Author Topic: Glyc amount using ASM  (Read 6664 times)
Offline RichardP
« on: February 27, 2013, 08:16:18 PM »
Just a quick question for those using ASM regarding the amount of glyc that is produced compared with the amount when using NaOH or KoH.
I do 160 - 170 liter batches, and with NaOH used to get around the same volume of glyc out as the methoxide going in, around 26 liters.
Now with ASM I'm getting around 15 liters or so out with a total of 25liters meth & ASM going in.
The finished bio amount is going up by that 10 liter difference too.
Anyone else getting a similar thing?
Re: Glyc amount using ASM
« Reply #1 on: February 27, 2013, 08:33:12 PM »
Haven't quantified it yet, I been concentrating on not making soap, but the last batch that worked OK, defiantly showed a significant reduction in glycerine.
« Reply #2 on: February 27, 2013, 08:36:30 PM »
Julian, are you still doing a titration two stage or have you gone over to titless ?
« Reply #3 on: February 27, 2013, 08:41:45 PM »
The last couple have been no titration.  But I find it more hassle the normal two stage and I still think that a 3/27 (or derivative there of) needs more time to drop than the process sensibly allows.
« Reply #4 on: February 27, 2013, 08:49:20 PM »
I've only done one batch so far, but yes, I'm seeing that too.
« Reply #5 on: February 27, 2013, 10:11:50 PM »
I was the first to stick my head above the parapet ref. a greater out put of bio than wvo in.
I do 100ltr batches and only need one 20ltr cubies for two batches worth of glyc, btw I'm not demething the Glyc.
Others using ASM have also noticed the difference.
« Reply #6 on: February 27, 2013, 10:46:22 PM »
This is really interesting the way changes in making the Bio are panning out. My batch using acetone had the same sort of reduction in Glyc that you have experienced with ASM,  this was with KoH though. I had about 19 litre's from a 180 batch.
Offline jgs600
    • www.biopumps.co.uk
« Reply #7 on: February 28, 2013, 04:15:26 AM »
yes i agree too, also on my last batch i made ui used less meths too than ive ever used, and my soap levels have deffo been lowered, as i need to water wash way less than ever now to get a clear 50/50 pass
1998 c250 merc..100% bio
Offline db
« Reply #8 on: March 01, 2013, 09:41:11 PM »
My 1st batch with ASM deffo produced less soap, approx 8 litres less. I forgot to measure the final volume of bio though, but I'm expecting it to increase.
Offline BassAddict
« Reply #9 on: March 02, 2013, 09:43:44 AM »
I've noticed the same too - much less glyc and much less meth used too. 180 litre batch and only 25 litres used in total (plus ASM) Stage 1 = 20 Litres meth + 3.6 Litres ASM. 1ml drop out. Added 360ml ASM to the other 5 litres and got a perfect pass with little soap and 30 litres of glyc rather than 40 - 45 I get.
How can it possibly make more bio than WVO in?
GL Eco 180 litre batches
Golf Mk 4 1.9 - 45000 miles on B100
« Reply #10 on: March 02, 2013, 05:51:41 PM »
Seems impossible but one of the chemist's will come in with an explanation I'm sure, it was explained to me but didn't stick enough to repeat it with any accuracy.  Your Glyc amounts do seem a tad high still though for some reason.
« Reply #11 on: March 02, 2013, 10:20:27 PM »
Today I received a nice suprise, 20L of ASM that I wasn't expecting (a very nice and unexpected suprise).
So I'll be using it on my next batch, hopefully I'll replicate these findings.
I now need to do some reading up on use and storage of this magical stuff.
« Reply #12 on: March 02, 2013, 10:48:46 PM »
He said you'ld be surprised.
Storage:
Shelf life of ASM is quoted as 12 months from delivery if kept dry and in original packaging. Storage temperature should not exceed 30°C, and at temperatures below 10°C the active ingredient may start to precipitate. Warming, combined with agitation will help re-dissolve the active ingredient.
Crystallisation temperatures of ASM solutions:
    25% ... -2°C
    28% ... 0°C
    30% ... 5°C
« Reply #13 on: March 02, 2013, 11:07:23 PM »
Is there a calculator for It. I've looked but can't find one.
It's safe to say Carl will be getting a top up whenever he needs one for a while yet.
« Reply #14 on: March 02, 2013, 11:23:49 PM »
All the calculations are here Mark. It pretty much covers all methods. I use a base of 4 for stage 1 ([4x 150] x 5) and 5  for stage 2 ([5x % of unreacted] x 5) on a two stage no tit.
http://www.biopowered.co.uk/wiki/Anhydrous_sodium_methylate
