Author Topic: I hate ASM!  (Read 18088 times)
Offline Oilybloke
Re: I hate ASM!
« Reply #45 on: January 31, 2013, 06:29:41 PM »
, but demethed by bringing up to 110c and circulating overnight @ 70c.,
I'm not sure I understand what you're saying, are you demething via a condenser? If not how do you know how much meth is left in the bio.
You're probably aware that meth in bio = suspended soap, methanol stops soap particles coalescing and dropping out.
Yes Jim, de-mething with condenser. Some recent discussions with Nathan showed that I had not been giving enough attention to de-meth (and hence the squirrel enquiry).
Jim, I have lost your email address, and would like some more details on the squirrel set up. Some pictures perhaps?
Re: I hate ASM!
« Reply #46 on: January 31, 2013, 06:43:31 PM »
Just covering my arse with the exploding bit, there was a cycle valve fitted to release the pressure although I found something posher for Nathans, it works better with calcium hydride but as it is hard to source I left it out (that is what is used in the sandy brae kit)
It could really do with a small airtight metal container but I have yet to find one
Its a good design to make at home :)
Calcium carbide giving off acetylene rather than Calcium hydride giving off hydrogen might make it a bit safer?  :-\
Do you think it would not be as accurate then?
Should be as accurate, its just grinding up the carbide that is time consuming and you get a quicker reaction with the hydride
