Author Topic: Next batch!  (Read 9123 times)
Re: Next batch!
« Reply #15 on: November 18, 2012, 10:50:32 PM »
I've got your float as well, you forgot about that didn't you.
Is that a wooden/ plastic float or a steel trowel
[/quote]
Been so long I can't remember ... I loose all my tools this way.
Re: Next batch!
« Reply #16 on: November 18, 2012, 10:59:18 PM »
Ahhh, my float ... I remember my float.  It's been so long since I've seen her. We used to have such fun together, but now she's ...
Um, maybe I should just drop it on your doorstep, ring the bell and drive off.
I don't need to see the reunion of a man and his tool, that's the sort of stuff that nightmares are made of.
Re: Next batch!
« Reply #17 on: November 19, 2012, 11:02:50 AM »
just knowing where they are is enough  :)
Re: Next batch!
« Reply #18 on: November 19, 2012, 12:08:40 PM »
No, he'll have them on ebay as soon as he thinks I've forgotten about them.
Re: Next batch!
« Reply #19 on: November 19, 2012, 09:36:16 PM »
Forget Ebay, it's to tracable.
I'll be weighing them in.
Re: Next batch!
« Reply #20 on: November 23, 2012, 10:04:46 PM »
has anyone tried the technique yet?
I did tonight.
I glyc washed 160lt of pretty good oil.
I mixed 3.2lt of ASM and made up to 21lt with methanol and mixed for an hour.
I did a 90/10 and got just 0.6ml drop out.
Dropped the glyc and mixed it all up again.
Got 0.5ml drop out! :(
Mixed up another 0.3lt of ASM an 1.5lt of methanol and got a slightly hazy pass.
I was really hoping that the mix following the glyc drop from stage 1 would send the reaction to completion. Ah well!
Like Julian said earlier in this thread....negative results are worthy of publication and discussion too.
Nige
Re: Next batch!
« Reply #21 on: November 24, 2012, 03:19:59 PM »
I tried it too. I made the first stage with the normal amount of chemicals then, after draining the first stage glycerol I mixed for an hour with no added chemicals. It made no difference at all - the fallout at the end was the same as at the start of the hour.
It took the calculated amount of second stage chemicals to get a clear pass.
Re: Next batch!
« Reply #22 on: November 24, 2012, 05:47:41 PM »
I tried that earlier this year just after I started doing the 2 stage no tit, but to try and push a failed S2 forward.
As said, no dice. Worth a go for the small effort required.
