Author Topic: Hypocritically off topic, help with things electrical please.  (Read 6818 times)
Re: Hypocritically off topic, help with things electrical please.
« Reply #15 on: December 19, 2012, 08:03:25 PM »
OK, pulled a connection appart on a "white" strip ... referring to the four copper connections where you cut the strips, positive is connected to (surprisingly) the positive wire and the other three are joined with a bridge of solder and connected to the negative wire.
Logically to make the primary colours you'd connect positive to positive and then the negative to either R, G or B as required.
On one of my strips RGB isn't marked, but it appears that the standard colour sequence is + G R B
If it's any help the new uprated RF controller is a vast improvement on the IR controller usually supplied with the strips.
Hope that helps.
« Reply #16 on: December 19, 2012, 08:31:42 PM »
thx got a link or pic of that new rf thing?
« Reply #17 on: December 19, 2012, 08:42:21 PM »
I got it here ... http://www.ebay.co.uk/itm/170778529916?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
It's only really necessary if you want to run more than one strip and have them work in sink (in which case you'll need an uprated transformer too), or if you want the controller hidden away.
Waiting for this to arrive (you can choose the rating to suit the number of strips ... I chose the next size up just to be on the safe side) ... http://www.ebay.co.uk/itm/230845090623?var=530075032447&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2648
It all starts to add up if you want something other than one standard strip!
« Reply #18 on: December 21, 2012, 10:44:27 PM »
This gets worse!
My nice big 30 amp power supply arrived today and the bloody thing is cooled with a fan ... a noisy fan.  No mention of fans in the advert that I remember.  So I can have nice pretty light only when accompanied by an annoying drone.
And the double sided tape on the strips obviously doesn't like Melamine because they are detaching when mounted on a horizontal surface.
« Reply #19 on: December 27, 2012, 10:06:59 AM »
Did you wipe down the melamine with IPA first? That is what I did in the caravan and they have stuck to the underside of cupboards and the like ncely. The caravan vibrates and flexes whilst being towed (certainly compared to a house anyway) and they are still stuck.
« Reply #20 on: December 27, 2012, 10:23:42 AM »
Yes scrupulously.
Played this game recently for a large retailer, trying to get doublesided tape to stick to powder coat.  Ended up having shelving tested at 3M  Bracknell who are recommending the 4th type of tape for the job.
I re-taped the strips with one of their previous recommendations for low energy surfaces and it worked fine.
« Reply #21 on: December 27, 2012, 11:05:39 AM »
If it is over rated can you disconnect the fan or put a resistor in series to slow it down and cut the drone?
« Reply #22 on: December 27, 2012, 11:45:16 AM »
It was well over rated ... I felt it best with cheap items made in the East!
Seller has agreed to swap it for a 20 amp version without a fan which is still slightly over rated for my application, so hopefully all will be good.
« Reply #23 on: December 27, 2012, 04:56:08 PM »
That's good to hear.
