Author Topic: In processor titrated water wash method  (Read 133884 times)
Offline RichardP
« Reply #180 on: December 27, 2012, 10:08:29 PM »
Not actually done the titration bit of this method, though I have been using vinegar in the first wash for some time. I need to get some stronger acid, hydrochloric is out for me as I have 316 stainless fittings, so would be looking at sulphuric or phosphoric, both being a similar price volume wise. What's the thoughts on phosphoric? Which would be best for use with stainless?
Also looking at the indicator for the test. Bromthymol blue looks to be best due to the colour change point, next being phenol red.   Any ideas where these can be acquired?
« Reply #181 on: December 27, 2012, 10:13:47 PM »
Get a soap test kit off Nige, that has Bromthymol blue in it.
Or ask your chemical supplier.
Offline RichardP
« Reply #182 on: December 27, 2012, 10:27:20 PM »
I thought the stuff in the soap kit was bromophenol blue? Where's Nige??
« Reply #183 on: December 27, 2012, 10:29:52 PM »
I'm here!
Richard..I have sulphuric acid here. FOC. It's brand new sealed battery acid that gets thrown away at work. For the sake of being close enough then bromophenol blue will work just fine. If you want Bromothymol blue I can get that for just under £10 for 500ml.
Mark..the indicator in the soap kits is Bromophenol Blue not Bromothymol Blue
If anybody needs any additional Bromophenol Blue for soap testing I can supply it at about £3.00 plus delivery for 100ml
Offline RichardP
« Reply #184 on: December 27, 2012, 10:40:25 PM »
Nige, can you get me some bromothymol please? I can pop over when I'm back 4th or 5th, I'll have a bit of the sulphuric to to try out. Thanks.
« Reply #185 on: December 27, 2012, 10:42:55 PM »
Doh, you can tell I'm not a chemist can't you.
« Reply #186 on: December 27, 2012, 10:49:31 PM »
It's an easy mistake to make Mark especially when the pH changes are so close as well the chemical name!
There was a point recently when I thought they were the same animal.
« Reply #187 on: December 27, 2012, 10:57:27 PM »
I've just emailed the company and am now awaiting a response regarding collection.
« Reply #188 on: December 28, 2012, 10:58:03 AM »
Nige,
I've got quite a few bottles of Bromophenol Blue, if you some anything urgently!
« Reply #189 on: December 28, 2012, 11:22:52 AM »
Phosphoric will be fine - it is just rather expensive. I still have a about 20 litres of 85% phosphoric acid which I will start using once I run out of 96% sulphuric (I have a about 1 litre of that left to use up first).
Phosphoric is certainly less hazardous although still not pleasant and will generate phosphate salts (ie Sodium Phosphate or Potassium Phosphate) in your wash water as opposed to Sulphate ones so would probably be good to put on your plants (especially Potassium Phosphate which is a valuable fertiliser).
« Reply #190 on: December 28, 2012, 01:40:58 PM »
I too have a ready supply of Bromophenol Blue Nathan....however, my post to Richard was about Bromothymol Blue.
« Reply #191 on: December 28, 2012, 02:00:40 PM »
Realise that you have a supply, implied by the soap test kits and earlier posts on this thread.  I was saying that I have a number of bottles of this that I won't be using.
« Reply #192 on: December 28, 2012, 02:28:55 PM »
I'm confused...help me here. What have you got that you wont be using Bromophenol or Bromothymol. Confusion because you quoted a reply to Richardp about Bromothymol!!
« Reply #193 on: December 28, 2012, 08:46:15 PM »
Nathan stop reading on your phone and use the lappy..... Richard wants Bromothymol not Bromophenol which you say you have... even though Richard did misspell in his OP about it, lol.
« Reply #194 on: December 28, 2012, 10:09:52 PM »
 :P
