Author Topic: New plant in the making - building work nearly done  (Read 18901 times)
Re: New plant in the making - building work nearly done
« Reply #45 on: October 26, 2012, 07:23:39 PM »
julian if you have a rgb building supplies anywhere near you their 25 mm celotex is £14.28 a sheet. jewsons is £13.85. jewsons is another make but basically the same stuff PIR. it is worth haggling. i brought 10 sheets to do the yurt roof. i just told them i could get it online for 13.75 and  asked how close can you get to that price? after a lot of typing they came back with those prices.
 http://www.rgbltd.co.uk/
« Reply #46 on: October 26, 2012, 08:08:52 PM »
there's a jewsons local to me.  i went in there as i wanted an endfeed fitting.  it was about £4.90 ex, when screwfix was under £2 inc, for the same item!
i just assumed evreything at jewsons was a bit of a con
« Reply #47 on: October 26, 2012, 09:07:00 PM »
That is quite annoying - I remember Bob telling me that when I saw him last - but I promptly forgot until he mentioned it here. There is a Jewson about 5 miles from me - which is much better than the Wickes which is 18 miles away in Plymouth (but I had to go there anyway to get some tools from Aldi).
Still - it is done now.
« Reply #48 on: October 26, 2012, 10:16:28 PM »
The disadvantage of hot cupboards in sheds is you'll get the police kicking your door in after they've been over the place with a helicopter and IR camera, because they think you'll be growing something you shouldn't ;)
Our reactors / settling drums give off enough heat to raise suspicions as it is,
I've often wondered when the "knock on the door" will happen.
