Author Topic: Copyright  (Read 8189 times)
Re: Copyright
« Reply #15 on: December 20, 2012, 08:37:49 PM »
Same Julian,  out of the loop here too.
Re: Copyright
« Reply #16 on: December 20, 2012, 08:38:35 PM »
not missing much  :P
Quantity isn't the issue, it's that I've missed anything at all ... feel all left out!
Re: Copyright
« Reply #17 on: December 20, 2012, 08:42:02 PM »
im often out...
infact im not sure when im in either?
or come to that who i am?
 :o
Re: Copyright
« Reply #18 on: December 20, 2012, 08:43:49 PM »
Yet again I must have missed all the fun.  I started reading that thread and lost intrest early on.   I've just re-read it ... what did I miss and what got deleted?
Must try and spend more time on forums.
I think most of it is still intact, except for the bit where i took a swipe at the American. I dunno if he responded or not, so I might have missed it.
Offline McDuff
Re: Copyright
« Reply #19 on: December 20, 2012, 10:48:21 PM »
Its all on his forum
Re: Copyright
« Reply #20 on: December 20, 2012, 11:00:05 PM »
That is freaky.............
Re: Copyright
« Reply #21 on: December 20, 2012, 11:04:36 PM »
I Just found that.  Looks like the VOD's on the black list ... http://beyondbiodiesel.org/forum/index.php?topic=33.0
Re: Copyright
« Reply #22 on: December 20, 2012, 11:25:35 PM »
He's back...................
Re: Copyright
« Reply #23 on: December 21, 2012, 12:01:51 AM »
.....and it seems to have got a bit nasty.
That's dissapointing. With an English degree, 'arse' should have be used not 'ass'.
Offline McDuff
Re: Copyright
« Reply #24 on: December 21, 2012, 12:04:35 AM »
Banned indefinately
Re: Copyright
« Reply #25 on: December 21, 2012, 12:36:29 AM »
Two of the Mods should be 'rather more moderate' in their comms, IMO.
Take that recent 'Merc for sale' post; the Mod is a member of that guy's forum!
Re: Copyright
« Reply #26 on: December 21, 2012, 01:55:31 AM »
Quite. And considering he claims to be an ordained Buddhist Monk, the concept of being a disinterested observer, seems to have escaped him.
Re: Copyright
« Reply #27 on: December 21, 2012, 07:00:12 AM »
McDuff, if it wasn't the blending that did for your injector spray pattern and piston rings, what did cause the problem if you don't mind my asking?
Edit: answered own question:
http://www.vegetableoildiesel.co.uk/forum/viewthread.php?tid=21589#pid244601
Quote
An update - The 2 door's engine was stripped down and there was a heavy carbon build up around the tops of the cylinders probably caused by slow burning oil. The injector inlet hole into the pre-combustion chamber of one of the pistons was blocked by carbon, this in turn appears to have blocked the injector and as the glow plug had less and less cooling from the fuel it burnt through and fell onto the piston where it burnt a hole through it - hence no compression. All the pistons had damaged rings and heavy coking of the grooves directly below the pre-combustion chamber. Rebuild amost complete and hopefully will be running later this week.
But you believe this to be an engine design problem as others have had similar just on Diesel?
« Last Edit: December 21, 2012, 07:06:55 AM by Tony »
Re: Copyright
« Reply #28 on: December 21, 2012, 07:13:43 AM »
i writ a post here and its gone??? has it been deleted? have i been moderated?
if there was a problem in what i wrote i could of explained it wasnt ment at anyone only in general terms as i didnt know, well i do know but couldnt think what the word is, my memory isnt good now, think thats my age not sure or demensher or altszimers,
will check nack later!
« Last Edit: December 21, 2012, 07:26:21 AM by Bob The Builder »
Re: Copyright
« Reply #29 on: December 21, 2012, 07:41:37 AM »
No moderation I'm aware of chap, what was it about?
