Biodiesel => Chemistry and process => Topic started by: Oilybloke on June 08, 2013, 04:55:13 PM
I have recently started collecting from a chippy that uses beef tallow. I have yet to process any, but wondered if anybody else has? Any pitfalls?
Ive got 300+ ltrs in the reactor at the moment, and another 400 in the preheat containers.
Its hard fat. Palm will go to slush on a hot day - no chance with tallow - you always need to pre-heat it or dig it out of the drums. I use a shovel, and i wouldnt waste my time in winter.
You also need to blend it in anything but proper hot weather. Ive been running on a blend for about the past 4 weeks, but even then we had one incident with the fuel filter.
You need to watch out for pipework setting when settling. When i rebuild my unit, ill have drains so as i can drain the whole lot down when i want to.
You also need to be very careful about the whole lot setting in the reactor.
Basically, its hassel - much more hassle than palm / prep etc. But i get 100s of litres of it for free, so, for me, its worth the mods to the reactor / process.
ps
melting point of its methyl ester is quoted on JTF to be about 15 or 16c. Ive found it maybe to be a couple of degrees lower (13 ish?) but, if its in your tank, you need to be watch for those night time temps too!
one last thing -
your settling drum cant fall below 13c ish either.
I found it also eats heater elements, I popped a couple when reacting tallow.
....and another thing -
The 90/10 test (etc) is always said to be done at 25c. If you try doing it with a tallow brew, you need to go above this temp, else the tallow component will just go hard as soon as it hits the meth.
The 90/10 is supposed to done at 20°C not 25°C.
Many thanks guys, all comments are appreciated.
