Author Topic: Purifiers  (Read 5636 times)
Purifiers
« on: March 10, 2013, 05:20:35 PM »
I promised that the next time I had a purifier in bits I would get some photos, so here they are. This is actually a lube oil purifier, not fuel oil - but they are identical with the exception of a few settings on the control system and the size of the gravity discs. This keeps the lube oil sufficiently clean for it not need to be changed - only ever topped up. We'd only change it if the oil is chemically degraded - something which rarely happens on this vessel as we're burning low sulphur diesel.
A purifier is essentially the mutt's nuts of filters. They'll remove solid particles as well as separate liquids of two differing densities (normally oil+water). They were originally invented for the dairy industry - for separating cream and milk but have evolved somewhat since. I hope you can see the relevance to us biodiesellers - having one of these on a settling tank would greatly simplify things!
This is an Alfa Laval unit - part of the MMPX series. They are self discharging - meaning that at periodic intervals the bowl opens and discharges the particulate matter into a tank before starting the process again. The only time it's opened is either for planned maintenance or when it breaks down (as this unit has recently done).
The bowl spins at just under 10k rpm and the feed rate is about 2000 litres per hour.
Information on operation can be found here:  http://www.marineengineering.org.uk/ (scroll down on the left to purifiers)
I'm actually building this up in this sequence of shots (which is why it's so clean), but for clarity of explanation the order is reversed.
So, the unit itself. The feed on the top is for sealing water, the product in pipe is hidden at the back, and the one to the left is the purified discharge. There are other pipes as well for operating water (opening and closing the bowl) that are at the bottom of the unit. The fat one is the sludge discharge, and the one behind it is the water discharge.
With the hood removed. The stainless bit is the bowl - all the red stuff is stationary. You can see the sludge ports in the side - these are normally closed in operation and open from time to time to discharge all the sludge into a sludge tank. The spindle in the middle is what the product is fed in through. It's hollow all the way to the bottom so that the product is introduced to the bottom of the distributor before making it's way back up through the disc stack. It also holds an impeller for discharging the cleaned product on the outer surface.
Gravity disc removed. The brass housing at the top is the outer section of the discharge pump.
And the gravity disc itself - this is what sets the discharge point between the two phases of oil and water. These come in various guises depending on the manufacturer. Alfa Laval have evidently chosen a cone shape for this one. The Westfalia units I've played with in the past use a giant washer.
Bowl top removed. You can see the top of the disc stack.
Disc stack top and spindle removed. The wings ensure that the product is rotating with the bowl. The holes in the discs allow movement of the product/water between adjacent discs.
Removed disc stack, discharge pump, spindle and gravity disc assembly.
A single disc. Each one is cleaned and inspected closely. They've spent about 12 hours sitting in a vat of acid prior to being washed in diesel and finally wiped with a rag. There are about 85 of them (despite counting them several times today, I've forgotten the exact number!)
Sliding piston. This moves up and down in the bowl to open/close the sludge ports in the side. (1.6MW alternator in the background. :D )
Operating water nozzles/ports. This pushes the sliding piston using water supplied externally.
I hope that's of some interest to some people on here. I'm sure this is how the big boys would ensure that their biodiesel is devoid of water/particulates - it would be how I'd do it too if I had the budget. That said - I do have a small milk purifier at home from the 1940s. It's a simple hand crank job and I do wonder how it'd handle bio.
« Last Edit: March 10, 2013, 05:29:40 PM by therecklessengineer »
Re: Purifiers
« Reply #1 on: March 10, 2013, 05:42:11 PM »
thanks for that. very interesting. i have just got one of nathans simple ones. going to use it to clean up my WMO for my burner,as well as final cleaning of bio when i get around to making some.
Re: Purifiers
« Reply #2 on: March 10, 2013, 05:47:32 PM »
Most interesting. What is the sealing water going in at the top, in the first pic? You mention operating water, is the thing powered by pressurised water? I guess the motor by the side may be driving a water pump?
A lovely bit of engineering.
I want a big alternator like that one.............
Re: Purifiers
« Reply #3 on: March 10, 2013, 05:52:42 PM »
Interesting bit of kit.  I doubt they turn up on eBay regularly though :)
Re: Purifiers
« Reply #4 on: March 10, 2013, 06:38:34 PM »
The motor by the side is the driving motor for the bowl. 2.2kW IIRC.
I probably should explain a little better!
The whole thing relies on the principle that oil will float on water. Water is put in first and is flung to the outside. The bowl fills up and eventually overflows out of the water outlet by the gravity disc. Oil is then pumped through - the oil 'floats' on the water passing up through the disc stack and out of the oil discharge. Particles are flung into the water (aided by their path through the discs) and ultimately the outside of the bowl. Any water in the oil passes into the water in the bowl causing the water to overflow from the water outlet a little more.
So really, it's quite different to a centrifuge - it'll actually continuously separate two liquids as well as solids.
Here's a good cross section of one:
« Last Edit: March 10, 2013, 06:41:27 PM by therecklessengineer »
Re: Purifiers
« Reply #5 on: March 10, 2013, 06:57:26 PM »
I'd like one of those :-)
I get a weekly email from firm in China that produces these, but the smallest that they do is still a couple of K plus shipping.
Re: Purifiers
« Reply #6 on: March 10, 2013, 07:58:17 PM »
Great writeup and what a beautifully clean engineroom.  Very different to the Greek tankers, "run on a shoe string" that I used to visit years ago!
I found a cheap cream separator on eBay a while back and posted it on the VOD.  Needless to say I can't find the thread using the search facility, but several other people have posted about them.  Am I understanding your description correctly, in that the internal geometry is designed to suit fluids of specific SGs?  So a cream separator would require modification?
Re: Purifiers
« Reply #7 on: March 10, 2013, 08:30:51 PM »
Only the gravity disc varies - but it varies with the ratio between the densities of the fluids. So milk/cream might be similar enough to biodiesel/water/gylc to work correctly. There's a bit of leeway as the interface can move up/down (well, horizontally on the diagram above) the discs - although the ideal position is the middle of the holes through the disc stack.
Even if a new one is needed, something could be turned up on a lathe for a little hand cranked one. Not something you can do on a full size one due to the very fine balancing.
Re: Purifiers
« Reply #8 on: March 10, 2013, 08:52:27 PM »
Hmm, 10,000 RPM cream separator on eBay ... http://www.ebay.co.uk/itm/DAIRY-CREAM-CENTRIFUGAL-SEPARATOR-50L-h-ELECTRIC-NIB-/170883021576?pt=UK_BOI_FarmingEquipment_RL&hash=item27c96bfb08
Including shipping it's quite expensive as a curiosity buy, shame!
Re: Purifiers
« Reply #9 on: March 10, 2013, 09:01:51 PM »
Thanks Reckless, nice to know how these things work.
That cream separator is a bit expensive just to play with, but if you had plenty of cow juice you wanted to skim, then it is not a bad price. Got no cows now, used to have a milker when I was a kid.
