Multi-tasking processor
3 in 1 Processing System.
Build and design by K.H
Parts List
  • 4mts 22mm pipe
  • 2x 3/4 hosetails
  • 5mt clear 1" pipe
  • 8x tees 22mm
  • 7x 90s 22mm
  • 2x 45 22mm
  • 2x bypass valve 22mm
  • 5x tank connectors 22mm
  • 5x nylon washers
  • 5x joiners 22mm
  • 4x 3/4"-22mm
  • 9x full bore valves 22mm
  • 2x pressure gauges
  • 18" immersion heater
  • 3x 10" filters plus brackets/elements
  • mechanical flange 2 1/4"
  • 400mic drum filter
  • 205lt clip top drum
  • 120lt HDPE clip top drum
  • tam 105 pump
  • 2x 1"-22mm
  • 4 mt flex
  • 2 plugs
  • 22-15-22 tee
  • 1x 15mm ball valve
  • 1x 15mm tank connector
  • 1x 15mm comp 90
  • 1x 15 comp tee
  • 1x 15mm speedfit stopend
  • 4x nylon washers
  • 1x float switch
  • 1x Connection box
  • 1x SSR (soild state relay)
  • 2x 1" tees
  • 1x 1" hosetail
  • 1x forecourt dispensing nozzle
  • various cable ties, jubilee clips etc
Total cost @ 01/05/11 £425
complete set up
Usage
Drying WVO
Step Lid Heater Pump V1 V2 V3 V4 V5 V6 V7 V8 V9 V10 V11 Notes
Oil in         Pour or pump oil into processor via the drum sieve.
Heat Oil   65°C       Check the oil level.  The element must be covered before switching on.
Settle oil           Leave to settle for a minimum of 7 days.
Drain crud             Drain water and 'whites' until good oil is observed.
Pump to settling tank
Bio production
Dry oil   65°C       Check the oil level. The element must be covered before switching on.  Remove the drum sieve.Circulate oil until a 3/27 pass is achieved.
Cool oil           Circulate oil until it reaches 65°C. Once at temperature, replace lid and ensure it makes and air tight seal.
Add methoxide             With Methoxide container connected to V2, partially close V10 and crack open V2 to entrain methoxide. On completion close V2 before fully opening V10
Reaction satge               Run for 90 mins
5% Prewash         Mix 15 mins.
Settle glycerol         Wait 90 mins.
Drain glycerol         Drain slowly to avoid vortex in tank.
Pump out to wash tank           Check heater is off before pumping out.
Dispensing WVO
Dispense settled oil         Lid can be on or off for this operation.
The wvo goes into the drum via a 400 micron drum filter, it's then heated with the option of circulating to speed dewatering, it is then pumped into the storage drum via 20 and 5 micron filters. Most filters are rated at 0.8 bar so there is a bypass valve which ensures the oil is never forced through the filters. From the storage drum the oil goes through a 1 micron filter protected by the bottom bypass valve to the car/drums. A pipe and valve also connect the crud valve to the pump inlet so this can also be used to make biodiesel but it will need an additional wet or dry wash tank. The methanol can be introduced before the pump and a pipe attached to the top of the sight tube becomes the vent. It will transfer to the wash/settling tank avoiding the filters and it utilises the clip top for sealing the processor. An inline heater cannot be used with this design but an eductor or venturi could be added if desired along with a condensor but an additional vent outlet would need to be fitted to the lid. You can dispense your wvo to the car/container via the delivery nozzle. When the trigger is released the oil is sent back to the tank by a bypass valve.
Safety Point
Main Features
Footnote
KH 23:02, 13 June 2011 (BST)
