Author Topic: Continious removal of glyc when processing, using a sedimenter?  (Read 10577 times)
Re: Continious removal of glyc when processing, using a sedimenter?
« Reply #15 on: January 01, 2013, 11:04:28 PM »
Tony, if you start rethinking your setup it'll never get finished.
this is one reason my processor is not yet finished, apart from working outside in a field and it not being a major priority. i have gone the other way and  put all the bells and whistles on, only to take them all off again as the chemistry changed.
 might get a bit more done now the rain has stopped for a while. just got to wait for the water to drain away. still a foot deep in mud at the moment. i now have all the bits including a m67 heater to pre heat the oil which will save on genny time.
« Reply #16 on: January 02, 2013, 01:26:10 AM »
Mate
You said it got a bit grim down there in the winter!
« Reply #17 on: January 02, 2013, 04:46:47 PM »
Mate
don't fancy coming down for a bit of team building camping then?
« Reply #18 on: January 06, 2013, 08:03:36 PM »
I suspect the RangeRover wouldn't pull the caravan in and out of your field at the moment  :)
At least the delay means a respite for the poor cat
« Reply #19 on: January 06, 2013, 09:21:35 PM »
poor cat has decided its far too wet to go outside at the moment. if she jumps out of the coach door she sinks  in a foot of mud. had to get a litter tray. suppose that counts as  "continual removal of sediment" just to stay vaguely on topic.
« Reply #20 on: January 06, 2013, 11:07:26 PM »
A decent set of off road tyres, locked front and rear diffs at tick over or slightly higher and it should even pull his coach out!
« Reply #21 on: January 06, 2013, 11:09:02 PM »
Mate
Mate
I'm a fair weather camper... well caravaner I'm ashamed to say!  Mind you the kids were pretty impressed with your place - they'd be up for it :-)
« Reply #22 on: January 07, 2013, 12:20:58 AM »
[/quote]
[/quote]
given the somewhat delicate nature of some areas of the coach i think there might not be a lot of coach making it out onto the road.
