Author Topic: push in plastic pipe ?  (Read 2459 times)
« on: May 07, 2013, 06:19:21 PM »
15mm push in pipe anyone know the inside ID of the tube please?
im not near any to get a vernier on it
i need a T jiont about that size to jubilee clip some rubber pipe
« Last Edit: May 07, 2013, 06:24:55 PM by Confucius »
Re: push in plastic pipe ?
« Reply #1 on: May 07, 2013, 06:24:37 PM »
15mm central heating pipe?
Just put the tape across a piece of white, I pressume grey is the same, I'm pretty sure they take the same inserts for a compression fitting anyway.
I haven't got a vernier, but the tape says 11mm. Possibly 10.9mm.
« Reply #2 on: May 07, 2013, 06:25:59 PM »
thx chap, ineed to locate a T i can push rubber pipe onto for cold water feed useing jubilee clips
« Reply #3 on: May 07, 2013, 06:29:25 PM »
I dunno would I use a pushfit for that. I'd be more inclined to get a compression fitting T and  insert for the plastic. Then use a piece of copper coming out the T, and a copper reducer down to the required size. Much less chance of it leaking. I don't much like push fits.
« Reply #4 on: May 07, 2013, 06:35:12 PM »
got to split the water feed in me van to get it to the new heater i got
« Reply #5 on: May 07, 2013, 06:40:07 PM »
ok i orded one
andgot this too hehehe
« Reply #6 on: May 07, 2013, 06:41:40 PM »
So you need to split a 15mm central heating pipe?
I'd be using on of these.
http://www.screwfix.com/p/equal-tee-15mm-pack-of-2/95632
Thats a crazy price though. You need an insert to put in the end of the plastic pipe for the olive to grip on. Then just get a 15 to whatever you need reducer, to go in the cross pieces of the T. At least it is easily serviceable.
Post overlapped.
« Reply #7 on: May 07, 2013, 06:46:31 PM »
Post overlapped.
no, bare with me, i pushed a piece of that plastic pipe on the heater inlet/outlet and it went on tight-ish so if i know that ID of that pipe i know what T to buy, in my van i have clear drinking water pipe
« Reply #8 on: May 07, 2013, 06:59:37 PM »
Roger dodge. I'm with ya.
« Reply #9 on: May 07, 2013, 07:17:41 PM »
I've just checked the pipe that I have and it's 11mm ID, same as Gem's.
« Reply #10 on: May 07, 2013, 09:23:36 PM »
bang tidy folks  8)
« Reply #11 on: May 07, 2013, 09:25:13 PM »
