Biodiesel => Chemistry and process => Topic started by: K.H on September 30, 2012, 09:01:07 PM
Title: In processor titrated water wash method
Post by: K.H on September 30, 2012, 09:01:07 PM
Me and Jules have been trialling a new method of washing suggested by Paul Carrington on here,it involves titrating the bio diesel and adding the correct amount of acid to neutralise the soap,this allows you to pump wash from the outset removing the chance of an emulsion,this can be done "in processor" and so far is proving a great sucess
Title: Re: In processor titrated water wash method
Post by: Dickjotec on September 30, 2012, 09:48:25 PM
Interesting tell me more! Or is it a state secret?
Post by: Carrington on September 30, 2012, 10:47:16 PM
Hi dick
No secret, when the reaction has completed and you have a full conversion then settle out the Glyc. Once the Glyc has been removed mix bio and do a soap titration test using the same solution as you will use to neutralise the bio. Mix the acid and water required about 7-10% batch volume and pump mix in to reactor. Mix for few minuets them leave to settle. Drain water then pump in about 15% batch volume clean water pump for few minuets leave to settle . This should give you clean bio now dry as normal . Using acid at the start of washing means no emulsion production allowing  for pump wash and using a lot less water and time.
Hope the makes sense.
Any probs drop me a line or give me a ring
Cheers
Paul
Post by: Julian on September 30, 2012, 11:00:31 PM
Think I'll have to give that a go.  I've stopped 7% washing in order to make Glogs, and that seems to promote emulsions forming during mist washing.
Last two batches I've had the white creamy lumps coming out with the wash water.
What acid do you use and what strength?
Post by: Carrington on September 30, 2012, 11:22:18 PM
Hi Julian
You can use any acid solution for the washing , you just need to use the some acid in the titration solution . This allows you to calculate the exact amount of acid needed to remove soap and any unused catylist
I mist washed once about 7years ago then come up with this way to pump wash quick and easy
Post by: Julian on September 30, 2012, 11:39:22 PM
I've got some concentrated sulphuric acid but I'd like to keep that to use in pickling baths.
Would vinegar do, or is it so weak that you'd need a tanker load?
Post by: K.H on October 01, 2012, 07:34:19 AM
I used vinegar and Jules used Sulphuric,i will post up the method i used later this evening
Post by: Tony on October 01, 2012, 07:58:54 AM
Interesting.  It's mentioned here but the quantities involved didn't seem as well quantified.
http://www.biodieseldiscussion.com/forums/archive/index.php?t-10182.html
Post by: Carrington on October 01, 2012, 08:02:21 AM
Morning all
Any acid liquid will work but I think the stronger the acid the more water needed to be mixed with it , so vinegar would probably work neat where sulphuric would def need diluting with water
Paul
Just had a look at Tony's link and will go back to it when my eye's wake up,
Post by: K.H on October 01, 2012, 09:03:09 AM
A few people add acid before washing Richard P for one,where this differs is we titrate to get the exact amount
Post by: Carrington on October 01, 2012, 09:39:32 AM
Yes it the titration that is the difference , this way you can pump wash with confidence . Also if the FFA's are hygroscopic then they would be washed out with the clean water wash
Post by: Julian on October 01, 2012, 03:14:51 PM
I started reading the link Tony put up and one chap mentions "the Tickell book "  this turns out to be From the Fryer to the Fuel Tank.  I found it on Google books here ...
http://books.google.co.uk/books?id=5tpLc8w4Ed4C&source=gbs_book_other_versions
This is the 2003 version.  It's not a full version but reasonably complete.
The page thak mentions adding acid is here ...
http://books.google.co.uk/books?id=5tpLc8w4Ed4C&lpg=PA9&pg=PA71#v=onepage&q&f=false
I'm thinking ... could we have a page on the wiki for links such as this?  I can't see that we will have any copyright issues as, right or wrong, Google have already placed it in the public domain.
Post by: K.H on October 01, 2012, 04:58:00 PM
Depends if the info is current i suppose no point linking to out dated ones
Post by: Julian on October 01, 2012, 05:31:16 PM
Good point, but a while back I wanted to find out about the 3/27 test.  There was a post on the VOD stating that a cloudy result indicated MGs and DGs.
I'd not seen that before and spent a great deal of time looking for the earliest mention of the 3/27 test.  I eventually found that Jan Warnqvist emailed it to Biofuel mailing list in Aug 2005., and there was no mention of MGs and DGs.  When this was pointed out to the poster, he withdrew the comments.
In the light of the above, I think there possibly is merit in reproducing or linking to original material and to that end I've just stuck Jan's email on the wiki page under the topic References.  I can remove it if people think it's inappropriate.
Post by: K.H on October 01, 2012, 05:48:33 PM
Maybe put it under something like "archive"?,not sure?,something that would indicate that the some of content may be out of date?
And stop going off thread,thats my job!
Post by: Julian on October 01, 2012, 07:05:13 PM
And who appointed you as official OTT ... Off Topic Tosser?
I thought I was doing rather well with my Skype thread, that ran to 5 pages mainly on Discos.  I've got lots more to report, but it makes me look a bit of a Muppet, so I may not bother!
Oh, and maybe the info archive is not such a bad idea.
Post by: K.H on October 01, 2012, 08:56:39 PM
Where has Jules got to?,my process was basically following his first attempt but with a different acid,it wouldnt be fair for me to post it up before his
Post by: Julian on October 01, 2012, 09:00:10 PM
Oh, seems a shame to waste a thread if Jules isn't going to post ... shall I tell you about my Discovery instaed?
Post by: julesandtash on October 01, 2012, 09:23:08 PM
Hi,
I do apologise for not posting, I haven't been on here or VOD for a few days now as it's all been a bit manic here. I have barely had a spare waking moment for various reasons.
Anyway, I am back now.
I can vouch for this method working really well.  I have done three batches in this way now, with different feedstocks and have had perfect results every time.
I do the two stage no titration method with methylate to get a perfect 5/45 test. Then drain the second stage glycerol.
To titrate the bio I made up a titration fluid of 1ml of 96% sulphuric acid in 1 litre of water. The titration itself is carried out with 50ml of IPA with enough drops of Bromophenol blue in it to make it a visible blue colour.
I then drop in 1ml of the bio which, being alkaline, keeps the solution blue
Then, using a 0.5ml syringe, I drip in the 0.1% acid solution and keep stirring until the solution turns greenish yellow.
At that point it is really easy to calculate how much acid is needed.
If the titration took 0.75 ml of acid solution then the bio will need 0.75ml per litre to neutralise.
On a 100 litre batch that would be 75 ml of acid.
Clearly, adding 75ml of concentrated sulphuric acid would carbonise the bio it touched so firstly I mix the acid with the 7% batch volume of water as Paul suggests above.
*** Safety warning - ALWAYS add the acid to the water. NEVER add water to concentrated sulphuric acid as the exothermic reaction will cause the water to instantly boil and throw acid out of the mixing vessel ***
Then mix, stop and allow the water to settle.
The water that comes out is dirty and, with suplhuric acid at least, smelly.
After this, I do another wash with 20% batch volume of clear water. Only needs 10 to 20 mins of mixing then a short time to settle.
The water coming out is then almost crystal clear. I take a sample before switching off the pump so I can see it settle in a jar.
If the water is not crystal clear, I do another wash. So far I have not had to do more than two 20 minute washes to have sparkling clear water coming out.
Then it is just a case of drying, which I also do in the processor with a bubble ring and koi air pump. After that, the bio is ready to use.
Doing one of Nigel's soap tests shows 0 ppm of soap too.
Post by: Julian on October 01, 2012, 09:32:56 PM
Sounds good.  Maybe I'll try using some of my Sulphuric after all.
I'm guessing you have a bit of a head start over others with the Methylate.
Post by: julesandtash on October 01, 2012, 09:43:16 PM
I think the only thing Methylate brings to the party is potentially less soap in the bio due to the lack of water produced.
NaOH or KOH would work just as well except that slightly more acid may be needed.
Sulphuric acid is so cheap and you need to little that I suspect it may work out cheaper than vinegar.
I have given some acid and Bromophenol blue to Bob (Photoman290 on VOD) for him to have a go with in his new processor.
Using this method really reduces the amount of kit needed.
No need for a separate bubbling/settling tank and no need for a consdenser as there is no methanol to recover (the small amount left in the bio after draining the second stage glyc goes out with the wash water).
If you use pre-pump injection of methoxide then there is no real need for a venturi and, if you get the oil to full process temperature before it goes into the processor (using a boiler, electric overnight heating etc) then you dont even need and inline or in processor heater.
I get my oil to 70C at the start of the day. Then glyc wash, then two stage process then in processor water was by this method.
Even after two cold water washes the bio is still at 35C to 40C at the end of  the process with no extra heat added at any stage.
Post by: K.H on October 01, 2012, 09:44:26 PM
Im still on NaOH but it seems to work well,i wont say just as well as i haven't tested the soap PPM but i have got crystal clear water in the 50/50,i have got some acids here but thought i would try vinegar to differ from Jules,the processor seems already set up for this and now the wash tank will just be a drying tank,i suppose some will never get over the fear of adding water but i consider this a step forward
I await the "its been tried 5 years ago" with interest
Post by: Keef on October 01, 2012, 09:44:47 PM
Has anyone tried titrating the finished bio?
If the acid turns the soaps to FFAs, are you sure they are all washed out during the washes or have you got acid bio?
Just a thought.
Post by: K.H on October 01, 2012, 09:45:31 PM
Stone the blasphemer!
sorry couldnt resist
Post by: K.H on October 01, 2012, 09:46:09 PM
Just a thought.
Mine tested at 7.5
Post by: julesandtash on October 01, 2012, 09:49:52 PM
I take it that was a pH of 7.5 as opposed to a titration value of 7.5 (which would be quite seriously acidic).
Post by: K.H on October 01, 2012, 09:52:26 PM
Yes,sorry pH
I found this when hunting down the indicator,may be of some use
(http://i316.photobucket.com/albums/mm323/KRH01/186indicators_zps423a34de.jpg)
Post by: Julian on October 01, 2012, 09:53:38 PM
Can you measure the ph of Bio? I thought you could only measure the ph of water based liquids.
Post by: K.H on October 01, 2012, 09:55:06 PM
Used a couple of indicators to get a rough idea,not very scientific admittedly
Post by: mark230678 on October 01, 2012, 09:57:55 PM
Am watching this with interest, as my processor will be built over the weekend.( Hopefully )
I used to water wash (mist) about 4 the the volume of bio.
This sounds perfect.
Post by: K.H on October 01, 2012, 09:59:58 PM
Nice to see you on here Mark
Post by: mark230678 on October 01, 2012, 10:03:51 PM
Been lurking for a while.
Doing lots of reading again.
WIll be trying the Glyc Logs as well, now i have my woodburning stove in.....
Post by: Tony on October 01, 2012, 10:11:16 PM
Just a thought.
Ion exchange resin does a very similar thing - turn soaps to FFAs.  The ATSM standard allows little soap but plenty of FFAs, so it's a good way to get a pass.  But the joint study on injection equipment showed the FFAs were bad for corrosion:
http://www.biopowered.co.uk/wiki/Effect_of_biodiesel_on_fuel_injection_systems
"Corrosion of fuel injection equipment, Filter plugging, Sediments on parts"
Does water wash it away?  Don't know...
Post by: Carrington on October 02, 2012, 06:02:27 AM
Just a thought
Been thinking about what if the FFA's remains in the bio and how could it be a problem, do we know if they are a problem to the veg runners.
I'm sure the oil used in straight running is better than is used in most bio production but there must be a % if FFA's.
also FAME (fatty acid methyl ester) is just fatty acid with  methanol bonded to it so still being a fatty acid.
Just a hazy morning while I awake in the chair.
Post by: Tony on October 02, 2012, 06:26:26 AM
It's a good point - forgot that WVO users must have them in their fuel.  Maybe they should water wash too ;)
Post by: julesandtash on October 02, 2012, 07:51:11 AM
If you do everything you can to minimise the amount of soap in the biodiesel prior to adding the acid then the amount of FFAS in the finished fuel will be minimised.
