Author Topic: Good prices on VFD  (Read 2343 times)
Good prices on VFD
« on: March 05, 2013, 11:27:08 PM »
http://www.ebay.co.uk/itm/300870658077
http://www.ebay.co.uk/itm/300870661661
http://www.ebay.co.uk/itm/300870665491
The first one (lowest powered) I've offered him £20 for - Mark gave me a little 112W three phase gear pump that it would drive just fine.  I know the motor works because I hooked up a cap to the third phase and it ran ok a while back.  So I'm thinking variable speed drywash pump.
The others are equally very well priced, if anyone wants to drive a three phase motor at variable speed.
Re: Good prices on VFD
« Reply #1 on: March 06, 2013, 12:50:28 AM »
i am sure they exist but i dont think 3 phase 240 motors are that common. except in the states. never seen one anyway. of course you could  a 3 phase transformer and use a 415 volt motor which are common. wonder if you can just use one phase and a single phase motor?
« Reply #2 on: March 06, 2013, 05:51:17 AM »
3 phase motors can be wired in star/delta for 230/415V operation.
I run a 3 phase pump on my processor using a VFD. Works very well.
« Reply #3 on: March 06, 2013, 06:13:49 AM »
dont understand this bit?
Quote
This drive can be used topower a 230V three phase motor from a 230V supplymaking it possible to run three phase machines from astandard single phase supply.
i always thought you can run 240v motors on 240v supplys just useing a 3 pin plug basically, well i do on my yaqm105...
and tony hehe you tryiing to buy off auction and trying to get him to end early?  :o floating ebay laws and rules...  ;D
« Last Edit: March 06, 2013, 06:28:26 AM by Ping Pong from pong ping »
« Reply #4 on: March 06, 2013, 09:13:37 AM »
Quote
240V single phase motors have a small start winding to kick them off in the right direction and usually a run cap to energise this winding.  You can make a three phase motor run off single phase but you need to give the third phase a cap in a similar way to "nudge" it in the right direction.  Or, a rope around the shaft to get it going the right way ;)
But a cap is not an efficient way to run a three phase motor, and it'll be down on the rated power (2/3 power I think?)
As James says so long as you can connect the three phase motor windings in delta formation then it'll run three phase 230V.
Don't ask, don't get ;)
« Last Edit: March 06, 2013, 09:16:01 AM by Tony »
« Reply #5 on: March 06, 2013, 09:17:53 AM »
Quote
Yes, a 240V single phase motor will run on a 240V single phase supply. A 3-phase motor can be connected in differing configurations for 415/230V operation - but must be 3 phases, even with 230V operation.
There are various ways of 'bodging' a three phase supply from a single phase source - like adding a capacitor, or even using another large 3 phase motor to 'generate' three phases from it's rotation.
Given the cost of VFDs these days, it's really not worth it - especially given the amount of control and protection they give you for your motor. Mine will trip out on overload/overheat/phase loss/earth fault etc etc.
« Reply #6 on: March 06, 2013, 02:08:50 PM »
He relisted it for me at £20 as a private auction, so now I have a nice little VFD on the way to drive Mark's gear pump :)
I'm going to plumb it permanently into my settle tank with three output valves, one to pump back into the settle tank (as a gentle agitator during settling) one via the drywash tower (circulate through drywash tower) and one to discharge into final storage.
Might add an additional two valves at the bottom with a spigot so I can suck biodiesel into the settle tank or drywash a batch that isn't in the settle tank.
Happy tinker time will ensue :)
« Reply #7 on: March 06, 2013, 04:34:39 PM »
That will be handy to have a variable speed gear pump.
