Biodiesel => Chemistry and process => Topic started by: Gordon on August 02, 2022, 01:01:11 PM
Title: Success, I think.
Post by: Gordon on August 02, 2022, 01:01:11 PM
Hello all,
After many failed attempts and plenty of solid jelly-like outcomes, I think I've succeeded. So, I thought I'd use this outcome to introduce myself. Hi. I'm no chemist, so simply followed instructions as closely as I could, to achieve this...
(https://pbs.twimg.com/media/FZJyMQlWIAIr2RD?format=jpg&name=small)
What's the simplest way to test that I have indeed succeeded?
Title: Re: Success, I think.
Post by: RichardP on August 02, 2022, 11:31:19 PM
3/27 or 10/90 test. http://biopowered.co.uk/wiki/3/27_test
Post by: nigelb on August 02, 2022, 11:55:34 PM
What exactly are we looking at? There is a genuine reason for asking?
Post by: dgs on August 03, 2022, 10:18:42 AM
He's just pleased with himself Nige. Remember the feeling of success with your !st batch.
Post by: dgs on August 03, 2022, 10:25:06 AM
Hi Gordon, welcome to the Forum.
Richard means one of these.https://www.ebay.co.uk/itm/125260439681?hash=item1d2a1aa081:g:ZG8AAOSwAXFiWIgh
I keep them in stock, pm me.
Post by: nigelb on August 03, 2022, 03:28:13 PM
The reason for asking is this. Is what we are lookingvat glycerine and bio. If so, its the clearest bio I've ever seen. It could also be taken as the result of a water shake em up test considering the clarity of the upper layre...but the water is on top instead of the bio.
I get the same euphoric reaction every time I brew..
Post by: Gordon on August 03, 2022, 06:30:07 PM
Hi there. This is exactly the observation that provoked my question.
This outcome seemed far more clear than I was expecting, and so I was suspicious that I had simply somehow created a jar of water.
However, this photo is a result of me mixing 500ml sunflower oil, 100ml of Methanol and 2.8g of NaOH at 56C for 10 mins, then leaving it to settle overnight.
But strictly speaking, I have no idea what I'm doing, as chemistry ain't my particular speciality.
I assume the glycerol is at the bottom, which means the oily substance at the top is what I'm after. However, it looks way clearer than I was expecting.
So, I figured I'd use my consternation as a way of saying hi.
Post by: Gordon on August 03, 2022, 06:31:20 PM
Yes, I am somewhat surprised by how pleasing this outcome was - assuming, of course, that I have achieved what I set out to achieve.
Post by: Gordon on August 03, 2022, 06:35:07 PM
Hi, and thanks very much.
Ah ha. Okay, thanks.
Post by: Gordon on August 04, 2022, 01:37:14 PM
Well, until I get the right kit, after a bit of cleaning at least it does burn.
Not sure what this really tells me that's useful, but at least it does indeed burn.
(https://pbs.twimg.com/media/FZUSqbZWQAARgFI?format=jpg&name=900x900)
Post by: Tony on August 04, 2022, 11:35:27 PM
Looks like you had a conversion which is great!
Bio will burn briefly with a wicked burner like that, but not for long before the wick burns down.  Even mixed with other solvents the same happens (I hoped to use bio in a greenhouse heater - no such luck).
Next step is the 3/27 test mentioned above - basically if you mix a small amount (~10%) bio with an excess of methanol, what should happen is you see the two combine into a clear liquid.  However, any bits that settle to the bottom would be unconverted oil.  It allows us to (roughly) see if there is any remaining oil that hasn't been converted to biodiesel.
Post by: Gordon on August 08, 2022, 02:43:24 PM
Excellent. Quite pleasing.
Ah, I was wondering about that. I rather liked to idea of burning bio in my latest construction...
(https://pbs.twimg.com/media/FZpGeeNWQAAj6IC?format=jpg&name=large)
..but I guess I'll have to stick to paraffin for the time being.
That's a shame - I rather liked the idea of bio in a greenhouse heater.
I assume the bio is too viscous to climb the wick sufficiently quickly?
In that case, to what type of heater is bio better suited?