Using dry oil, glycerol washing, sodium methylate and the two stage no titraion process all combine to minimise the soap (and, consequently, FFA) levels.
Certainly WVO users will have FFAs in their fuel. Even SVO user may end up with some since it is the repeated heating and cooling of oil that splits off the FFAs. Whilst the temperatures in a vehicle fuel system are not as high as a chip fryer, the oil is still be heated and cooled on a daily basis.
Post by: Tony on October 02, 2012, 08:04:23 AM
I thought that water had to be present for FFAs to split from the triglyceride with heat? (As provided by frozen chips added to a frier, for example).
Post by: K.H on October 02, 2012, 10:42:33 AM
I don know,I used two different indicators to get to 7.5 and the other half took a sample to the sci dept on Mon and there ph tester also said 7.5
What type of tester I don't know
Post by: mark230678 on October 02, 2012, 09:49:29 PM
Keith just out of interest.
What was your process with the vinegar.
I am sure it's similar, but vinegar is easier for me to get hold of
Post by: julesandtash on October 02, 2012, 10:42:10 PM
I promise that I will help Keith write up a Wiki page for this soon. It wont be until the weekend though as I can guarantee not to have any spare time until then.
If you can list your process using Vinegar Keith that would be good as we can put both on the Wiki,
Mine should work for whatever strong acid (Sulphuric, Phosphoric, Hydrochloric etc) that anyone wants to use (Nitric would, of course, not be recommended for obvious reasons).
Yours should work for all sorts of weak acids, presumably citric, acetic, tartaric etc
Post by: 1958steveflying on October 03, 2012, 12:33:44 AM
Probably easier for him to withdraw his comments than to try and validate them !
Post by: Rotary-Motion on October 03, 2012, 07:44:17 AM
i guess theres always fat in the oil i burn in the car cant get 100% out or maybe you could but for me not needed, dont chnage car fuel filters anymore and the cars done 1000's of miles,  i try get most gunge out in the shed filtering stages and water.
i only just done an engine oil/filter change after 2 years and 35,000 miles aswell, think most do it after 2 or 3 thoudsand miles to stop ring gumming, i guess this can be worse or better dependant on the engine type your useing?
the only fat buildup i have ever seen in a car fuel system is when it touches zinc or galvansied metal (fuel sender cover - pug 405) in fuel tank, also known of it in the gauze filter of the injection pump banjo (non HE heated system)
Post by: william crosby on October 04, 2012, 08:42:57 PM
this method sounds very interesting.where can i buy the acids needed to give this a got
thanks william
Post by: mark230678 on October 04, 2012, 08:49:45 PM
Think Keith was using vinegar with success, so down to local supermarket.
Post by: Carrington on October 04, 2012, 08:54:44 PM
With this system you can use any acidic liquid you just need to do the titration with the same solution.
Paul
Post by: nigelb on October 04, 2012, 09:26:36 PM
thanks william
If it's not too late William, Barry could supply you with any acid you like and put it on your pallet.
Nige
Post by: julesandtash on October 05, 2012, 08:12:14 AM
Paul
I would recommend not using nitric acid though - although the risks are absoutely minimal, it is not a good idea to mix nitric acid with organic materials, particularly glycerin.
Concentrated sulphuric is probably the cheapest option you could use.
As Carrington says, it doesn't really matter which acid (except Nitric - as above) that you use, you just need to make up a tiitration fluid with it so you can calculate how much you need to add to the batch. The weaker acids like vinegar will need much higher volumes that the stronger ones (although teh strong ones need diluting in water first before they are added).
Post by: Tony on October 05, 2012, 08:21:10 AM
I dunno about that, I added fuming Nitric and Sulphuric to mine and I've not seen any Glyc since!  (Or the shed, or the windows at the back of the house)  ;)
Post by: nigelb on October 05, 2012, 07:18:22 PM
This is one for keith really. With such a short wash cycle ie 2 washes...does this completely deplete the amount of methanol within the biodiesel. Have you used your alcohol tester to check on the percentage of methanol left behind.
Nige
Post by: K.H on October 05, 2012, 07:24:08 PM
Nige
I never gave that a thought Nigel,good thinking,i intend doing another batch tomorrow to double check my method so i will check the washes for methanol as well
Post by: Head Womble on October 05, 2012, 10:46:37 PM
What indicator do you use, I assume it's different to the turmeric I used to use for titration.
I was going to add a cone to thebottom of my settling tank so I could go back to water washing,
but I think I'll give this a go as it's less work, less time and less modifying of my system.
Post by: K.H on October 05, 2012, 10:52:38 PM
The Bromophenol from Nigels soap test kit
Post by: Carrington on October 05, 2012, 11:13:51 PM
Hi all
This system can also be used with the dry wash if anyone wants to give it a go.
When using this way with dry wash you add the acid first to neutralise then de-meth , the salt that's created is bigger than the residual alkali so will settle quickly , probably fast than the time to de-meth.
Any filter system used after should last a lot longer. This is something I did in the factory and it made it possible to get much more bio through the filters without changing.
Maybe I should keep stum about the dry wash
Paul
Post by: julianf on October 06, 2012, 11:25:06 AM
The main thing that's put me off water washing in the past was the energy required to then dry the bio.
Not that ive done calculations, but i felt that re-heating the bio from cold and then taking off the water must take more power than just keeping it hot at the end of the reaction to demeth.
It seems that this method may require so little water so as to be able to maintain the temperature to some degree.  Jules mentions this above.
Could this reduce the total energy consumption per batch then?
Somthing else i thought when reading through this thread -
Water washers have always mentioned lack of HMPEs as a bonus of water washing.  Its been hard to tie this down, but my own conclusion was that washing with cold water possibly allowed the HMPEs to come out of solution, and get removed with the water.
If this is the case, then maintaining the temperature with the low-volume water washes may remove this function?
Post by: K.H on October 06, 2012, 05:59:19 PM
I read Julians post while making a batch today so i took a sample from last weeks titrated wash,i used a higher % of water than Jules and it was cold water straight from the tap,i also never bother reheating at any stage after the initial 64C,not sure what Jules does so my bio may be at a lower temp.
Anyway i  stuck it in the deep freeze,below is the bio at -8
(http://i316.photobucket.com/albums/mm323/KRH01/Chrome003_zpsf367b1bf.jpg)
No sign of HMPE,s and when back to room temp still no sign
(http://i316.photobucket.com/albums/mm323/KRH01/Chrome004_zps697ef154.jpg)
Not conclusive i know but seems to be ok with my oil
Post by: julesandtash on October 06, 2012, 06:49:41 PM
Good stuff Keith.
I have a batch brewing right now - just waiting for the acid wash to settle then will be a couple of water washes then bubble overnight.
I use cold water straight from the tap. I could use hot water too as I have mains pressure hot water on tap in the processing area. Maybe I should try a batch with each.
Post by: Julian on October 06, 2012, 07:16:15 PM
Going to give this a go, but need to free up settling tanks to do it.
Any how, to refresh my rather poor memory, I just reread Jules's description on page two of this thread.
Jules, I was wondering if would it be prudent to add a warning where you twice talk about diluting concentrated sulphuric acid.  I was told that you should add the acid to the water and not the other way round.  I believe if you get it wrong you can get a violent reaction as the heat produced boils the acid.
Post by: K.H on October 07, 2012, 04:13:55 PM
Ok this is the method i used today,we tried universal indicator so we could tell when it changed to pH 7 as we wanted it neutral,we also tried methanol instead of IPA because the IPA we had was acidic
280 LITRE BATCH
(1) Titrate bio
(2) Titration fluid: white vinegar
(3) 25 ml of Methanol and some Universal Indicator,added 10 ml of bio shake, Green to Blue
(4) Then add the titration fluid in drips until the colour changes to green/yellow
(5) Multiply the result by the batch size to get the amount of acid needed
e.g. if 0.1ml vinegar used to change colour to neutralize 10ml bio, 10ml vinegar neutralizes 1L 10x280 = 2.8L vinegar
(6) Add to 30 litres of water and mix with the bio for 25 minutes
(7) Take sample for reference
Sample just taken
(http://i316.photobucket.com/albums/mm323/KRH01/1stsampleunsettled_zpsbe51c872.jpg)
Settled
(http://i316.photobucket.com/albums/mm323/KRH01/1stwashsettled_zps3b367b25.jpg)
( 8 ) Allow to settle for 1 hour,then drain the 30 litres
(9) Then add 30 litres of water and mix for 5 minutes
(10) Take reference sample
2nd wash settled
(http://i316.photobucket.com/albums/mm323/KRH01/2ndwashsettled_zps1d80904c.jpg)
50/50 of 2nd wash
(http://i316.photobucket.com/albums/mm323/KRH01/2ndwash5050_zps59f2f15b.jpg)
(11) Leave to settle for 15 minutes
I tested the raw bio for methanol as well,after the first wash i got a reading of around 300 ppm and after the second 100 ppm,so by the time i do the third and final wash it should around zero.
The cost of the vinegar for a 125 litre batch would be just under £2,how does that compare with sulphuric? (im sure vinegar can be got cheaper i had to buy Sarsons as it was the only one available)
Any comments on the method or use of "universal" and "methanol" ?
Post by: william crosby on October 07, 2012, 05:31:46 PM
hi Keith does it matter what type of vinegar used as i have just bought 5 Lt's from cosco for £2.05 and there is no vat but its not white vinegar
Post by: K.H on October 07, 2012, 05:48:58 PM
No it shouldn't make any difference,I Titrated with White so just bought the same,it was just what was here at the time
Post by: julesandtash on October 07, 2012, 06:13:30 PM
Julian, I will edit the post to add the warning - you are quite correct that adding water to the acid gets very exciting, it is very exothermic, boils the water instantly and throws sulphuric acid droplets around the place which try to eat anything they touch !!!!!
You are, of course, correct that one should slowly add the acid to the water.
Keith - good result and good writeup there. I like the idea of using universal indicator.
Sulphuric acid cost me £1 a litre from NigelB when I bought some. My last batch needed 1ml per litre so, in your 280litre batch, that would be 280ml or around 28p worth of acid so a considerable amount cheaper than vinegar.
Post by: Carrington on October 07, 2012, 10:09:46 PM
Hi jule's
Thank you for doing the hard work on this little project I'm glad it's working for everyone.
I do think that sulphuric is the best for this process but it's down to how people feel about storing strong acid at home. I remember thinking that 60L may be a bit much to have in the garage now I store it by the IBC's.
one foot note with regards to which acid's not to use. Hydraulic acid will corrode stainless steel and also give's of some nasty fumes and hydrfloric dissolves bones so equally less desirable
Paul
Post by: K.H on October 07, 2012, 10:30:59 PM
Yes i agree sulphuric is probably the way to go if you are happy handling it,the only reason i used vinegar was that me and Jules thought it made sense to use two different acids in the trials
Post by: Head Womble on October 07, 2012, 10:48:03 PM
Just a small note, when I ran a fish & chip shop many years ago we got the vinegar in a concentrated form and just mixed it with water ,
I can't remember what the % was but this may be a safer option for those that don't want to keep sulfuric acid around the place.
I'll see if I can find a supplier and price for it.
Post by: K.H on October 07, 2012, 10:50:10 PM
I noticed the bottles i used said 5% acidity,not sure what that means?
Post by: Carrington on October 08, 2012, 06:31:05 AM
Hi Kieth
Yes I agree that with two people doing test with different materials was the best way to showcase this system . Giving people the option of of a range of acids means they can work with a acid that they feel comfortable with rather than having to jump straight in with sulphuric.
Looking at your pic's I have carried on adding vinegar until the water separation was clearer before going on to the full water wash, but saying the amount you used still makes it possible to go straight to pump wash with no chance of emulsion and reduced the amount of following washes this being the main objective of the trials.
Paul
Post by: julesandtash on October 08, 2012, 07:36:19 AM
I'm going to try the next batch with 85% phosphoric acid.
