Author Topic: Viscosity cup page ... is falcon about?  (Read 12386 times)
« on: March 04, 2013, 12:29:27 AM »
I've just found a page started by falcon over a year ago.
Ron, from the stats, it would seem you were on line yesterday.  Looks like you were having trouble uploading photos and abandoned the page.  It was a shame, because it looks like a good idea which could be of use to quite a few folks.
Anyhow, I've taken the liberty of uploading a couple of your photos and laid out the page here ...  http://www.biopowered.co.uk/wiki/Viscosity_cup
Let me know if you think it's OK.
Re: Viscosity cup page ... is falcon about?
« Reply #1 on: March 04, 2013, 09:22:25 AM »
That's a good idea, I shall be looking for a suitable ladle now.
« Reply #2 on: March 04, 2013, 05:52:03 PM »
blending biodiesel with miss fuels will never be the same viscosity of 100% keresene would it?
« Reply #3 on: March 04, 2013, 08:06:16 PM »
Can think of some useful applications for this:  For example comparative viscosity tests with bio after different processes.
« Reply #4 on: March 04, 2013, 10:07:09 PM »
It could also  be used to monitor the effects temperature has on bio and veg in the winter,
after a while it should be possable to evaluate at what viscosity the filter will start to block.
« Reply #5 on: March 04, 2013, 10:31:08 PM »
As this seems to be generally accepted as a good idea by many, would it make sense to try and establish a "standard hole" for a specific volume ladle?
That way, if we established a "standard" temperature, we could compare viscositys between members (within reason)
« Reply #6 on: March 04, 2013, 11:16:11 PM »
Presumably shape also has an effect on the drain duration (wide and short vs thin and tall)?
« Last Edit: March 04, 2013, 11:17:52 PM by Tony »
« Reply #7 on: March 04, 2013, 11:46:14 PM »
For accurate viscosity comparison, brewer to brewer, a standard cup will be needed.
Perhaps the top of the ubiquitous 2ltr pop bottle with a standard hole size in the cap.
« Reply #8 on: March 05, 2013, 01:07:57 AM »
A standard container would be a good idea.
Don't those pop bottles deform too easly?
Using some type of packaging would mean it's widly available though.
« Reply #9 on: March 05, 2013, 06:11:37 AM »
good piont also amount of oil needs to be the very same level in everybody cup aswell as being the very same cup as mentioned. i see this on a run of the mill 200 ltr drum, when full 200 ltr and you open the crud valve i can shoot a jet 2 foot in a downward arc, half full onlt achieves a 1 foot and so on... the downward force acting on the amount of volume makes a diff.
« Last Edit: March 05, 2013, 06:16:29 AM by Ping Pong from pong ping »
« Reply #10 on: March 05, 2013, 06:49:32 PM »
It's the height of the head that makes the difference, 100L and 50L will produce the same pressure at the bottom for the same given head (no smutty remarks needed).
« Reply #11 on: March 05, 2013, 06:54:09 PM »
 8) lol hehe
« Reply #12 on: March 05, 2013, 10:20:02 PM »
I have one from my spray kit i used it when testing the coldflows
« Reply #13 on: March 05, 2013, 10:54:28 PM »
Keith, your avatar looks lie RM in a goldfish bowl.
« Reply #14 on: March 08, 2013, 07:01:00 PM »
Just been looking at the winter addatives page and it's obvious KH used a viscosity cup for the tests.
What did you use Keith?
