Author Topic: bt speeds or internet speeds  (Read 10280 times)
Re: bt speeds or internet speeds
« Reply #15 on: November 05, 2012, 01:50:27 PM »
6 Mbps is the download speed. Your download is 29! Almost 5 times as fast. Your upload is 3.5 10times faster than mine!
« Reply #16 on: November 05, 2012, 01:51:56 PM »
i see just this app here put it at 3.5mb/s not just 30
« Reply #17 on: November 05, 2012, 01:54:49 PM »
ok so you can get 6 megabytes on a good day = 60 gigabytes
my house is 10 gig all the time or 1 mbs
rachaels house here now with infinity is 35 gigabytes or 3.5 mbs
Ah, 3.5MB/s not 3.5mbps.
3.5MB/s is actually 28mbps.  No idea where you got 35 gigabytes from :)
1MB/s is 8mbps.
« Reply #18 on: November 05, 2012, 01:56:36 PM »
1MB/s is 8mbps.
yup confusing meself there
doesnt a 1000gig make 1 mb ?
« Reply #19 on: November 05, 2012, 01:57:59 PM »
Download is what counts that is why upload is usually slower. Check with the speed test at different times of day to get an overall picture but what you have there is flying.
Got to go to work now so will look back later. Take care both
Dick
« Reply #20 on: November 05, 2012, 02:03:00 PM »
Other way around, 1000 megabytes makes 1 gigabyte.
Speeds are measured in one of two ways, megabytes per second typically, say, 3.5MB/sec or megabits per second (mbps).
There are 8 bits in 1 byte, so if you have 3.5 megabytes per second you have 3.5 * 8 = 28 megabits per second.
« Reply #21 on: November 05, 2012, 02:04:12 PM »
If that speed test is done via wifi - I'd suggest that probably the wifi part of the link is the slowest. You might like to try again when it's plugged in.
Anyhow - that's blisteringly fast :D
« Reply #22 on: November 05, 2012, 02:05:49 PM »
right im following now
« Reply #23 on: November 05, 2012, 02:06:59 PM »
yes it was..
heres one for you then lol the wifi stick i just bought is 150 mbps, whats that then :)
« Reply #24 on: November 05, 2012, 02:10:28 PM »
« Reply #25 on: November 05, 2012, 02:11:01 PM »
this is on a cable about the same
« Reply #27 on: November 05, 2012, 02:13:10 PM »
Ta, couldnt get the graphic up.
« Reply #28 on: November 05, 2012, 02:14:36 PM »
think its the icon binoculars then drop link in the tags
Offline petep900
« Reply #29 on: November 05, 2012, 08:25:33 PM »
..but i am using my mobile....  :(
Get cable on friday so should get around 30 download...... ;D ;D ;D ;D
