Biodiesel => Biodiesel equipment => Topic started by: K.H on January 28, 2013, 10:20:19 PM
Title: Quick release couplings?
Post by: K.H on January 28, 2013, 10:20:19 PM
Im looking for a quick release coupling that shuts the flow off when disconnected, these look like they may be suitable but im not sure that they shut the flow off, any opinions?
 http://www.ebay.co.uk/itm/MACDONALD-Male-Female-Hydraulic-Quick-Release-Action-Coupling-Type-HF-/130831671887?pt=LH_DefaultDomain_3&hash=item1e762ce24f&_uhb=1
Title: Re: Quick release couplings?
Post by: Dickjotec on January 28, 2013, 10:25:09 PM
Think those will do. Hydraulic couplings have to seal but don't know if the seals inside will be bio proof.
Post by: K.H on January 28, 2013, 10:42:37 PM
Cheers Dick, only for WVO transferring so think i will buy some
Post by: Rotary-Motion on January 28, 2013, 11:00:24 PM
there about 10mm ID going by tape measure
Post by: Rotary-Motion on January 28, 2013, 11:08:16 PM
hmm i see now cant leave pipe on.......
Post by: julianf on January 28, 2013, 11:18:25 PM
i dont know if you got them, but im pretty sure the iso ones seal on both sides -
http://www.ebay.co.uk/itm/Hydraulic-Quick-Release-Coupling-1-2-BSPP-ISO-A-FF-/270786588590?pt=LH_DefaultDomain_3&hash=item3f0c236fae
i have a set (somwhere) but ive never put them into service, and cant recall the exact details.
theyre not too expensive for smaller bores.
Post by: julianf on January 28, 2013, 11:22:36 PM
Some of these -
http://www.oilybits.com/hose-couplings-reels/hose-connectors/cam-and-groove-couplings/prod_290.html
and some full bore butterfly valves (which are often real cheap at BES) may work out better for preserving the bore / flow ?
possibly cheaper too, if a little more awkward to use?
Post by: Tony on January 29, 2013, 09:57:32 AM
The oilybits ones are good prices but the only metal ones are Aluminium?  I'd love to have some quick release connectors but they're just so expensive...
Post by: julianf on January 29, 2013, 11:26:11 AM
The fear of aluminium =- aren't all the spin on filter heads (in landrovers etc) all aluminium?
Or were you wanting them for bio processing (where the caustic will be present?)
Post by: Tony on January 29, 2013, 11:45:11 AM
Think Bosch IP body is ally too.  I think this is why we like to remove all the Methanol before it gets to the car.
Quote
Mostly for WVO/bio transfer in my case.  Maybe it's not such an issue for this?
Post by: julianf on January 29, 2013, 11:50:40 AM
Im sure its just a slip up, but its the caustic that does for ally, not the meth.
I realised quite how it reacted with some metals, when i got a trace amount on some galvanised.
My personal suspicion is that well made bio has very limited caustic in it - of course, this is whats being titrated for by the acid wash method.
I (personally) would have no issue using the fittings for bio transfer - indeed, you could look at is this way - an early warning system for if your bio is still reactive!
Post by: Tony on January 29, 2013, 12:02:54 PM
I'm sure that's true too, but Methanol strips off the oxide layer on Aluminium, which then allows the surface to oxidise further with any dissolved oxygen (and Methanol acts as an oxidising agent too).
Methanol and Aluminium are not buddies :)
Post by: julianf on January 29, 2013, 12:09:01 PM
...you learn something new every day! : )
Post by: Tony on January 29, 2013, 12:33:32 PM
Watch this... if the installers of the aluminium-finned flame arrester had known it, then two of the chaps fitting the roof may not have died.
https://www.youtube.com/watch?v=yYgJcnzr_2k
Scary stuff!
Post by: Julian on January 29, 2013, 01:51:29 PM
We went through this on the VOD.  I got info from my mate (yes Keith I do have a few!) with a PhD in chemistry who advised that the effect was at a microscopic level.  It would take years for Methanol to have a serious effect on anything of reasonable thickness.
Post by: Tony on January 29, 2013, 02:10:34 PM
That's interesting.  At the risk of going too far off topic there used to be a bio producer down my way that winterised his commercial biodiesel with Methanol.
Post by: greasemonkey on January 29, 2013, 03:21:54 PM
Scary stuff!
