm-CERAMIC-AIR-STONES-KOI-POND-FISH-TANK-/400496357886?pt=UK_HomeGarden_Garden_PondsWaterFeatures_UK&hash=item5d3f7171fe
Bubble wash systems are on the wiki
« Last Edit: June 02, 2013, 09:14:44 PM by nigelb »
« Reply #3 on: June 02, 2013, 09:25:40 PM »
To make very small holes in copper tube, try sharpening a masonry nail to a very acute angle with a really sharp point (mind it doesn't get too hot and loose it's hardness).
Put it on the pipe and give it a sharp tap with a hammer.  Very small diameter holes, very quick and no broken drills.
Offline Rossey
« Reply #4 on: June 03, 2013, 07:56:36 AM »
How much
Does it have to be a piston pump?
I found a 240lpm pump for seven quid and it's just down the road from me, but it's a diaphram pump.
« Reply #5 on: June 03, 2013, 06:01:35 PM »
No it'doesn't have to be a piston pump. The only reason I linked you to that one is because it's the brand I currently use. I think they're rather good.
At the end of the day so long as it pumps air at the rate you require that's all you need.
Offline Rossey
« Reply #6 on: June 04, 2013, 10:43:37 PM »
I'm on a budget of nothing to zero lol
I understand you use little screw valves to control the amount of air.
Isn't that bad for the pump with the pressure building up?
« Reply #7 on: June 04, 2013, 11:06:49 PM »
You put a T in the pipe between pump and airstone, the valve goes on the T, open the valve to vent excess air.
This way you don't restrict the pump in any way.
« Reply #9 on: June 05, 2013, 08:08:29 PM »
Is it?
You're not the first to mention about the control valve. I've had two of these pumps. The first was used in the same way and was sold with the plant when I moved it on. The new one..more powerful..has been going for 18 months now. If it ever packs up I'll let you know.
« Reply #10 on: June 05, 2013, 09:18:38 PM »
Is it?
It is if you're using the diaphragm type pump (which I do), as it extends the life of the diaphragm.
