Biodiesel => Chemistry and process => Topic started by: RIngrey on October 26, 2011, 03:43:54 PM
In anticipation of the colder weather I thought it wise to invest in some additives to prevent issues developing over the winter period.
I know some of you will choose to add a little petrol and mix with regular derv but I decided to give the commercially available additives a try.
I purchased some Coldflow 350 and BioBoost 1000. Having made a few batches now I have to say the difference is quite astounding. My Bio's viscosity has totally changed and together with the Bioboost performance has increased also. I can't vouch for any increases in MPG as of yet as I have not done any calculations to date. However, cold starting has improved considerably and throttle response has also benefitted.
I thought I would share my experiences with you all now that the colder weather is set to draw in.
All up the cost is minimal and well worth the outlay.
They have to be mixed hot don't they?
Also doesn't 1u filtering take the additives out again? (I always 1u cold filter before it goes in the car)
Only the coldflow needs adding when hot. 1u filtering isn't required when you consider most car filters are only 10u.
Not so much hot as warm,either 20C or 5 above the cloud point and the companys now say they can be filtered to (and incl) 1 micron
im using coldflow 350 at the moment and it seams ok but will see in a few weeks
It hasn't got proper cold yet - when there is ice on the ground - that's when the fun starts!
quite true we managed last yr with just herbina plus so either coldflow 350 or herbina pro will be fine
the only think i dont do in the winter is use solids i use 100% liquid but right now its 80 liquid 20 solids until i get a cload and its time to stop the solids
Keith can I format up your testing of additives from here:
http://www.vegetableoildiesel.co.uk/forum/viewthread.php?tid=14224
...to put them in the wiki?
Yes,no problem :)
Done!
http://www.biopowered.co.uk/wiki/Winter_fuel_additive_testing
The table definitely helps with the readability of the results.
Great page chaps, just a couple of comments ...
It will surely sit better in the "Safety and testing" category as it's not part of the production process and the clue appears to be in the page title ... testing!!!
Can we add a little more info on the viscosity test and the drip cup? I can hazard a guess as to how it works but some photos and a little text would compliment the already excellent information.
I just bunged it in the current category without much engagement of the grey matter. I'm not going to be precious about it if you want to move it Julian. :)