There would be no real reason to do this as it is quite expensive (I got it at a bargain basement price and was still £2.50 a litre) but I have around 15 litres or so of it so I will give it a go
The processor is now in piece for a while so I can move it all and rebuild the bund for it in a better position.
Interestingly the bio/veg/glyc/water combination that had accumulated in the bund had seriously degraded the concrete blocks and mortar and was starting to leak out across the floor.
The new bund is going to be lined with 18mm OSB plywood then covered in fibreglass which seems to be immune to everything.
It's a good time to strip the processor back to the basic requirements needed for this method too.
Post by: julianf on October 08, 2012, 09:06:35 AM
I think its simply the strength.  As Mark says, not all vinegar is as potent / concentrated.
Asda does, i think 5 or 600 ml bottles of brown vinegar for about 8p a hit (or at least did when i wanted some last).  I doubt it is that strong (i dont have a bottle to hand to check) but i used a whole load of them once for stripping some rust, and they worked for that.
Depending on how the titration quantities work, that may be a convenient source of less scary acid, for not loads of money.
Incidentally, my first and last water washing attempt ended in emulsion - i had some of these left over then, and they split the emulsion well - i dont recall having to use that many of them?
Post by: Head Womble on October 08, 2012, 11:23:01 AM
Jules, I always find strip down and rebuild time very scary.
It's that need to get brewing again before you have to visit the tax station that makes me cut corners,
or at least get it up and running before everything is just how I planed it,
my shed is still not finished and I just don't seem to find the time.
Post by: julesandtash on October 08, 2012, 06:33:34 PM
Well the taking and insulation of the walls where the processor is going is done. The timberwork of the bund is all done with a 1:55 gradient from each end towards the middle where the is a 1.5" deep sump .
I went to get the 10 sq.m of fibreglass mat and resin today but didn't realise the place closed at 4:30  and I got there at 4:40! Will have to go get the fibreglass tomorrow.
Hopfully by the end of tomorrow the glassing will be done.
Then I just need to tile the area above the bund. Once that is done the processor can get moved in there. Once all of that is done I can get started on the new control panel and, after that, the boiler powered heating system for the oil heat tank
Post by: Julian on October 08, 2012, 06:48:34 PM
Jules, I think we need some photos ... this sounds like the mother of all processing systems! Next you'll be telling us you have a works canteen on site!
What about a mixing drum under the Glycerol drain for making Glogs on the hoof?  Thinking this might be a good addition if I ever get round to updating my set up.
Post by: julesandtash on October 08, 2012, 06:56:39 PM
I will take some photos. I do have running hot and cold mains water in the workshop, plus a dishwasher and soon to be a fridge out there
I am just fed up with the walls leaking (one end of the building is actually underground due to the slope of the site) and the floor getting oily so I am doing it properly.
Post by: K.H on October 08, 2012, 08:54:20 PM
Thats a better price than the sarsons i had to get.
It would take about 2 of the bottles (568 ml) to do a titrated wash on a 125 litre batch,how much do you think you used to split that emulsion roughly?
Post by: K.H on October 08, 2012, 08:56:50 PM
Nooooo thats the most enjoyable bit,i much prefer messing about with the processor as opposed to actually brewing a batch (unless theres something new to do) thats probably why im on No 4
Post by: K.H on October 08, 2012, 09:00:06 PM
I brought some Brick acid home today,9% Hydrochloric, so i will test that next,at that strength its a sort of happy medium and easy enough to obtain
Post by: julianf on October 08, 2012, 09:24:47 PM
It was so long ago that any number i came up with would just be a guess.
What i do recall is that i had this thick emulsion that i then split with the vinegar.  I then thought 'phew', did a 50/50 which was almost clear, but i thought id do a final water wash, just to be sure.
...and the whole thing happened over again (not quite as bad though).  I didnt know why, as the 50/50 wasnt bad? (but that was the end of water washing for me)
In essex we had pretty hard water, moderately alkaline - as i recall from chemistry a-level, hard water forms a precipitate with soap, whilst soft water doesn't (?)
That must, im sure, have some relevance?
Post by: K.H on October 08, 2012, 09:31:08 PM
I know that Nigel took water samples from a few of us at last years BBB to test if the differing hardness affected 50/50,s which it did,i think that was one reason he came up with the soap test kits.
Im sat on limestone so our water is very hard
Post by: julianf on October 08, 2012, 09:32:36 PM
I assume this was the vinegar i used -
(http://i1-groceries.asda.com/g/084/201/21084201_21000_IDShot_2.jpeg)
http://groceries.asda.com/asda-estore/catalog/sectionpagecontainer.jsp?skuId=36648&departmentid=1214921923813&aisleid=1214921925507&startValue=
...but its more money now, a2 29.9p/ltr
Its coming back now - morrisons did/do the same (same bottle, different label, same price), but, at the time, they were certainly under 10p per bottle.
Post by: Head Womble on October 08, 2012, 09:54:53 PM
I'm with you on that one, I look forward to tinkering time,
At one stage my setup was modified allmost every week.
Post by: julesandtash on October 09, 2012, 07:48:28 AM
And I am sat on granite so our water is super soft yet we both have success with this washing method.
Post by: julesandtash on October 09, 2012, 03:44:32 PM
Well the fibreglassing is done - what I thought would be an easy job turned out not to be - I have never glassed a big area before and gained a lot of experience along the way - had I known at the start what I did at the end, I would have done a few things differently.
Post by: Tony on October 09, 2012, 03:50:03 PM
Sounds like an epic adventure.  I've never glassed a large area before - any tips?  And more importantly, any photos?
Post by: julesandtash on October 09, 2012, 04:06:13 PM
I would cut the matting into two foot squares with what I know now. I ddn't do that and had a lot of troubles trying to work with a 10 metre long 1 metre wide roll - I was surprised how fragile chopped strand matting is.
Also, polyester resin tends to burn the skin after dissolving cheap surgical gloves and sticks like **** to a blanket.
I will upload some photos once the bund is all done.
Post by: hifly on October 09, 2012, 07:13:36 PM
very interesting,
i have noticed that no one has mentioned blanking the ipa/methanol befoer adding the bio, would it not be a good idea to get an accurate result?
Post by: nigelb on October 09, 2012, 07:32:39 PM
The results of the tests I performed were far from conclusive. So many variables and surprisingly difficult to replicate.
The titrated soap test is by far the best indicator of soap in biodiesel.
If you want a kit Julianf give me a shout.
Nige
Post by: julesandtash on October 09, 2012, 07:39:24 PM
very interesting,
Good point - none of mine has been acidic enough to need blanking and has always been blue when adding the bromophenol blue. It it was green or, heaven forbid, yellow, then there would be a need to blank it.
Post by: hifly on October 09, 2012, 07:44:01 PM
just think it would be worth adding a line or two to any guide for the process as some may not understand the need to blank now most people don't do titrations when making thier bio.
Post by: K.H on October 09, 2012, 07:48:37 PM
As we used universal indicator it proved our methanol to be neutral before we added bio
Post by: Head Womble on October 09, 2012, 07:51:16 PM
The first bit of advice I would give for anyone fiberglassing a large area is use woven matting,
far easier to work with but probably more expensive to buy.
Oh and use marigold gloves.
Post by: hifly on October 09, 2012, 08:03:17 PM
yes but you still need to tell people that if its not green to start with add some titration solution until it is, thats all i'm saying, just think how confused people got when titrating wvo.
Post by: K.H on October 09, 2012, 08:09:36 PM
OK i get where your coming from  :) ,me and Jules have yet to start on a wiki page for this so we will make sure its included.
Post by: Julian on October 15, 2012, 08:45:06 PM
                                             We're liking this method!
Post by: julesandtash on October 15, 2012, 08:58:36 PM
I take it that you are a fan then Julian.
I never thought I would step back into the water washers corner but I am firmly there now thanks to this method.
Post by: Tony on October 15, 2012, 09:06:02 PM
Julian. To think I respected your stand against smilies - and here you are with huge (blue!) scrolling text - it's like walking in on an AA meeting to see empty vodka bottles scattered around the place - I don't know what to think!
Post by: Julian on October 15, 2012, 09:13:21 PM
Bit of a late night last night trying to get my head around this method ... minor discrepancies earlier in the post!
I had a bash using concentrated Sulphuric acid and so far it's looking very promising.  I used acid ten times stronger that Jules for the titration, but I think I got the sums right (appreciate someone smarter than me checking them over)
I diluted 98% sulphuric to a 1% solution and used that for the titration. This gave a figure of 0.12ml to neutralise 1ml of Bio.
Therefore 0.12 litres per litre. So, for an 80 litre batch I'd need 0.12×80 = 9.6 litres.  As I diluted the acid 100:1, I'd need one hundredth of this which is 96ml of concentrated acid.
No emulsions and the wash water isn't quite as clear as it might be.  I've done three washes so far, but only 5 litres each time for an 80 litre batch.  Wash water has a distinctly yellow tint to it, so Id guess I'm using too little water and running the pump for to long ... one sample has bio accumulating on top of the water.
Just doing one last wash with 10 litres and I'll dry the batch tomorrow.
So far very impressed.
PS. Keith ... I saw the comment you deleted!!!
PS. Tony ... You certainly won't see this sort of frivolity form me often!
Post by: K.H on October 15, 2012, 09:34:43 PM
The blue text doesn't show on my phone but shows up as normal writing if I quote it
Post by: Head Womble on October 15, 2012, 09:45:38 PM
Hopefully my soap test kit will turn up tomorrow and I can join in the fun.
I'm looking forward to trying this.
Post by: 1958steveflying on October 15, 2012, 10:08:57 PM
Hoping to do a batch this week so I will be trying it too.. can't wait as I have not water washed in over 4 years but think this method will bring it back.
Post by: julesandtash on October 15, 2012, 10:38:05 PM
Julian, very sorry for the slight confusion re the titration fluid.
My fluid is 1ml of acid mixed with 999ml of water to give a 0.1% solution.
I do my titrations now with 10m of biodiesel and slowly drop in the acid. That makes it easier to see the change point.
On my last batch it took 4.5ml of the titration fluid to change the 10ml of bio from blue to the greenish yellow change point.
That works out at 0.45ml per litre.
Trying to do them with just 1ml of the biodiesel and then needing only around 0.5ml of titration fluid is more awkward and gives more chance of errors in reading.
The whole batch was 300 litres so a total of 135ml of acid (pretty low soap concentration to start with - I was quite pleased with that)
I put that acid into 20 litres of water for the acid wash and ran for 20mins then settled for an hour. After draining I did two water washes of 60 litres each in 300 litres of bio. The first had a yellowish hue but the second didn't
Post by: Head Womble on October 15, 2012, 10:45:27 PM
Is there a wiki page for this yet, I've had a quick look but can't see one.
Post by: julesandtash on October 15, 2012, 10:49:16 PM
No - it seemed best to iron out the wrinkles first then write a definitve guide. This was also why Keith and I thought it best to debut it here rather than on VOD as there is less of a 'it'll never work' culture on here.
Hopefully there will be one soon though.
Post by: Carrington on October 15, 2012, 11:01:27 PM
Hi guys
Glad every one is getting one well with the system. Just one thought if anyone would like to try something , a calc I used to use when working with 96% sulphuric was batch size * 0.5% acid, this was before I could titrate the soap and it generally worked but we are talking along time ago so maybe could be a bit out as me and notes don't really get on.
Ps big thanks to Steveflying for helping me with head gasket on truck last week.
Paul
As pointed out below by jule's that it should be 0.05%
Post by: julesandtash on October 15, 2012, 11:13:32 PM
0.5% acid by volume sounds a lot - that would be 500ml on a 100 litre batch - 1500ml on a 300 litre batch.
That  is ten times what I used on my last batch - 0.05% would be much closer.
Post by: Carrington on October 15, 2012, 11:17:27 PM
Sorry that sounds better I will edit my last post , been a long few days and again I have no notes so just going on memory
Post by: Julian on October 16, 2012, 03:35:26 PM
My first effort is drying in the processor.  I'll do a Nige soap test once cooled.
