Author Topic: My new control panel  (Read 8140 times)
Offline Huntman40
Re: My new control panel
« Reply #15 on: April 06, 2013, 10:10:35 PM »
I dont demeth and my processor has a good seal and a vent pipe.
Im not going to loose any sleep over meth fumes, im confident of a good seal
Heat sinks get hot, better to keep them out of the way
« Last Edit: April 06, 2013, 10:16:21 PM by Huntman40 »
« Reply #16 on: April 07, 2013, 07:28:23 AM »
here are my tag writings, courtesy of K.H's handheld printer machine, thx kieth...
« Reply #17 on: April 07, 2013, 07:30:13 AM »
for your fan use an old phone charger, 240 down to 5 or 7 volts...
could even use a battery, prolly last ages....
Offline Huntman40
« Reply #18 on: April 16, 2013, 11:08:57 PM »
in the end i decided to give one of these a try for the fan power. Im trying to think of a more sustainable source of transformers for more professional jobs.
http://www.ebay.co.uk/itm/370704254100?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
but in this case im doing as you said with a 9.5v somthing charger just plugged in outside the box :)
I was thinking of disassembling it but with its pending replacement i cheated and wired it externally.
« Reply #19 on: April 16, 2013, 11:47:34 PM »
why not use a 230v ac fan? You can get small ones 80mm or so?
This one is 120mm
http://www.rapidonline.com/electrical-power/adda-main-axial-fan-230v-sleeve-bearing-120mm-37-0972
« Reply #20 on: April 17, 2013, 07:45:22 AM »
you would get that tranny in ya box...
