Author Topic: Glycerol from ASM reactions  (Read 17525 times)
Re: Glycerol from ASM reactions
« Reply #45 on: March 08, 2013, 04:18:53 PM »
A gly trap then, I've spoken to Tony about this in the past (his idea not mine).
« Reply #46 on: March 08, 2013, 04:22:04 PM »
Oh, that old chestnut.  We were all expecting something novel and exciting based on deep fundamental physics, and we get a bucket with a lid and a pipe ... really!
The idea's been muted many times before, but not for static collection of glycerine that I can remember.  Have you tried using it for collecting glycerine as the reaction progresses?  A bit like real time two stage reaction.
« Reply #47 on: March 08, 2013, 05:12:58 PM »
I was going to say keep up Jim but you posted in this thread already
http://www.biopowered.co.uk/forum/index.php/topic,933.msg9245.html
The stainless tank has built in coils which could be used to warm what drops out back to liquid for removal.
Thinking about it I bet the gear pump would do a good job of moving the glyc from the sedimenter to containers for disposal.
« Last Edit: March 08, 2013, 05:14:39 PM by Tony »
Offline bertle
« Reply #48 on: March 08, 2013, 09:28:00 PM »
A sealed container connected to the bottom drain of the reactor larger than the volume of the glycerol with
a tap above the glycerol level to drain the bio
Give him the money Mable.
You don't need a valve to return the bio, as the heavier glyc drops in the bio returns back up the same pipe.
To make things easier use 22mm pipe and valve.
I don't get it, how does that get the solid glyc out of my processor?
I got the bio out easily enough, I just opened the valve I put in a couple of inches above the cone and drained it in to some cans.
« Reply #49 on: March 09, 2013, 12:59:07 AM »
It doesn't BUT it will help you and others should the need to rapidly depart the scene occur again.
Offline RichardP
« Reply #50 on: March 09, 2013, 07:12:15 AM »
BTW I've recently fitted a special glyc entry point, makes life a piece of pi$$. I can put 20ltr of glyc in as fast or faster than the methoxide.
You've not enlightened us thickos on your lid free glyc injection system yet.
Offline bertle
« Reply #51 on: March 09, 2013, 08:11:35 AM »
Ah ok, I have got the pleasure of sorting this out this afternoon, nearly out of fuel and could have done with some in the settling drum by now.
Who would be a bio brewer.......
« Reply #52 on: March 10, 2013, 07:11:12 PM »
Hmm... that's why I went back over to KOH
« Reply #53 on: March 10, 2013, 07:34:51 PM »
How did you get on ?
Offline bertle
« Reply #54 on: March 10, 2013, 08:06:55 PM »
Well after a couple of hours getting covered in glyc it is all sorted and reloaded ready to make a batch this week. Once the oil was out it was apparent that the glyc was not totally solid just very thick and a good rodding sorted it out. I had to take the pumps appart and clean them out but could have been worse!