Meantime here are a couple of photos taken this afternoon ...
This is a sample taken during the first wash with the acid solution.  Some 24hrs on the Bio has started to dry at the top of the jar, and not clear from the photo, the water is very clear.
(http://www.biopowered.co.uk/w/images/1/19/Soap_neutralisation_washing_sample_during_first_wash.JPG)
These are samples taken from the first 4 washes whilst draining the water.
(http://www.biopowered.co.uk/w/images/1/1a/Soap_neutralisation_washing_wash_waster_first_4_washes.JPG)
I've uploaded the photos to the wiki if you (Jules and Keith) want to use them in the wiki page, feel free.
Post by: julesandtash on October 16, 2012, 04:39:55 PM
Nice result - well done. If you do leave jars of the wet bio to breathe they all start to clear from the top like that.
Post by: Julian on October 16, 2012, 04:47:11 PM
I'm gobsmacked at the volume of water this method has put into the bio ... so far I've got about 4 litres out of an 80 litre batch!
Way more than I get when mist washing.
Post by: Head Womble on October 16, 2012, 05:19:49 PM
Are you condensing it off Julian?
Post by: Julian on October 16, 2012, 05:51:53 PM
Yes, but I'll also be loosing some to atmosphere as I'm bubbling with a small compressor.
Post by: Head Womble on October 16, 2012, 05:58:59 PM
I guess the pump really mashes the bio and water together,
whereas mist washing is far more gentle.
Post by: Julian on October 16, 2012, 06:24:19 PM
You're probably right, however I've just looked again and I'll revise my estimate to 3 litres, but it still seems a hell of a lot to me.
If this is typical, then final drying with this method is quite important.  I've just dumped the batch into the barrel formally known as mist washing barrel at 67°C and I'll bubble overnight.
Post by: Tony on October 16, 2012, 06:44:27 PM
Well that ain't gonna get it dry is it - suggest bubbling the bio instead ;)
Post by: julesandtash on October 16, 2012, 08:19:02 PM
If you leave it a decent amount of time, quite a lot of that water will drop out. I have left it overnight after the second wash and then drained the water in the morning before drying.
Bubble drying with the Koi pump or running the processor with the venturi sucking air from the outside world and with the big four inch vents on the top of the processor does a good job
Post by: Head Womble on October 16, 2012, 08:22:41 PM
I got a batch done today and the gly is settling at the mo.
I'll do the water wash tomorrow as I don't fancy starting it this late in the day, plus I haven't got any acid yet.
What's the most commercially available and economic acid we can use.
Post by: julesandtash on October 16, 2012, 08:26:51 PM
Concentrated Sulphuric is pretty much the cheapest - Vinegar is probably the most commonly available.
Post by: Head Womble on October 16, 2012, 08:58:05 PM
How about something like this
http://www.ebay.co.uk/itm/HIGH-STRENGTH-BRICK-ACID-BASED-CLEANER-REMOVING-CEMENT-AND-MORTAR-SPLASHES-TILES-/140856804762?pt=LH_DefaultDomain_3&hash=item20cbb8459a
it's 18% hydrochloric acid.
Post by: Tony on October 16, 2012, 09:11:10 PM
That's not bad - even with the postage it's cheaper than the Wickes stuff (and stronger!)
Post by: photoman290 on October 17, 2012, 01:07:39 AM
remember. the max concentration of hcl you get is 34% above that it it is fuming hcl. H2So4 is 96% or 98% fuming.
Post by: Julian on October 17, 2012, 08:12:47 AM
Mine wasn't.  Don't know, is there is such a thing as fuming Sulphuric acid?
Post by: photoman290 on October 17, 2012, 10:43:27 AM
there is but  its not normally sold as such.
http://en.wikipedia.org/wiki/Sulfuric_acid#Grades_of_sulfuric_acid
soory if i sound like i know what i am talking about. chemistry is not my best subject. wish i knew more about it. all the chemists i know are weirder than me. :D
Post by: Glycer-rides on October 17, 2012, 11:02:17 AM
Pool chems seem to be well priced.
25L of 28% HCL for 30 quid in Farborough, http://www.onlinepoolstore.co.uk/hydrochloric-acid-28---25-litres-31-p.asp
Post by: Head Womble on October 17, 2012, 11:23:16 AM
I've just brought some of this
http://www.amazon.co.uk/Amokleen-Spirits-of-Salt-500ml/dp/B002SP7I0K/ref=sr_1_2?ie=UTF8&qid=1350469230&sr=8-2
but the 5L which is stronger (32% hydrochloric acid), it was £17.70 but I should get quite a few batches from it.
Carl (etz250 on the VOD) can get 98% sulfuric acid at a good price so I'll get him to pick me up some soon.
Settling the first wash now and the sample looks good with no emulsion, all good so far.
Post by: Carrington on October 17, 2012, 02:22:45 PM
Hi all
Just a quick look in between running round like a headless chicken.
Looking at Julian's pick with a bit of fine tuning you should be able to get your water in the second jar to settle clear meaning 1acid wash and 1clean water wash, this will reduce the moisture left in the bio and should mean that the bio is still hot ready for drying.
With regards to hydrchloric acid is does attack stainless steel but I'm not sure as to the strength it would need to be but also heat make the attack stronger ( just a thought ).
Sorry I haven't been much help on this thread but trucks down and life's gone crazy but I'm on the phone if anyone want's to chat about it all
Cheers
Paul
Post by: photoman290 on October 17, 2012, 03:01:10 PM
RE: acid and stainless steel. the person who does know about this is bertle. not sure if he is a member here.
Post by: Head Womble on October 17, 2012, 04:25:00 PM
I've just finished a third wash (probably could have got away with two but I know it was a soapy batch).
Soap test result was 30.4  ;D (sorry Julian)
So to recap it was a 180L batch,
two stage non titration,
WBD,
Titration was 1.4, so 252ml of 32% hydrochloric acid added,
three washes,
it's now condensing off the water.
As long as I don't get HMPE's I'll be doing it this way from now on, it's just so easy.
No stainless steel in my plant.
Thanks guys.
Post by: Rob-b on October 17, 2012, 04:30:46 PM
Been reading this with intrigue, i've done this ever since I have been doing bio but went off the guideline of this guy http://www.youtube.com/watch?v=lHgCm8QHG_Y , he works on 22ml per 100l of bio regardless of soaps and have to say have been getting the same results as this for some two years with nice clear washes and no emulsions.
My question is, what is the PH after you have washed? I need to wash at least 5/6 times with 20 litres of water each time in 180 litres of biodiesel to reach a PH of 7 ish, interesting to hear how many times you guys need to wash?
I always finish off with a stone cold wash with a watering can and rose without the pump, and leave for two or three days which seems to drag HMPE's out also, then I dry. It would just be nice to get a system that is much quicker and this sounds great if it can be achieved with titrating the soaps first and using the correct amount of acid.
I am just concerned that the amounts that are being used are too much and the same result can be acieved with less, as it can't be too friendly to car components with a high acid content if not fully washed out.
Post by: K.H on October 17, 2012, 07:06:09 PM
I tested mine (page 2 of this thread) as best i could and got a pH of 7.5 but i was using vinegar
Post by: Julian on October 17, 2012, 07:18:17 PM
Been trying to get my head round pH of Biodiesel.  Had a long chat with a mate who's a PhD in chemistry, last night down the pub.
He says sticking litmus paper, indicator solution or a pH meter into bio won't work.  I ask what happens when we titrate and apparently adding IPA allows the pH to be measured.  He started explaining about releasing Hydrogen ions, allowing the pH to be measured and completely lost me.  The one stipulation he made was that there must be sufficient IPA to allow release of all the hydrogen ions.  When I asked how much is sufficient he didn't know.
I've just tried 5ml of the acid neutralised batch and 5 ml from a normal batch pre washing, neat and with 5, 10 and 15ml of IPA.
The acid neutralised batch showed no change to the colour of the litmus paper in any of the 4 tests.
The pre-wash, normal batch showed signs of being slightly alkaline when the neat sample was tested (did it twice to be sure) and no change with the three volumes of IPA.
I'd like to believe the tests, but I'm highly suspicious of the results.
Post by: Julian on October 17, 2012, 07:59:47 PM
Just spent half and hour Googling "testing pH of biodiesel".  Just about every result showed a direct test with either litmus paper or a pH meter.
Very confused (situation normal ... thought I'd get that in before anyone else).  Does anyone have a factual explanation as to why this works?
Wonder if testing a wet sample of bio during washing would produce a valid result?
Post by: K.H on October 17, 2012, 08:08:16 PM
If you cant test the bio,which is how i also understand it,what about testing the washwater?,maybe comparing it to a different wash methods water?
Post by: Julian on October 17, 2012, 08:12:47 PM
Just found this on the VOD, not by using the VOD search, but via Google ...
http://www.vegetableoildiesel.co.uk/forum/viewthread.php?tid=3251
Post by: Rob-b on October 17, 2012, 08:26:51 PM
Well, I was under the impression that you shake up your wet fuel and test with litmus, now I've always wondered about this because as your bio gets cleaner surely you are effectively testing the water that comes out of the tap and if you have soft water it is already acidic and vice verse.
So I just test the tap water and when the wash water becomes the same in the litmus test, then I have washed the acid out.
Post by: Rob-b on October 17, 2012, 08:27:24 PM
Just a follow up, how do you test KH?
Post by: K.H on October 17, 2012, 08:51:16 PM
Used universal indicator and it showed it not far off neutral,im not saying this method worked,just what result i got  :)
Post by: Carrington on October 17, 2012, 10:04:07 PM
This is my take on the ph of bio
Veg oil and bio can't take on acid or base , this is one of the reasons we mix base with meth before mixing with the wvo. So any chemical that isn't spent in the reaction is left floating around in between all oil/bio molecule's . So when we do a 50/50 test the water washes out any remaining chem's or if we de-meth the they sink to the Bottom of the tank.
So my take is the bio is by its nature ph neutral and only the impurities left behind can give it any other ph reading and this is done by 50/50 test and then testing the water.
One example I can give is if I esterifiy oil the run tests the sample that get put through the centrifuge with be less acidic than the sample tested straight away.
Gona stop waffling now
Maybe this is just obviouse or it will help with some understanding or maybe I'm completely wrong and will get put straight
Paul
Post by: 1958steveflying on October 18, 2012, 05:47:40 AM
Completed a batch yesterday which Paul then came by and helped to treat with acid, he picked up some vinegar from my local chippie, it was a concentrate at 16x strength !
We didn't have the means to titrate with us so tested a couple of samples and then the batch. It now sits waiting for the acid to be dropped until Friday which is the earliest i can get back to it.
It is handy that I can do this without worrying about blocked pipes etc.  Cheers Paul.
Post by: Head Womble on October 18, 2012, 01:10:35 PM
Quick update,
I filled the wife's car this morning as it was almost empty,
I hadn't told her what I had done ie. water wasting,
she's just got in and said the cars running really well with more power than normal.
I'm going to run mine down quite low, fill it up and see what the merc goes like with this batch.
Anyone got any ideas as to why water washing would have had this effect ?
Post by: Rob-b on October 18, 2012, 02:10:34 PM
Maybe you've never really settled soaps right out? I wouldn't know the difference i've always washed, maybe your wife just thinks it is because you have changed something and she is humouring you LOL.
 On the last batch though I upped my dosage of cold flow and veggie boost and have noticed quite a difference. I would normally put in 350ml per 180 litre batch, I upped it to 500ml each and motor runs really well, better acceleration, economy the works.
Post by: Head Womble on October 18, 2012, 02:42:16 PM
I've had my soaps tested by Nige at 60ppm (I know that was only one batch but it gives me an idea of what's going on).
My wife had no idea what I was doing in the shed, she doesn't listen to me if I do tell her.
I don't use any winteriser/additives, only RUG when it gets really cold.
Post by: Tony on October 18, 2012, 02:48:58 PM
What do acid neutralised soaps become, chemically?
Is it the same as converting soap to FFAs by using ion exchange resin?
