Biodiesel => Chemistry and process => Topic started by: willbuild on May 22, 2014, 08:50:28 AM
Title: processing palm oil / lard
Post by: willbuild on May 22, 2014, 08:50:28 AM
I have about 80ltr of solids which i assume is palm oil? or should i process mixed 50/50 with rapeseed?
If i process only palm oil i assume that it will return to solid at around 20c
Title: Re: processing palm oil / lard
Post by: therecklessengineer on May 22, 2014, 08:55:40 AM
Pretty much right yes.
The higher the proportion of palm, the higher the cloud point of the product.
I cut with about 70% clear oil and I'm good down to about 0 degrees.
Post by: Jamesrl on May 22, 2014, 09:57:06 AM
On the odd occasion that I do process solid palm I use 20/80% liquid.
Post by: 1958steveflying on May 22, 2014, 11:42:54 AM
Bio made from Palm oil that is solid at 20c will normally be good down to around 5c without problems.
Post by: willbuild on May 22, 2014, 12:06:05 PM
thanks for that. will go into workshop (shed) and give it a go :)
Post by: Jamesrl on May 22, 2014, 05:04:55 PM
Bio refinery surely.
