Author Topic: PLUG ... my versio of PLUTO  (Read 10015 times)
« on: April 21, 2013, 06:13:11 PM »
For nearly five years I've been lugging containers of bio from the backgarden to the drive to fill the car.
Whilst relaying a new patio, I've decided to install PLUG (Pipe Line Under the Garden), my version of the WW2 PLUTO (Pipe Line Under The Ocean) ...
Re: PLUG ... my versio of PLUTO
« Reply #1 on: April 21, 2013, 06:51:47 PM »
Looks good. I've done similar, but it runs along a wall rather than under the garden. Certainly makes life a lot easier!
Is that a urinal?
« Reply #2 on: April 21, 2013, 06:52:07 PM »
Won't the soap set hard in the pipe?
And what about a slow accumulation of Glyc drop out blocking over time?
« Reply #3 on: April 21, 2013, 07:24:05 PM »
I hope thats a before picture otherwise im slightly underwhelmed!
« Reply #4 on: April 21, 2013, 07:24:35 PM »
Nice one  ;D ;D ;D ;D ;D ;D
« Reply #5 on: April 21, 2013, 07:28:43 PM »
So cruel...but so funny!
« Reply #6 on: April 21, 2013, 07:31:45 PM »
I'd at least lay the pipe in sand, then cover it over with sand. I was on the gangs on the water board for a while, it wasn't uncommon to dig out a leaking pipe, and find a stone had punctured it.
That blue alcethene (spelling?) will also split without any encouragement from a stone. Admittedly, I don't suppose it is that common, we used to see a lot of water pipes.
In your favour, the pipe is not under any pressure, so should be ok. Otherwise ,I'd say run it in a duct. You dont want to have to be hacking concrete or patios up to find a leak.
« Reply #7 on: April 21, 2013, 07:46:32 PM »
I reckon it should be PULP, sounds better.
Pipe Line Under the Patio.
« Reply #8 on: April 21, 2013, 08:22:13 PM »
I hadn't heard of operation PLUTO before. Just read a bit about and am quite amazed.
I can't imagine this country being able to undertake a task like that today yet they managed it seventy years ago.
« Reply #9 on: April 21, 2013, 08:35:12 PM »
Is that a urinal?
Yes.
No, I don't make soap any more.
With Heather on the job I doubt it.
What a tosser, 'corse it's not!  She's chosen stone with a similar cost to Axminster carpet, but I may yet talk her into lovely, plain concrete.
Nice one
No it's not.
No it's not.
Have you got the right thread, this is a serious answer!  It's PE pipe and I was going to surround it with a little sand ... couldn't find anything in building regs about subterranean biodiesel pipes.
Stupid boy .. PULP would be Pipe Under Line Patio!
I can imagine this country being able to do that seventy years ago ... I can't imagine this country doing it so quickly or efficiently, if at all, now.
« Reply #10 on: April 21, 2013, 08:40:31 PM »
whats running in the curve round the grass?
« Reply #11 on: April 21, 2013, 08:42:45 PM »
Weeds mostly at the moment.
« Reply #12 on: April 21, 2013, 08:54:53 PM »
out the concrete?
« Reply #13 on: April 21, 2013, 09:10:46 PM »
out the concrete?
The redish looking strip is a brick edge, the bit behind it it broken concrete waiting to be dug up to pour a foundation for a second, higher brick edge.
« Reply #14 on: April 21, 2013, 09:13:57 PM »
The mixers going to get another workout then.