Post by: Head Womble on October 18, 2012, 03:12:15 PM
The same thing had crossed my mind Tony,
although we're only adding enough to neutralise the bio we don't know what chemical effect it's having.
Post by: Tony on October 18, 2012, 03:51:15 PM
One site suggested that FFAs would wash out with water (which I'm not sure about, as they're not water soluble, are they)?
I think we need Carrington's knowledge here!
Post by: Carrington on October 18, 2012, 06:04:10 PM
Hi all again this is only my take on it.
Fame = fatty acid methyel ester
So if you if you have an FFA it's a fatty acid without the methanol bonded to it.
Some well respected members of VOD are adamant that FFA's are very hydroscopic so this would leave me to believe that they would get washed out with water.
But if you where to do a 2 stage no tit batch and produced very few soaps, with the neutralisation stage you should only be cleaning up excess base chem's and not converting soaps back to FFA's.
but if you did get some and they didn't all wash out would it be a problem.
I don't think it would as the fatty acid makes up most of biodiesel anyway.
Remember en 14214 only requires 96.5% methel ester conversion so if you get a complete pass on your 90/10 test and 3.5% is FFA I feel this would be better than no FFA but 3.5% of mono, die and try glycerides.
Again this is only my opinion I will let everyone come to their own conclusion but i would be interested to hear what people think even if what I just wrote makes no sence at all
Cheers
Paul
Remember with this process you are only really looking to neutralise any excess base chemicals that could cause soap formation when adding water as the excess soap formed can lead to emulsion when water is added with too much agitation.
Post by: photoman290 on October 18, 2012, 07:21:57 PM
when i was involved in the cambridge university  project there was a lot of different tests done on bio. the results should still be on there server somewhere.  the project leader was andrew harvey. the work was done at chemical engineering under Malcolm mackley. it was about 12 years ago but there should be some results somewhere. andrew harvey is now at newcasle doing research into algal oil production. not sure if he  still has any stuff from when he was at Cambridge ,but might be worth a try. i don't know enough about the chemistry to interpret any findings  but there might be something there worth digging for.
Post by: Tony on October 18, 2012, 07:37:36 PM
Ah I think I missed that important bit of info!  Thanks for the explainations.
Post by: Julian on October 18, 2012, 08:25:07 PM
I was under the impression we were neutralising soap, along with any residual catalyst.
I will already have soap in my bio due to the water generated mixing the catalyst and Methanol.
Surely the soap is alkaline and the addition of acid must neutralise it.
On the Biodiesel pH issue, Paul's description seems to fit the little tests I did.  It was only the unwashed bio that gave any change on the litmus paper, so it could be testing the impurities and not the bio.
Post by: Carrington on October 18, 2012, 09:25:42 PM
Hi Julian
Yes you will get some soap produced in production but if your oil is dry these should be minimal and yes they would revert back to FFA's.
when you are doing a soap test you are mainly testing for the potential of soap if mixed with water due to excess chem's
The good thing about ASM is no water produced in mixing so minimising any soap formation but still requiring excess chem's to be neutralised so when water added no soap production.
Paul
Post by: Head Womble on October 19, 2012, 10:31:29 PM
What would happen if too much acid was added ?
I ask as when I did my titration I added 12ml of bio not 1ml (I'd written it down wrong, silly I know).
So effectively I must have used 12 x the amount necessary.
Now this fuel is in both my cars, the wife's is running really well (I can confirm this myself),
but mine is running badly, at first I thought it was the filter but after changing it it's no better.
Post by: julesandtash on October 20, 2012, 07:52:00 AM
I suspect that the excess acid will have ended up in the wash water but I dont know for sure. Maybe Carrington can advise on that one?
It seems strange that one car is running well and one badly - if there was an issue with the fuel you would expect both to run badly.
Post by: Julian on October 20, 2012, 11:06:27 AM
I'd tend to agree with Jules, I think the acid is likely to be removed in the wash water ... how many washes did you do?
Also if the pH of bio tests any contaminants remaining in the bio, then a test with litmus paper may indicate if there's any excess acid remaining.
Post by: Carrington on October 20, 2012, 12:29:34 PM
Mark can you give me a ring I think I have a reason why your motors are running different but it would be a lot of typing to explaine and would like to make sure before posting
Paul
If I'm correct I will post all info up
07796297844
Post by: Julian on October 20, 2012, 12:48:25 PM
Another point to factor in is that Mark maintains both these vehicles!
Post by: Head Womble on October 20, 2012, 07:05:15 PM
The bio had three washes, one 10 % and two 20%.  final wash ended with a soap content of 30.4.
Yes I maintain both cars, to a, well, to my standards.
Post by: Head Womble on October 20, 2012, 09:18:21 PM
I've spoken to Paul (Carrington) this evening (thanks mate) and things are looking clearer,
I'll leave him to spill the beans as I've a feeling he'll explain thing better than me.
Post by: Carrington on October 21, 2012, 05:49:51 PM
Hi all
Having spoken to Mark I think he's going to be ok as he did several water washes after over dosing so should have washed the acid out. As for different proforming vehicle's I think that by overdosing on hydrachloric by so much he may have broken the methyel ester bond leaving him with FFA's or depending on temp and agitation and how much free glycerine was in the bio at the time he could many have produced some mono's or diglycerides ( not sure about this but will be doing some tests soon along side testing a theory on hmpe's ).
If anyone get's hmpe's can you please save me them as I think I may be able to prevent them in the wbd system but need different sorts to get some proper results.
Cheers
Paul
Post by: Julian on October 21, 2012, 07:43:24 PM
Hi all
Cheers
Paul
All sounds most interesting, so do you have a test for mono and diglycerides?
If you can find a cure for HMPEs, your name deserves to go into the home brewers book of heros, along side GL!
All my HMPEs are yours as and when they appear.
Post by: Head Womble on October 28, 2012, 07:28:12 PM
A quick update on my car, I added 0.5 % acetone )premixed in some bio) to my car and it made no difference at all to start with.
However the more I drove it the better it ran.
Ive now used all the fuel that was in the car and fulled it with my latest batch (my second acid titration water wash) and it's now running better than ever.
Post by: Stumpy on October 28, 2012, 08:35:30 PM
Cant wait to get my "new" improved mk5 processor up and running to try this method, especially with winter nearly here and dreaded HMPE`s
BIG BIG THANKS to everyone who`s done the testing and trials keep up the great work  8)
Post by: Carrington on October 28, 2012, 09:50:52 PM
Hi mark
Glad to hear that the cars running well and you have had more success with the second go at titrated water wash
Post by: nathanrobo on November 02, 2012, 09:32:03 PM
I've always been very nervous of pump washing but tried Paul's method on the last couple of batches.  I didn't titrate though, just added vinegar a bottle at a time, mixing well and taking a sample to do a water shake up test in a clear jar.  As soon as I get a sample that doesn't cloud, I pump from the processor into the wash tank, wash with 10 litres or so, followed by a small mist wash, shake up test again and then dry.
It's working really well!  I'm saving so much time & energy :-)  It's a bit like two stage  - all win - no downsides!
Post by: nigelb on November 03, 2012, 07:46:06 AM
I've not yet had a go at this particular method as I've been having some rather odd and satisfying results with my water washing since using ASM. For some reason I can gently bubble wash my 150lts of Bio with just three 10lt washes over 36hrs without adding any additional chemicals. I then perform a hot pump wash and dry.
If things change I'll have a good read through this information and give it a go.
Nige
Title: Re: In processor titrated water wash method
Post by: nathanrobo on November 03, 2012, 06:33:02 PM
From what I understand from Carrington, it's the chemistry that's important when neutralising with acid.
Post by: Julian on November 03, 2012, 08:02:43 PM
An update on the batch I ran ...
Both the PD Golf and the Disco have run fine on the batch (as fine as the Disco ever runs!), but in making a comparison between this batch after about a week settling, and the previous batch which was water washed, this batch was still quite cloudy.  I' now have a DSS sitting outside, and I'll keep a close eye on it over the next week or so.
Post by: Chug on November 04, 2012, 05:34:07 PM
right chaps, I've been trying too keep up on this thread even though I'm more than happy with my method and not thinking of changing, but as ever just trying to simplify/clarify things
But ifn we assume folks have done a reasonable conversion and haven't used to much catalyst you should be able to work out some rough guidelines for amounts of acid per litre to neutralise the soaps created from good oil thyrough to bad oil?
And assuming someone did use a little too much would that cause any major problems, except needing more water to remove?
EDIT: just read Nathans post it's where I'm leaning
Post by: 1958steveflying on November 04, 2012, 06:14:52 PM
My first and only batch so far Paul came to me with vinegar, we did a trial and error addition of the vinegar on samples and then an amount added to the batch with some water, pumped and left overnight. The vinegar was dropped and with this 180 litre batch I used 5 x 25 litre pumped water washes,  the water was still coming out slightly milky. Each 25 litre was left at least 12 hrs before being dropped. It was then left for a few days as I was away and then dried.
 Paul tested a sample for soap and water content which both came out perfect, however it was acidic, Ph 4.2 I think it was which he then titrated and came out at 0.8. Based on the theory that Wvo users would use oil that could titrate up to 10 or so It has just been added to around 80 litres of the previous batch.
2 questions spring to mind 1, if too much vinegar was used why was the water still milky ? all the soap should have been well gone ! . . .  2, why did 125 litres of water not neutralise the acid and balance the Ph of the Bio ?
Thoughts ?
The next batch we are going to be more scientific using Sulphuric.
Post by: Chug on November 04, 2012, 06:23:28 PM
I'll see If I can find any of the discussions on neutralizing the remaining catalyst from push n pull processor and my early wbd trials,  some folks in US still do it before they wbd as standard as they got used to it from their push n pull days
looking for more on this and remembering it used titration of the whole batch with phenolpthalein for accuracy over sample titrations and added HCL acid until colour change on whole batch,  I'll have to find it now as it's got me head going.
Post by: Tony on November 04, 2012, 06:42:58 PM
I'd be very interested in that Chug.
Post by: 1958steveflying on November 04, 2012, 07:04:05 PM
Me too.
Post by: Chug on November 04, 2012, 07:08:02 PM
searching through old stuff I've found it was 34% concentrate HCL and my notes say approx 100ml per 100 litre batch but gotta go have a sarnie or summit so I'll be back on the case in a bit
Post by: Chug on November 04, 2012, 08:22:57 PM
Right I've found some info posted by GL, obviously it was for neutralizing catalyst before demething the whole batch, but it should neutralise soap and instead of demething you guys will then just drain glyc and water wash instead, or maybe even experiment and try water wash with all the glyc in, obviously no good if you need it for glycwashing though
Hi GM
As Nick mentioned, the viscosity rises dramatically as methanol concentration in the glycerol drops, so the venturi fails to operate if using glycerol alone..
So here's an interesting twist, which works well, I have had no issues with back reaction as far as I can tell, and no problems with foaming....
After reaction, keep the pump running and do NOT drain the glycerol, and do NOT do 5% prewash,.
Instead, add a 1/2 teaspoon of phenolphthalein powder per 100 litres batch and allow to mix thoroughly. You'll need a sight tube to view the mixture. A narrow clear branched tube, off the outlet of the pump is safest - you want to be able to instantly see the colour change, so the tube must carry some of the pump outlet flow thru it.
Very slowly (I mean VERY SLOWLY) dose 34% conc. HCl into the inlet of the pump and note the colour change. When you get to about 0.1% dosed volume, you'll see the deep red will lighten up a bit.
STOP adding HCL at this point.
The colour will darken again in a few minutes, DON'T add any more HCl or you will start to make FFA from the soap. The lye will preferentially neutralise first with the HCL, then the soap.
The NaOH or KOH should mostly be neutralised now, making it an ineffective catalyst for what follows...
Add heat to the whole batch and start distilling off the methanol, you'll need to go up to 90C or more.
When this becomes a trickle, stop.
The glycerol will drop out within a matter of seconds when you stop the pump, drain it before it cools and solidifies.
