Author Topic: Glycerol from ASM reactions  (Read 17518 times)
Re: Glycerol from ASM reactions
« Reply #30 on: March 07, 2013, 10:19:03 AM »
Sir, Sir, I know Sir .... leave the pump running.
Not even warm, it's simpler than that and NOTHING is turned on or left running.
OK, got it now ... turn the processor up-side-down so the glycerine settles and sets at the top, then turn the right way up to drain the bio.
« Reply #31 on: March 07, 2013, 10:22:58 AM »
Got me curious too.
Use KOH?
Drain the Glyc first?
I thought we were talking ASM and leaving it WITH the glyc still on board.
« Reply #32 on: March 07, 2013, 10:25:35 AM »
Julian, you're getting colder than the Antarctic on a winters day.
It really is simple.
« Reply #33 on: March 07, 2013, 10:30:17 AM »
Got me curious too.
Use KOH?
Ah, so this doesn't apply to NaOH Methoxide?
You're such a tease.
« Reply #34 on: March 07, 2013, 10:37:50 AM »
Got me curious too.
Use KOH?
KOH makes no difference so yes it will work on catalysts that solidify as the temperature drops.
A clue, though you shouldn't need one, think Sg.
I'm going over to the skunk works now so I'll check out your thoughts later.
« Last Edit: March 07, 2013, 10:42:26 AM by jamesrl »
« Reply #35 on: March 07, 2013, 11:40:33 AM »
Add Methanol or water?
Offline thewormman
« Reply #36 on: March 07, 2013, 12:19:07 PM »
'And the poor man longed to eat from the crumbs of the rich mans table....'
What a tease, you love it don't you Jim... ::)
« Reply #37 on: March 07, 2013, 06:52:16 PM »
You add nothing.
« Reply #38 on: March 07, 2013, 06:54:19 PM »
Still no ideas then?
I've used the idea before and it works a treat.
« Reply #39 on: March 07, 2013, 07:22:18 PM »
Double skinned reactor, add some heat and off you go.
« Reply #40 on: March 07, 2013, 08:20:30 PM »
No, it can be used on any reactor.
Come on, you lot ain't thinking.
Whatever happened to the lateral kind.
« Reply #41 on: March 07, 2013, 08:31:11 PM »
Don't demeth it ?
« Reply #42 on: March 07, 2013, 09:59:48 PM »
A sealed container connected to the bottom drain of the reactor larger than the volume of the glycerol with
a tap above the glycerol level to drain the bio
Offline RichardP
« Reply #43 on: March 07, 2013, 10:07:28 PM »
Probably just a valved suction inlet before the pump, stick the pipe in the glyc, open valve to pump and away it goes.
« Reply #44 on: March 08, 2013, 03:57:05 PM »
Give him the money Mable.
You don't need a valve to return the bio, as the heavier glyc drops in the bio returns back up the same pipe.
To make things easier use 22mm pipe and valve.
