Author Topic: Results page for acetone use in reaction  (Read 7412 times)
Re: Results page for acetone use in reaction
« Reply #15 on: January 27, 2013, 08:49:04 PM »
And yes I like the wiki page
Space for lists of info so people can go the way they want
Some will go for doing by the book and some that just want to make things a bit easer for their system.
Just remebr we used to do it by the book for years then we found out that a base of 3.5 NaOH wasn't enough , so how knows what we may turn up
Paul
« Reply #16 on: January 27, 2013, 08:56:12 PM »
..... and now some are saying, once again, that it is.
« Reply #17 on: January 27, 2013, 09:27:55 PM »
i,m going for flann obrien s policemen in the 3rd policeman. that explains the world from the viewpoint of a policeman in a small irish town, after talking to some people from the pub. i think? been a while since i read it.
« Reply #18 on: January 27, 2013, 09:33:39 PM »
Just remember we used to do it by the book for years then we found out that a base of 3.5 NaOH wasn't enough ,
Paul
 Catch up Paul.......
And then we started 2 stage no titration and found out actually 3.5g NaOH base is enough... so long as your oil is DRY. lol.
« Reply #19 on: January 27, 2013, 09:39:05 PM »
Sorry I'm so behind the times it been a while.
« Reply #20 on: January 27, 2013, 09:47:44 PM »
Paul
Even bone dry oil won't give complete conversion single stage without 5g+ base.  The Acetone paper seems to suggest that complete conversion is possible with much less than 3.5g.
Hypothetically, you should only need a tiny bit of catalyst, because it's a catalyst and not consumed by the process where no water and FFAs are present, so you could get away with 0.1g/l if the process was right!
I'm guessing 5g/l and 3.5g/l all comes down to Glycerol byproduct retarding the catalyst in some way.
« Reply #21 on: January 27, 2013, 10:02:31 PM »
There is no correct way just the best way for individual circumstances. Some want to do it 'right' others just as easily as possible. In the end if we have all the information each can make their choice.
The process has evolved considerably since I started 6 years ago and, hopefully will contine to change.
Dick