Then drain off the remaining biodiesel into a settling tank to allow soap to drop out, or you can wash it gently as is - it should wash fairly easily if you treat it gently for the first one.
Key things
1. Use a pump which can deal with the viscosity.
2. Don't OD on HCL.
3. Don't dose HCL too fast, or you'll make FFAs
For a 100 litre batch, you'll use around 100ml HCL, depending on titration, amount of lye, water in oil etc.
My pump is roughly 1/2 batch volume per minute.
Dose the HCL at a rate which will take around 30 minutes to complete, at the inlet of your pump so it mixes well.
This is info to the best of my knowledge to date - there is a lot still to learn and much can be done to improve the process, but it is showing good promise as a simple, fast efficient way to recover methanol from the whole batch and aid washing or eliminate the use of water.
Post by: Tony on November 04, 2012, 08:44:47 PM
Best bet for WBD is to use 96% Sulphuric (which I'm currently trying to find at a reasonable price) and then titrate for neutralisation before demething.  Adding water in any form sounds like a bad plan for recovered Methanol quality. Question is how to titrate bio+glyc?
Post by: nigelb on November 04, 2012, 09:02:35 PM
What's the best price you've had for the Sulphuric Tony?
Nige
Post by: Tony on November 04, 2012, 09:04:22 PM
So far this one:
http://www.bonnymans.co.uk/products/product.php?productID=6398
Post by: Carrington on November 04, 2012, 09:10:31 PM
I haven't tried to titrate bio and Glyc yet but I would assume that taking a sample while the batch is mixing then  drawing 1 ml straight away and dissolving ipa should give close indication.
I'm going to try some test batches tomorrow if I can with some new oil .
Post by: Chug on November 04, 2012, 09:27:48 PM
yeah I think a standard ipa titration should work too
Post by: Head Womble on November 04, 2012, 10:06:18 PM
Umm, I wonder if this could help with HMPE formation when WBD is combined with non titration method.
Post by: Tony on November 05, 2012, 08:02:41 AM
Add titration to the non-titration method?  Burn the heretic lol!
Seriously though, sounds like a plan to me.
Post by: Carrington on November 06, 2012, 04:58:37 AM
Well got flooded out in the factory over the weekend so spent a lot of yesterday mopping up , will try and make some hmpe's later in week
Post by: nigelb on November 24, 2012, 06:51:52 PM
I've been to see Keith and Lorretta today to drop off some winteriser....I also dropped off some battery acid I got from work. Brand new and sealed in seperate vials. These are available to anyone passing their door...FOC. It will save you the bother of using acetic acid (vinegar). I think it's 1230sg
Anyone passing my door in Leicester can also have some FOC...but I'm not going to post any. Sulphuric Acid through the post does not sound like a clever thing to send.
Nige
Post by: nathanrobo on December 22, 2012, 03:55:19 PM
Has anyone discussed the water method of testing prior to pump washing?  I couldn't see it but it's a rather big thread now.
I done this on a few batches now, after each first test I get cloudy water drop out and then continue to add acetic acid until I get a a clear test.
I had been transferring the fuel to my wash tank before adding water via a hose pipe and pumping.  The last time, I just sucked in the water via the pump's suction on my processor, I settled for 45 minutes each time under heat and got a good split.  In all I reckon 30 - 35 litres.  Perfect 50 / 50 clear.
Question is, are there any reasons why this slight variation is a bad idea?
Post by: RichardP on December 27, 2012, 10:08:29 PM
Not actually done the titration bit of this method, though I have been using vinegar in the first wash for some time. I need to get some stronger acid, hydrochloric is out for me as I have 316 stainless fittings, so would be looking at sulphuric or phosphoric, both being a similar price volume wise. What's the thoughts on phosphoric? Which would be best for use with stainless?
Also looking at the indicator for the test. Bromthymol blue looks to be best due to the colour change point, next being phenol red.   Any ideas where these can be acquired?
Post by: Head Womble on December 27, 2012, 10:13:47 PM
Get a soap test kit off Nige, that has Bromthymol blue in it.
Or ask your chemical supplier.
Post by: RichardP on December 27, 2012, 10:27:20 PM
I thought the stuff in the soap kit was bromophenol blue? Where's Nige??
Post by: nigelb on December 27, 2012, 10:29:52 PM
I'm here!
Richard..I have sulphuric acid here. FOC. It's brand new sealed battery acid that gets thrown away at work. For the sake of being close enough then bromophenol blue will work just fine. If you want Bromothymol blue I can get that for just under £10 for 500ml.
Mark..the indicator in the soap kits is Bromophenol Blue not Bromothymol Blue
If anybody needs any additional Bromophenol Blue for soap testing I can supply it at about £3.00 plus delivery for 100ml
Post by: RichardP on December 27, 2012, 10:40:25 PM
Nige, can you get me some bromothymol please? I can pop over when I'm back 4th or 5th, I'll have a bit of the sulphuric to to try out. Thanks.
Post by: Head Womble on December 27, 2012, 10:42:55 PM
Doh, you can tell I'm not a chemist can't you.
Post by: nigelb on December 27, 2012, 10:49:31 PM
It's an easy mistake to make Mark especially when the pH changes are so close as well the chemical name!
There was a point recently when I thought they were the same animal.
Post by: nigelb on December 27, 2012, 10:57:27 PM
I've just emailed the company and am now awaiting a response regarding collection.
Post by: nathanrobo on December 28, 2012, 10:58:03 AM
Nige,
I've got quite a few bottles of Bromophenol Blue, if you some anything urgently!
Post by: julesandtash on December 28, 2012, 11:22:52 AM
Phosphoric will be fine - it is just rather expensive. I still have a about 20 litres of 85% phosphoric acid which I will start using once I run out of 96% sulphuric (I have a about 1 litre of that left to use up first).
Phosphoric is certainly less hazardous although still not pleasant and will generate phosphate salts (ie Sodium Phosphate or Potassium Phosphate) in your wash water as opposed to Sulphate ones so would probably be good to put on your plants (especially Potassium Phosphate which is a valuable fertiliser).
Post by: nigelb on December 28, 2012, 01:40:58 PM
I too have a ready supply of Bromophenol Blue Nathan....however, my post to Richard was about Bromothymol Blue.
Post by: nathanrobo on December 28, 2012, 02:00:40 PM
Realise that you have a supply, implied by the soap test kits and earlier posts on this thread.  I was saying that I have a number of bottles of this that I won't be using.
Post by: nigelb on December 28, 2012, 02:28:55 PM
I'm confused...help me here. What have you got that you wont be using Bromophenol or Bromothymol. Confusion because you quoted a reply to Richardp about Bromothymol!!
Post by: 1958steveflying on December 28, 2012, 08:46:15 PM
Nathan stop reading on your phone and use the lappy..... Richard wants Bromothymol not Bromophenol which you say you have... even though Richard did misspell in his OP about it, lol.
Post by: nathanrobo on December 28, 2012, 10:09:52 PM
 :P
Post by: db on January 03, 2013, 10:45:07 PM
I've been following this with interest, as i've always bubbled and settled. I'm gonna give it a go, just a couple of questions:
Titration fluid using vinegar - do I mix 1ml to 1L of water and does it need to be de ionised?
Is every wash cycle a GENTLE mix (ie no eductor) for 20 mins?
Is the amount of water always around 7% of the batch volume / wash?
Once the water is clear I plan to dewater via my condensor, then transfer and bubble for a few hrs.
Does this sound like a plan?
Dawson
Post by: Head Womble on January 03, 2013, 11:06:28 PM
Keep in mind that you'll use quite a bit of vinegar,
if you can go for something stronger.
I used tap water, but I did wonder if I should have used de ionised.
I pump for 1hr with the eductor running, no need to worry as you'll not make an emulsion.
I use about 15% on the first wash and as much as I can fit in for the second.
I also dry with the condenser, but bubble over night just to be sure,
you will find the bio holds more water than normall washing.
Let us know how you get on.
Post by: william crosby on January 04, 2013, 06:23:08 PM
I have been getting good results using 2ltr vinegar on a 180ltr batch don't bother titrating as its been working fine and the car has been running fine .Not checked the ph for acidity.
By the way what should the ph of bio.
thanks
Post by: db on January 04, 2013, 09:29:15 PM
I tried to titrate today with not much sucess. I made a titration fluid up of 1ml/litre of  vinegar/distilled water.
After adding about 50ml and no colour change (still blue, using 50ml IPA and blue indicator from NigeB's soap kit) I decided something was wrong!
Can I use neat vinegar to titrate with?
Also regarding William's post above - can you overdose on vinegar if you just toss it in regardless?
Dawson
Post by: william crosby on January 04, 2013, 09:33:51 PM
if using vinegar you will have to use neat for titration solution no good watering it down.i think the only real thing putting to much in is the cost but i get it from cosco for 2.00 inc vat for 5ltrs so not that much oit of pocket if to much used.
Post by: Carrington on January 04, 2013, 10:04:18 PM
If you are using vinegar then the easy way is to add maybe 1/2 L and mix then do a 50/50 water test . If the water is cloudy then add another 1/2L , do this until the settled water is clear (ish ) then you know your ready to go onto the water wash.
With vinegar I think it would be hard to overdose , the excess will be washed out with the water wash
Paul
Post by: william crosby on January 04, 2013, 10:09:18 PM
paul
what shoud biodiesel ph test figures be.
william
Post by: Carrington on January 04, 2013, 10:26:08 PM
Hi William
It's very hard to test the ph of bio but if you do a 50/50 water test the water should be around 7 ish
Hope this helps
Paul
Post by: db on January 05, 2013, 09:18:48 AM
Paul
Thanks. So I add the vineagar to the bio without adding water, then when 50/50 clearish I can start to add water?
Can this be done at ambient temp. or do I need to heat?
Dawson
Post by: Carrington on January 05, 2013, 02:16:45 PM
Hi Dawson
Yes you can do this at ambient temp
Post by: nathanrobo on January 05, 2013, 03:50:04 PM
Paul
Dawson
I've been using this method, so have others and it works very well!  The last batch was pump washed to a crystal clear 50/50 (very aggressive shakeup) using just three bucket of water.  It seems less fiddly than doing a soap test.
Post by: db on January 05, 2013, 07:18:28 PM
Ok guys, I've added 1.5 ltrs vinegar and a 50/50 looks good. Just one more question..
Do I let the vinegar settle then drain, THEN add the water
or
Just add the water straight away?
Sorry for basic questions but i want to do it right.
dawson
Post by: Head Womble on January 05, 2013, 07:25:29 PM
Paul
Dawson
50/50  tests are less fiddly but don't tell the hole story,
it's only recently that I have started soap testing and it's quite shocking how much soap can still be in bio that shows a clear 50/50.
Post by: Head Womble on January 05, 2013, 07:26:35 PM
or
dawson
Add the water now with the vinegar still pressent.
Post by: db on January 06, 2013, 05:32:37 PM
I'm on my 6th wash now. I'm adding 10 L water at a time to 75L bio. I knew this batch would be soapy due to running out of sodium and wanting to use up the potassium I still have. I used a whopping 1Kg to convert this batch (usually only around 400g)!!
Can't wait to try the ASM - I hate Koh!!
Dawson
Post by: nigelb on January 06, 2013, 06:37:19 PM
Dawson
I should find out tomorrow or Tuesday for the delivery and price of the next consignment of ASM. Be patient young man.
Post by: db on January 06, 2013, 07:37:00 PM
Thanks Nige!
Quick update.. I'm on my 10th wash is this normal? The sample still shows cloudy water. Guess I'll just keep going.
(http://i1023.photobucket.com/albums/af359/DawsonBullock/Image128.jpg)
Post by: nathanrobo on January 06, 2013, 07:41:20 PM
Thanks Nige!
Putting to one side the odd looking bio, it would seem that something went wrong, with this many washes.
Post by: nathanrobo on January 06, 2013, 07:43:26 PM
Dawson
Did you do a 10/90?
Post by: db on January 06, 2013, 07:47:25 PM
Dawson
Did you do a 10/90?
