General => Chatter => Topic started by: neisel on January 06, 2022, 03:13:48 PM
Not mine & nothing to do with me, I just have a soft spot for these quirky beasties after owning a petrol version years ago & keep an eye out. This one sounds OK & with a little TLC could be a keeper.
https://www.ebay.co.uk/itm/185244842853?mkevt=1&mkpid=0&emsid=e11021.m43.l1120&mkcid=7&ch=osgood&euid=94f1a53119514c5fb8a50ae06de13d26&bu=43931276378&ut=RU&osub=-1%7E1&crd=20220106073727&segname=11021&sojTags=ch%3Dch%2Cbu%3Dbu%2Cut%3Dut%2Cosub%3Dosub%2Ccrd%3Dcrd%2Csegname%3Dsegname%2Cchnl%3Dmkcid
P.S. Do we have a spotted on ebay section?
Never had one but always wanted one for the hydraulic suspension. Phenomenal bit of design, shame it went out of fashion.
The French are great at inovative design. Surprised that they've not designed a vehicle with the handbrake located in the glovebox and the indicator stalk under the front passenger seat😊
I had a couple of Diesel BX models. Very comfortable.
But they had an dangerous fault.. If the hydraulics suddenly failed, so did the brakes.
A bloke close to here was killed by one. He was using the hydraulic suspension lift to give enough space to enable him to work under it. And the engine stopped.
I still have a full set of front to rear hydraulic pipes in the shed. Brand new in their original wrappers should anyone be interested.
There is supposed to be a hydraulic accumulator attached to the regulator. These run down and need replacing , if done before they are totally flat they could often be recharged. This would give a reservoir of hydraulic pressure to enable a driver to stop. Sadly as these cars became cheap the maintainance was never done, so no reserve of braking/ suspension pressure
I'm afraid it is a myth that these cars come down if the engine stops. They do come down - albeit very slowly- usually the back drops to half height overnight. Later cars have an anti sink system, I have a Xantia parked up in the yard - the suspension is still on full lift after 6 years parked up...