Nasty. Easy to see how it could happen. Seems a bit thtupid making the flash arrestor out of aluminium in the first place mind. Its surely going to corrode up over time, with or without the Methanol. Although, to be fair, they did say it should have been serviced every 12 months.
Post by: nathanrobo on January 30, 2013, 07:51:23 PM
Where / how were you thinking of using them?
Post by: K.H on January 30, 2013, 08:10:39 PM
When i bund the wash tank and processor the wvo storage tank will be a few feet away, so thats what they are for, the one i linked to arrived today and does NOT shut off  :(
Post by: Jamesrl on January 30, 2013, 08:15:47 PM
Stick something in the hole then like your di finger.
Post by: nathanrobo on January 30, 2013, 08:20:11 PM
The Filtertechnik ones seal perfectly.  They use them on the rigs, so it could be worth a call to Mike - see if they'll sell them as a part.
Post by: K.H on January 30, 2013, 08:23:50 PM
Its only a small hole, im sure you have something small i can borrow!
Post by: Jamesrl on January 30, 2013, 08:27:10 PM
I was under the impression you have a VERY small di er little finger, well so a certain lady told something like that at the BBB.
Post by: K.H on January 30, 2013, 08:31:12 PM
Chunder is NO lady, ladies dont kiss and tell!
Post by: Tony on January 31, 2013, 10:05:47 AM
Some of these -
I think with all due consideration, despite being Aluminium, if these are used for oil transfer then they should be fine.  I may well have to save up for a few of these for the new processor.  Do the different "types" just designate different pipe fitments (male/female bsp/barb)?
What is the "Viton seal" they talk about?  Is that just a sealing o-ring?
Post by: julianf on January 31, 2013, 11:59:10 AM
so far as i can tell -
type a/d are a paid for connecting to male bsp
type c/e for hoses
type b/f for female bsp
and then, of course, you can mix and match as you see fit.
i want to get some for my mono pump - i use it for general purpose veg shifting, so it has a suction tube and a 30m 3/4 hose attatched... permenantly - which does not make for much fun when i want to move it about.
i dont think theyre 'complex' like the iso couplers, so i suspect the seal just sits in a recess somwhere, and, as it says -
All Fittings are supplied as standard with NBR seals, with Viton and NBR Filled Teflon (PTFE) available seperately
the stator in my mono is not viton, so ive never given these seals much thought!
Post by: Jamesrl on January 31, 2013, 02:25:35 PM
Aha! so it is true about the tryst with our Chunder, I thought he was pulling my leg when he told me.
Oh ye', he said can he have is pants back, they're the only ones he has without holes in'm.
Post by: K.H on January 31, 2013, 04:12:34 PM
Sorry no can do, last I saw of them they were powering a sailing ship across the Atlantic
Post by: Jamesrl on January 31, 2013, 08:04:58 PM
So from your last two replies you're confirming there has been a relationship with said lady and that you kept his pants as a trophy.
Nuff said.
Post by: K.H on January 31, 2013, 09:01:43 PM
Jealousy can be a terrible thing!
Oh and the other half wants to know who your avatar is?
Post by: Julian on January 31, 2013, 09:09:38 PM
I'm not surprised, he's a bloody site better looking than you!
Post by: K.H on January 31, 2013, 09:13:44 PM
Says the bloke that looks like a rat peeking out a hedge
Post by: Jamesrl on January 31, 2013, 09:20:22 PM
Me of course, when is was a little younger, good looking bugger wasn't I
Post by: K.H on January 31, 2013, 09:22:59 PM
Her money is on Eminen, i think more M&M,s
Post by: Jamesrl on January 31, 2013, 09:27:32 PM
He did copy my style I must admit, even had plastic surgery to copy my image.
Post by: K.H on January 31, 2013, 09:29:05 PM
I could of done that for nowt, me and my trusty baseball bat!
Post by: Julian on January 31, 2013, 09:29:36 PM
Oh dear, one more brain cell and you could work it out for yourself.  Picture property ... http://www.biopowered.co.uk/forum/avatars/Musicians/Eminem.jpg
Post by: Julian on January 31, 2013, 09:31:23 PM
A hedge is merely a row of bushes ... I should be so lucky!
Post by: Jamesrl on January 31, 2013, 09:36:20 PM
I had a box of brass bushes, never knew it was a hedge.
Post by: K.H on January 31, 2013, 10:20:50 PM
Anyway im going for the ISO ones suggested by the sensible Julian as i want both sides to seal when disconnected as they will be used on transfer pipes, fed up bending the pipe double when i disconnect!