I did a 27/3. it took 4 stages to get a pass. There was the teeniest weeniest bit of drop out, I'm talking less than 0.1ml.
Post by: Carrington on January 06, 2013, 07:57:40 PM
I've got to be quick
I think you meth is duff or your oil was very wet .
This is why you needed so much base chems
Leave it to settle over night . Drop the water put more vinegar in
This batch could take some time
Post by: db on January 06, 2013, 08:00:19 PM
Yep I'll do that. I'm wondering if the Koh is off because it's been stood for about 18 months, but in sealed containers.
Cheers.
Post by: nathanrobo on January 06, 2013, 08:55:40 PM
KOH shouldn't go stale, but it will absorb water right out of the air.  If the flakes are wet or sticking together, it's no good!
I used ASM for a while leaving my KOH that was already 18 months old, in a mango chutney container with a screw top.  I went back to KOH and it was fine.  I've had as little as 6% drop out after the first stage (2 stage no-titration).
Assuming that your KOH is okay, i'd guess it's as Paul says, you've got to look at the dryness of your feedstock or meth.
Post by: nathanrobo on January 06, 2013, 08:57:45 PM
btw 10/90 testing will allow you to be more accurate with dosing.  Uberveg has the glass centrifuge tubes really cheap.
Post by: Head Womble on January 06, 2013, 09:39:23 PM
Now I've not done that much water washing, but does that bio look amiss, it's just too light in colour.
Post by: Carrington on January 06, 2013, 09:51:21 PM
Very emulsified to me, too much base  I think this is why I think it was wet oil/meth this is what held back the reaction.
The problem is that the stage fails so you add more base when realy it just needs dry meth, this means that when you get final completion it's massively over dosed with base
Post by: nathanrobo on January 06, 2013, 11:04:05 PM
There's another similar thing that happens... If the process stalls due to insufficient meth first stage, more meth is added and more lye, but if the fuel has excess lye, then adding to it just makes more soap, when what it actually needs is meth.
I've spoken to a number of folk who have had high drop outs on their 10/90 after first dose and then had a mare with water wash or used a lot of vinegar trying to neutralise it.
Question is, will just adding more meth in with the glyc still present and continuing the 1st stage work?
Post by: kamaangir on January 07, 2013, 07:09:46 AM
I have had that and yes it will work with glyc present and insufficient meth. I used to mix my naoh in with half of my meth (easier to mix in a cubie with 12 litres rather than 24) and injected it and went off to do something else and forgot to inject the other 12 litres. Came back and had a massive dropout. Added the rest and got a 95% pass. I dropped the glyc.
I would only do a 2nd stage if my drop out was more than 10-15% as my cars ran on veg any way and it was better for me to not risk making excess soap by adding in more chemicals.
Post by: db on January 07, 2013, 02:18:17 PM
I used 12L meth on 1st stage, with 400 koh.  I wish I'd titrated now, then I could eliminte or blame the Koh. I'm gonna drain water and add more vinegar. Should i add the vinegar until a clear 50/50 again?
Post by: db on January 07, 2013, 07:43:42 PM
I've added another 1.2 l of vinegar and the 50/50 water is clear.
I've done 4 more washes and still cloudy.
Post by: Carrington on January 07, 2013, 07:56:41 PM
Hi Dawson
How long are you leaving the water to settle and how long are you mixing the water
Post by: db on January 07, 2013, 08:24:26 PM
Hi Dawson
15 min mixes, then 1/2 Hr settle.
If i was short on meth on first stage would this be the reason i used so much caustic? I did dry the oil before use via condenser until no drips.
Post by: william crosby on January 07, 2013, 08:52:23 PM
hi
i have found you need to let the water settle for at least 3 hours as it holds lots of bio and you will loose lots when draining water
Post by: db on January 07, 2013, 09:32:43 PM
Right that's me done with water washing!!
Tomorrow I'm draining the water, running the condenser and then bubble and settle.
Never again.
Dawson
Post by: db on January 08, 2013, 08:06:16 PM
I've dewatered via condensor, taken a sample and done a 50/50 and it's clear. Now to bubble and settle.
I'm wondering if the wash water would not have been cloudy if it it was heated?
Post by: Head Womble on January 08, 2013, 08:16:47 PM
Good result.
So are you still done with water washing, or are you going to give it another go ?
Post by: db on January 08, 2013, 09:19:26 PM
Hi Mark, I'm not sure..  With the wash water been cloudy every time I can't tell when to stop washing!!
I might try again while I use up the Koh but I've got some ASM comming soon to try which I'm told creates less soap, so hoping to just demeth and settle as normal.
Dawson
Post by: nigelb on January 09, 2013, 07:17:52 PM
Everybody's methods are different Dawson and, without trawling through this entire thread to see if I posted the comments I'm about to, I can say that my methods are very simple and effective.
I batched up at the weekend.(150lts).....a bit of a nightmare to begin with as some oily looking water got into the processor. Luckily this time I heated via convection rather than having the pump running. I managed to get the best part of 5lts out by heating to 60C and allowing to settle before moving on to my glyc wash to dry it completely.
I had a good 5/45 after my 2 stage titless process using ASM and pumped to the wash tank after a 7% post reaction wash. I bubble washed with 4 x 10lt washes. 1 on saturday through the night. 1 through Sunday. 1 through Sunday night and 1 through Monday. No settling or stopping the bubbler on any of the washes. By the time I got home on Monday evening the bio was clear and so was the wash water that came out. I heated it all up and did a hot pump wash. Drained that and used the heat to dry through Monday night using my uri geller diffuser. Filtered and winterised last night (Wednesday).
I didn't use any chemicals to neutralise the soaps...just good old fashioned tried and tested methods.
Don't give up on it. Some water washing sceptics have now been converted using the titrated wash method. That carries an awful lot of weight in my book.
Nige
Post by: 1958steveflying on January 09, 2013, 07:28:31 PM
It's my guess that had Dawson not used the acid wash method that he would most likely of had a massive emulsion on his hands.
Post by: nigelb on January 09, 2013, 09:16:15 PM
I guess you're right Steve. What I'm trying to advocate here is the need to be careful and gentle when water washing. Done gently, with a small bubbles for the first 2 washes and then increasing the ferocity and agitation in subsequent washes, stand alone washing can be very successful. In all of my posts regarding water washing on this site and the VOD it's what I promote the most. It works...it always has.
I think this titrated acid wash method is fantastic. A real step forward in the removal of soaps in biodiesel. However, it's not something I'll be trying anytime soon for the simple reason that my method works just fine.
Nige
Post by: Head Womble on January 09, 2013, 09:27:41 PM
Nige
I was one of those sceptics, I started my bio life using demeth and settle,
I then started mist washing like Nige, but suffered emulsions (probably due to pore convertions).
Now after a few years of going back to demeth and settle I've again gone to water washing, but this time it's the titrated acid pump wash method.
So as you can see I've tried a few different ways to remove the soaps, and I'm now completely sold on washing.
Post by: db on January 11, 2013, 09:35:29 PM
I hear ya guys. Like Nige say's, everone does it slightly different and i suppose it's a mattr of try which is best for me. I will try again soon, but I'm hoping with ASM I can demeth bubble and settle due to less soaps produced to start with.
Dawson
Post by: RichardP on January 20, 2013, 08:01:50 PM
Finally did a titrated batch, thanks to NigelB getting the bromothymol blue and some of the battery acid.
The oil was dried with the ventrui at 65c then glyc washed. On this batch, 160L, I reduced by base ASM from 3.5 to 3g/l, 2400ml, as I'd been getting 0.7ml dropout after s1 on the 10/90. Processed as normal and got .8ml dropout after s1, used 4.5g/l, 290ml asm, on s2 to a clear pass. (Total of 15.6% meth)
Onto the acid side. Made the titration fluid with 1ml of the battery acid - 1.32sg - to 999ml of distilled water. Titrated both 1ml and 10ml bio samples, and came to 0.2ml/l, so should have used 32ml of the acid. Now this seemed a bit low, after looking at the amounts others were using then I would have expected to use a fair bit more. The acid at an sg of 1.32 works out to around 40% H2SO4, http://www.sulphuric-acid.com/techmanual/Properties/properties_acid_sg.htm
Anyway, as the acid vial was 66ml I threw that all in (didn't want bits hanging around) with 10L of water, pump washed for 30 mins, settled/split very quickly. Another 3 10L washes and the bio tested at 12ppm soap.
Are my calcs right with the acid amount? I'm sure they're ok, but like I said it seems to little for the acid strength and batch size, even the 65ml that went in seems too low, but the results were good.
Maybe it was the base of 3g/l that greatly reduced the need for more acid, as it gave about the same dropout as using 3.5g/l.
Post by: Julian on January 20, 2013, 08:15:03 PM
Haven't been through your sums, but with the batch I've just made I used 200ml conc. sulphuric for 80 ltrs of Bio.
Post by: nathanrobo on January 21, 2013, 12:34:08 AM
Apologies if somebody covered this, couldn't see it - plus short attn span!
But if your first reaction 'stalled' due to insufficient meth, there may have been excess lye in the fuel. Now you calculate 2nd stage lye on Basis of dropout reading, you now have too much lye in 2nd stage  & u have enough soap for bath time :-)
Post by: nathanrobo on January 21, 2013, 12:40:55 AM
Nige
Mist washed for 5 years - swore by it! Experimented with pump washing... Tank full of blamange. Started to neutralise and tried pump washing again. What a difference! Was getting bored of bio, but it's getting interesting again. Well - u gotta play!
Post by: jgs600 on January 22, 2013, 10:36:56 AM
i buy some drain block from my local store, i checked with the company and its 98% pure acid ( so gotta be careful)
after ive finished the process i let the glyc settle , tap this off, get the processor churning over then add 40ml of acid, then chuck in 15litres of water, never had any problems doing this and the acid stops the bio turning to custard too.. :)
Post by: Huntman40 on January 26, 2013, 06:36:56 PM
What temps are people pump washing at.
with the cold ambient temps some people may not be realizing that the wash water can freeze. (can it?)
My first attempt at pump washing (hit and miss without titration) was left overnight to settle and by that time the batch and wash water was at -1 deg C. water and bio would not split. (orange juice)
once heated to 3 deg suddenly everything went back to normal, bio and water split.. continued washing.
Time to bite the bullet, who sells the kit i need to titrate?
Cheers
Post by: Head Womble on January 26, 2013, 10:09:20 PM
I start washing as soon as the gly is removed, so the acid wash is done at around 60°C,
this is generally settled overnight, drained in the morning,
then do the second wash, so it's still around 45 to 50°c.
The titration kit you want is sold by nigelb.
Post by: thewormman on April 21, 2013, 01:00:29 AM
So a few months on what is the considered opinion of this method from those that contributed?
Are you still doing it?
What are your findings?
Have you changed your process at all?
Post by: Head Womble on April 21, 2013, 09:45:47 AM
I've stopped acid washing, I now do a 7% post reaction wash with the gly from the second stage still pressent,
this removes enough soap to not form an emulsion on the first wash.
Yes the acid wash did work and the only drawback (apart from adding another stage) was that titrated soap tests gave false readings until all the acid had been washed out.
Post by: Jamesrl on April 21, 2013, 01:04:21 PM
1. Are you still doing it?
2. Have you changed your process at all?
I. Tried it but found it to be an unnecessary additional stage.
2. As the "dead man walking" above, returned to the post reaction 5/7% water wash.
Post by: Head Womble on April 21, 2013, 01:29:42 PM
Dead Womble walking, please get it right.
Post by: Jamesrl on April 21, 2013, 04:27:44 PM
Feel free to use either phrase, the result will be the same.
Just another wooden cross in the corner of a distant field.
Post by: nigelb on April 21, 2013, 05:56:24 PM
;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
This years BBB is going to be so much fun ;)
Post by: Head Womble on April 21, 2013, 06:51:30 PM
Sorry to disappoint, but if I loose my setup I'll not be attending the BBB,
how can I turn up with diesel in the tank, that's a hanging offence as it is.
Post by: Jamesrl on April 21, 2013, 06:54:35 PM
Just turning up is a hanging offence in your case and I know where you live, there's no escape.
