Author Topic: In-line strainer to protect FPHE?  (Read 2746 times)
« on: May 08, 2013, 04:19:00 PM »
Ive been using various exchangers (coil / baxi cast iron lump / radiators) for a while now to pre-heat my veg, but they are very slow.
For example, the average indirect coil is only about 0.3 m/sq in area, so, although the water is hot, the transfer to the veg is slow.
I have a large fphe, but i dont want to wreck it with BCBs.  Im wondering about fitting one of these in-line with it -
I read they have a removable mesh filter.
Wondering if anyone is familiar with them?
Re: In-line strainer to protect FPHE?
« Reply #1 on: May 08, 2013, 04:21:26 PM »
Yes K.H gifted me one a while back.  They have a little steel mesh liner that is indeed removable and cleanable.
« Reply #2 on: May 08, 2013, 08:31:50 PM »
Would you say my plan is reasonable then?
JIM on VOD has given me the fear about them blocking, and, as i want to operate one on my processor, i need it meth / temperature proof, which rules out a normal filter.
« Reply #3 on: May 09, 2013, 06:49:18 AM »
They're entirely metal construction, so temperature and methanol proof.
What's the issue with it blocking? You can always fit a PRV and a dump back into the reactor if you need to maintain flow.
« Reply #4 on: May 09, 2013, 10:19:38 AM »
The issue is that, if it gets full of BCBs, and back flushing does not work, its "new FPHE" time : (
« Reply #5 on: May 09, 2013, 10:30:37 AM »
Ah, you mean the FPHE blocking, not the filter.
Yes, I see what you mean.
Anyone ever tried to take one apart? Are they welded construction or pressed? Seal material?
