Author Topic: Soaps/Acetone  (Read 80579 times)
Re: Soaps/Acetone
« Reply #60 on: December 29, 2012, 08:17:48 PM »
So does that mean using the Acetone has completed the job in less washes than it would normally take Mark ?
Yes, I normally do 3 or 4 washes.
Re: Soaps/Acetone
« Reply #61 on: December 29, 2012, 09:35:36 PM »
 Wicked, that's a good result for starters.  My batch is made, when I get to wash it I will be adding the Acetone with the first wash.
Re: Soaps/Acetone
« Reply #62 on: December 29, 2012, 09:51:40 PM »
How much are you going to add ?
I used 20ml in 180L of bio.
I hope your results confirm my findings.
Do you do titrated acid washing, if you do I wouldn't add the acetone to the first wash as we have no idea what the outcome will be,
maybe Carrington can enlighten us on this.
« Last Edit: December 29, 2012, 09:54:14 PM by mark »
Re: Soaps/Acetone
« Reply #63 on: December 29, 2012, 09:57:54 PM »
My last one was... but I have demethed this batch as I believe the Methanol interferes with washing too.  Sooo..  I will be talking to Paul first. And using an amount along your lines. Cheers Mark.
Re: Soaps/Acetone
« Reply #64 on: December 30, 2012, 12:44:24 PM »
I've believe that too!  I'm sure that when I've demethed (bit fiddly without a venturi - pulling in air on the suction side of the pump), washing has been easier.
I'd be interested in testing meth % on each wash, but as I've mentioned previously I've a theory that meth ppms or % reduces over successive washes until it reaches a threshold where soaps release at higher volumes.  I could be wrong, but everything that I've seen with years of water washing suggest this.
Re: Soaps/Acetone
« Reply #65 on: December 31, 2012, 09:48:38 AM »
Any results yet Steve ?
Re: Soaps/Acetone
« Reply #66 on: December 31, 2012, 06:44:57 PM »
Hi Mark,
    no sorry I have not had a chance to catch up with Paul yet, I did a 50/50 with bio from the bottom and to be honest it was not that white so I have high hopes once I get to neutralise it and give it a wash.
As this batch will have had a fair settling time I will keep a sample before washing and one after to do some side by side cold testing which may be interesting too.
Re: Soaps/Acetone
« Reply #67 on: December 31, 2012, 10:23:23 PM »
Side by side testing would be great.
Once I some more IPA I'll do the same.
Re: Soaps/Acetone
« Reply #68 on: January 01, 2013, 09:59:38 AM »
What testing are you doing with IPA Mark ?
Re: Soaps/Acetone
« Reply #69 on: January 01, 2013, 12:31:27 PM »
I rather suspect, Steve, that mark has run out of IPA for performing titrated soap tests. A key ingredient and test for for what you're trying to acheive.
Re: Soaps/Acetone
« Reply #70 on: January 01, 2013, 04:03:03 PM »
Ah I understand now, cheers.
Re: Soaps/Acetone
« Reply #71 on: January 08, 2013, 11:36:50 PM »
I've got a batch from a week and a half back that seems to be settling rather slowly, so I've taken a 75ml sample and added 0.5ml Acetone (0.66%)
I'll compare this for soap with the rest of the batch later this week.
I'm also about to make a new batch tomorrow, I was going to take 2x 500ml samples in the same jars, one with and one without acetone to compare settling of those.  What percentage do you think I should try?
Re: Soaps/Acetone
« Reply #72 on: January 09, 2013, 09:09:09 PM »
Tony, I added 20ml to 180L of bio for my washing,
that works out at around 0.1ml per liter,
this could be a starting point for you.
Re: Soaps/Acetone
« Reply #73 on: January 09, 2013, 09:14:57 PM »
That's not much at all.  I'll try 0.1ml in each 500ml sample then.
The one that wasn't settling is showing some faint signs of soap at the bottom today.
Re: Soaps/Acetone
« Reply #74 on: January 11, 2013, 04:20:11 PM »
I have had a demethed KoH  180 litre batch settling in my reactor for the last week or so, once a day I have been dropping the glyc, all nice and dark.
  Yesterday only a drip came out so I put in 200ml of Acetone and mixed for 20 minutes at ambient temp. Today I dropped 350ml of dark glyc ! So it has released more from the Bio. I will see what drops tomorrow and then take a sample for a 50/50 test.
  I may end up not washing this batch and the next batch will get the Acetone after demething and probably once it has cooled a bit.
