Author Topic: Calling Keith if you're about!  (Read 10777 times)
Re: Calling Keith if you're about!
« Reply #15 on: December 10, 2010, 11:54:20 PM »
Ahem ... One of the things you must remember when doing this is to save the page once you've edited it ... I'll just do that again!
« Reply #16 on: December 11, 2010, 12:00:39 AM »
That's better, done AND saved!
« Reply #17 on: December 11, 2010, 12:02:12 AM »
Ha just spent 5 mins thinking id cocked up again :D
Thanks for that-the help i mean
Do you think that will do?
« Last Edit: December 11, 2010, 12:08:15 AM by KH »
« Reply #18 on: December 11, 2010, 12:19:57 AM »
It's nearly there.
Perhaps loose the top line and amalgamate it with the first paragraph.
Follow that with a  "TOC" (Table of contents)
Put    __TOC__   After the first paragraph.
Add headings, so the TOC can list them, so ...
Change TAM 105 to    ==TAM 105 specifications==
Change Components to ==Components==
Change Performance to    ==Performance==
In the interests of being unbiased and non commercial perhaps we should loose the Machine Mart contact details.  (any one can search TAM 105 and arrive at the MM website quit easily)
Put    Biodiesel    after the colon in the Category at the bottom and delete text starting "Add the ...."
« Reply #19 on: December 11, 2010, 12:34:49 AM »
I think i will save a come back tomorrow, ive deleted most of the MM details but ive left the email address/tel no as parts are not so easily found and that was the idea behind this- to allow people to source parts,do you think that will be ok?
« Reply #20 on: December 11, 2010, 12:44:11 AM »
Still needed to move the headings to the left-hand margin in order for them to work.  I just did it so you can see the difference.
Tricky with regards to the spares contact. How about making it more generic and saying something like:
"Spares for this pump are readily available from the main stockists and distributors whose detail can be found on the internet"
Again they only have to bang TAM 105 into Google and they will come up with machine mart.
« Reply #21 on: December 11, 2010, 10:18:30 AM »
check out bullets on your first paragraph keith
see if you likey, if not sorry i butted in, just looks neater and less spread out for quick reference, also goes with rest of the site to keep it unilateral...
http://www.biopowered.co.uk/wiki/Tam_105
« Reply #22 on: December 11, 2010, 08:26:13 PM »
Anything is fine by me, i think its finished now unless anyone knows better :D
« Reply #23 on: December 11, 2010, 08:39:16 PM »
ok im going in for a play hehehe
« Reply #24 on: December 11, 2010, 08:46:10 PM »
finished........  8)
« Reply #25 on: December 11, 2010, 08:48:26 PM »
Looking good.  Now, where's the next page!
« Reply #26 on: December 11, 2010, 09:15:17 PM »
trying to think of one...