Post by: Head Womble on April 21, 2013, 06:58:36 PM
I sounds like I'll have to attend the public hanging then.
Post by: nigelb on April 21, 2013, 07:26:30 PM
I think that Brett Gilbert showed last year and had never made a single litre of bio fuel.....no excuse there I'm afraid Mark.
Show up and take you punishment like a man. ;D
Post by: thewormman on April 21, 2013, 10:25:01 PM
So does that mean after 17 pages singing it's praises no-one now does it and it's not worth doing?
Post by: K.H on April 21, 2013, 10:29:23 PM
Im still doing it, cuts my wash time down considerably
Post by: Head Womble on April 21, 2013, 10:35:14 PM
No.
We've tested it, It's been proved to work, some are still using it.
It's all about what each brewer finds works for him,
with so many ways of finishing our fuel there should be something for everyone.
Post by: thewormman on April 21, 2013, 10:37:43 PM
Could I ask what routine you have settled into with it and how it cuts the time compared to what you did before?
Thanks
Post by: K.H on April 21, 2013, 10:39:40 PM
I agree with Mark it does work, very well in fact and it suits me at the moment as the drain my mist washer goes into is blocked, when that is sorted i will most probably revert to that but only because its less hands on, which to me is the main thing
Post by: Soft top on April 21, 2013, 10:44:14 PM
Wow. Your brave, asking a question like that.
I hope you get better answers than when I asked the same people on vod, "what are the advantages of acid washing" someone not only spat his dummy at me but chucked his toys as well. Lol.
Post by: K.H on April 21, 2013, 10:49:41 PM
Thanks
I use Sulphuric (From Nigel ) now and do 3 pump washes in the processor, then its transferred to the non overflowing mist wash tank where i just send 25 litres of water through to give it a final wash
I would normally just transfer the unwashed bio to the wash tank, turn on the tap slightly and come back in 5/6 hours to clean fuel, that suits me because i prefer hands off over saving some money
But with a blocked drain i cant mist wash for hours so the acid wash suits me, in future if i need fuel in a hurry i would also acid wash over mist washing.
Post by: Head Womble on April 21, 2013, 10:52:59 PM
We're more tolerant over here, and open to try new things.
Post by: K.H on April 21, 2013, 10:53:50 PM
One advantage that cant be overlooked is the fact it can all be done in processor, something that may suit people with restricted space, AFAIC you can easily get the same result bubble or mist washing but its good to have in reserve if you get a very soapy batch or need fuel ASAP
Post by: Julian on April 21, 2013, 10:53:55 PM
I still use it, I very much like the idea.
It allows me to have uncontaminated glycerine for glogs.
Doing a titration and adding a bit of acid to the wash water isn't so much hassle.
I've never really had fantastic results bubble or mist washing where as the titrated acid wash is pretty fool proof.
I guess it's just a case of each to his own.
Post by: K.H on April 21, 2013, 10:55:24 PM
What more can you ask for? the seal of approval from the soap king
Post by: Julian on April 21, 2013, 11:02:33 PM
Praise indeed from the only scatologist on the forum.
Post by: K.H on April 21, 2013, 11:04:04 PM
I will stick a more interesting one on there
Post by: Julian on April 21, 2013, 11:10:10 PM
Please don't.
Post by: K.H on April 21, 2013, 11:12:15 PM
Please don't.
Too late
Post by: thewormman on April 22, 2013, 12:11:35 AM
No.
OK cool just wanted to know if its still an option as I like the sound of it.  :)
Confrontational thats me  :P
(Runs and hides...)
Post by: Head Womble on April 22, 2013, 08:20:28 PM
It's good method for new brewers, as if you do make a soapy batch you can wash with confidence.
In may ways it's fool proof, but you always get one fool that can mess anything up.
Post by: mikethebike3 on May 19, 2013, 10:56:58 PM
After 7 previous batches with varying degrees of minor problems (but ultimate success), I just tried my first batch using this titrated water wash, and I failed :-(
I'm using universal indicator and mixed it with meth as per the wiki, it turned a little yellow so I added a drop of KOH reference solution which turned it nicely green, no probs.
Then when I added my bio it stayed green, and no amount of shaking or threatening it made any difference.  I repeated the process with the same result.  Just to make sure I didn't have a dud indicator I added a few more drops of KOH reference and it duly turned blue.
I should say that I processed using 4 stages, with each 10/90 returning less unprocessed oil until I got a pass.  I deliberately do this as it's not a lot of extra effort and I know it should minimise soap production, but I wasn't expecting ph neutral!
Any suggestions?  I've emptied it into my settling tank as I have to do another batch, but does this mean I could have washed it in the processor (as if I'd added acid) without fear of forming an emulsion?
Any insights gratefully received!
Mike
Post by: Julian on May 19, 2013, 11:05:56 PM
Hi Mike,
Welcome to the wiki and forum ... what took you so long!
Best test you could do is to do a say, 10% water shake up test.  Shake the b'Jueus out of it, that should give you some idea of what in-processor washing will do.
Post by: mikethebike3 on May 19, 2013, 11:09:46 PM
Thanks for that Julian - are you ALWAYS here?
I'll give it a whirl in the morning and report back.
Mike
Post by: Julian on May 19, 2013, 11:18:58 PM
Not ALWAYS.  The PC is usually on if I'm at home and I'll check the forum when I pass the PC!
I've been looking at exactly the same thing this evening.  I did a 7% water wash with the glycerine (won't need glogs for a few months hopefully) and tried a shake up test afterwards ... results don't look promising, so I'll probably have to go back to titration for soap and add acid.  Strange when I keep reducing the ASM.
Post by: Head Womble on May 20, 2013, 02:34:19 PM
This suprises me, I got away with a 10% water wash with only the second stage gly pressent on my last batch, and I run the eductor while washing.
Post by: Head Womble on May 20, 2013, 02:37:53 PM
Mike
Have you tried a 7% water wash (with gly pressent) and then doing 10% water washes.
You should get away with this if you're producing very little soap.
Try it on a small sample first though.
Post by: Julian on May 20, 2013, 03:00:41 PM
And when it doesn't work you can dump 200 ltrs in my back garden!
Post by: Kevin on June 19, 2013, 07:01:31 PM
I'm new here and at a larger scale refinery, but I'm assuming the same basic principles apply.  Our water typically comes in the plant at pH 8-8.5.   This is problematic as it contributes to soap formation.  We dose the wash water to pH 6.5.  We are approximately 8:1 biodiesel to water.  We do not titrate the bio as this has become a rather full proof method.  An addition note is that we are using softened water which is a benefit as well as it is still pulling the metals away.
Post by: Julian on June 19, 2013, 07:55:05 PM
Welcome to the forum and wik, Kevin.
I don't know if anyone has taken into account the pH of their water ... I know I dont.  Perhaps I should check it!
Last few batches I've only had to use minimal acid as I'm gradually cutting down on the catalist I use.  I've been playing with gradual additions until I get colour and viscosity changes coupled with a temperature rise.
I guess the "No titrration method" would deliver similar results ... what processiung method do you use and what batch size?
Post by: 1958steveflying on June 19, 2013, 08:10:02 PM
Hi Julian... out of interest can you elaborate the " coupled with a temperature rise."
 cheers Steve
Post by: Julian on June 19, 2013, 09:00:07 PM
It's detailed on another thread, I'll try and find it.
I assume it's the exothermic reaction taking place.
Post by: Julian on June 19, 2013, 09:04:49 PM
Here you go ... http://www.biopowered.co.uk/forum/index.php/topic,1264.0.html
Two posts towards the bottom of the page, one with a photo.
Post by: 1958steveflying on June 19, 2013, 10:51:46 PM
I took your post to mean adding the acid in small additions caused a temperature rise... my bad sorry
Post by: nathanrobo on July 06, 2013, 10:07:31 AM
My new set process / set up has similarly allowed me to use less KOH (always seem to get either 94 or 95% conversion after stage one now) which means that neutralising is easier.  Washing is now consistently 4 x 10 litre buckets to a crystal 50/50... another benefit of getting a great first reaction :-)
Title: Re: In processor titrated water wash method _ what am i doing wrong?
Post by: Islebio on March 30, 2017, 06:59:30 PM
Hi,
I have been following this post and trying this method for the last 4 or so batches. I have been getting a good 45/5 test result, i have had little luck with the figuring out how much acid i need, so have been adding 5 litres of vinegar to a batch of 180 litres bio. I then start adding the water and it always turn to some form of emulsion. I wash it about 3 times till the waste water is clear, then dry the bio in my drier (sprayed out at heat), this takes all ( or most)of the water out. It still remains a bit cloudy but passes the 50/50 water test really good with little soap.
Questions - should the bio be totally clear after adding the first batch of water wash
 - Why when you do a 50/50 shake test on soapy bio and it settles out really nicely to the bio at the top, soap in the middle and water at the bottom, does this not apply to the bio in the processor? I thought i could just drain it alll off ( i left it over a week )
Any help appreciated.
Post by: dgs on March 30, 2017, 10:22:44 PM
I just love these old threads being brought into life again. Islebio, I am not a great lover of this method (as I have posted before)
If the amount of acid needed is small then granted, there can be some advantages as regards separation of water and bio, but adding lots of acid or in your case vinegar is a no no.
Your soap level after the last reaction when you have achieved a good 45/5 could be 000's of ppm's and with the acid addition you will turn these soaps to free fatty acids. In addition you will have monoglycerides present (they are always present no matter who's bio it is) Water washing can be a good way to remove these but the addition of acid encourages them to stay in the bio.
Before you add acid, water wash with water only. Mist or gently bubble if you tend to get an emulsion, or better still either de-meth (if you don't already) or do a 5% pre-wash with water.
http://www.biopowered.co.uk/wiki/Water_prewash
Post by: dgs on March 30, 2017, 11:06:21 PM
Just to qualify a few things with my post.
first Islebio to answer your questions. No, the bio should not be clear after the first water wash as it will be saturated with water (something like 1000ppm)
The mix in the processor should roughly follow what has happened in your 50/50 jar, but if the relative temperatures are different (if for instance you have brought the test into the house) then this may account for the two being slightly different.
It is my opinion that biodiesel with amounts of FFA's and Mono's left in the mix is more viscous than biodiesel without these contaminants. Furthermore I believe that biodiesel with these contaminants is less volatile than without them. Both are reasons to remove/not produce them if using the fuel in a common rail vehicle.
If I ever do use acid the soap level is <100ppm and then I only use 5mls of 50% acetic in 8 litres of water. This is with a 200 litre batch size.
Post by: Islebio on March 31, 2017, 03:46:01 PM
Hi DGS,
Thanks for your help, i am really trying to do this to avoid waterwashing. I have a jamesrl processor where i demeth via the condenser till there is nothing dripping out ( last time i did this i think i may have left it too long as the liquid coming out was eventually brown). I then transfer this to a bubbling tank and leave to bubble for about 12 hours, i then heat up again in that tank before i leave to settle. Even though i do this the 50/50 sample seems really soapy. I know that water washing via misting will reduce this soap but i'm just trying to do a quicker turnaround on the process.
Cheers
Post by: dgs on March 31, 2017, 04:00:38 PM
if you are just leaving it to settle after demething then the catalyst used will make a great difference to the soap level. If you are using Potassium then even after demething the soap could still be quite high in which case filtering through oak chips is a good idea, it should bring the soap down to zero.
Post by: Islebio on April 01, 2017, 07:01:29 AM
Hi,
Yes i do use potasium, I do have a dry media tower, which i fill with ecopure2 media and change every 1000 litres then through a 10 and 5 micron filters but still seem to have a soap content, haven't tried the resin tower but this may be the next move!
Cheers
Post by: dgs on April 01, 2017, 09:43:03 AM
A soap test kit is a good idea, then you know exactly whats what. They are very easy to use and very accurate. The 50/50 is only accurate to a point. NigelB on here sells them.
If you use ion exchange resin the life expectancy is greatly reduced if the starting soap level is greater than 500ppm.