Ah, okay - I'll give that a try.
Thanks.
Post by: countrypaul on August 08, 2022, 03:41:51 PM
 It might be more related to the boiling points, Kerosene/paraffin being around 180C where as biodiesel is around 360C (both are subjet to variations in content and  purity, and target market as well as Kerosene/paraffin having slightly different meanings in different locations).
Post by: Gordon on August 08, 2022, 07:24:37 PM
That certainly seems a possible explanation. However, I would have thought that if it's lit, it's lit, and that flame front is therefore hot enough to ignite more local fuel.
Hence I was musing that if the flame extinguishes after a few minutes then it's running out of fuel, suggesting that the fuel is not climbing the wick sufficiently fast to maintain the flame.
However, if that was indeed the case, I would have expected mixing the bio with something lighter would fix the problem, but it didn't, so, well, I guess I'm wrong.
Suffice it to say, it'd be nice to diagnose this, as I'd quite like a bio greenhouse heater...
Post by: DavidA on August 10, 2022, 11:26:19 AM
I'm just seeing a blank box with no image.
Post by: countrypaul on August 10, 2022, 01:05:06 PM
What browser are you using, can you try a different one? Have you checked the various setting?
Post by: DavidA on August 10, 2022, 08:02:06 PM
I'm using my usual Firefox browser.
It seems to be working ok on the wiki pictures. Just this thread that is a problem.
Post by: countrypaul on August 10, 2022, 10:55:50 PM
I'm using Firefox 103.0.1 on windows 10 with no problems.
Can you try with Edge since M$ seem to install that anyway?
Post by: DavidA on August 11, 2022, 11:05:25 AM
I suspect the problem is with the version of Linux I am running.  For example I can't resolve mpeg4 format for videos, although I have no problem with mpeg3. So the pictures are likely to be in a format that my machine doesn't recognise. I'll connect up one of my other machines and see what happens.
Post by: Tony on August 12, 2022, 09:44:29 PM
I tried mixing various combinations of biodiesel and isopropyl alcohol/methanol up to a mix of 4:1 biodiesel to alcohols, and still problems with yellow flames, ash and the wick burning down.  This was in an aladdin 14 type paraffin heater.
You might be able to burn a mix of kerosene and biodiesel if there is not much biodiesel, but that rather defeats the point!
I did build a mini heater that had just a steel bowl with a tall thin chimney and that worked a treat, lit with a rag as a wick then the heat was kept in the chamber and the surface of the biodiesel itself burned.
Post by: Gordon on September 18, 2022, 12:00:14 AM
Okay, yes, agreed, using only a basic wick my concoction will not climb the wick fast enough to remain lit. However, I still fancied a bio fuelled greenhouse heater, so here's my solution so far, built from scratch using the least amount of specialist materials or tools I could manage...
https://www.instagram.com/tv/Cin9mbQPJZg/?utm_source=ig_web_copy_link
Basically, a gravity feed to simply pump the bio up through the wick and onto its surface. It gets hot, it remains lit, and I haven't yet burned down my shed which is a bonus. The whole story so far can be found here...
https://www.instagram.com/greenshedbuilds
Post by: Gordon on October 17, 2022, 02:33:51 PM
Here's a neat idea...
https://www.youtube.com/watch?v=HX2taNrdQh8&ab_channel=RobertMurray-Smith
Apparently, carbon felt will indeed wick thick vegetable oils, allowing you to build a greenhouse heater.
Post by: dgs on October 17, 2022, 05:58:53 PM
One of my greenhouses is in my 72 foot polytunnel. I over-winter some sensitive plants in it. It is double insulated with bubblewrap. the carbon wick method still puts too much smoke out to use it in a sealed space.
I have 3 types of heat in this greenhouse. An electric 180 watt tube heater, set to come on at 10degs. A 5kw chinese heater which uses 100mls of kero per hour on min. A thermobile 307 waste oil heater. Using a combination of these through the winter I seem to manage. Believe it or not the electric heater is the most economical!
I so wish i could use bio but it seems impossible. A little methanol heater would burn clean but with the present prices there would be no advantage over the Chinese heater on kerosene.
