Welcome,
Guest
. Please
login
or
register
March 26, 2026, 03:40:39 PM
Wiki
Forum
Tools
Titration calculator
No-titration calculator
Pump pressure vs head
Oil heating calculator
Venturi and eductor throat
Drum cone calculator
Oil price trends
Recent Posts
Help
Search
Login
Register
Biodiesel
Biodiesel equipment
Lowara ceam 70/5-V
« previous
next »
Print
Pages: [
1
Author
Topic: Lowara ceam 70/5-V (Read 3552 times)
nigelb
Wiki Editor
Grand Gunge Master
Lowara ceam 70/5-V
on:
September 29, 2012, 03:50:47 PM »
On my last batch I had a blockage in my pump after the methoxide had been venturied in during stage 1 of a two stage no tit. I seperated the pump from the pipework to find some peeled paint stuck in the inlet port of the pump. I removed what I could and reassembled. The batch went as planned following that. Now I've removed the pump again to make sure it's all out but I can see traces of it still. If I undo the cap screws from the front body of the pump am I likely to gain access to the main impellor? Will I damage any seals by doing so? If so where can I get spares?
The peeled paint has come from the inside of the lid. It's now been cleaned so will not pose any problems in the future. I cant say that for the main body of the reactor which also has this coating but does not show any signs of peeling.
Nige
Logged
Glycer-rides
Wiki Editor
Valve head
Re: Lowara ceam 70/5-V
Reply #1 on:
September 29, 2012, 04:01:23 PM »
This page might provide you with answers, Nige?
Sir Pumpalot (Tony) will know.
http://www.e-pumps.co.uk/lowara-cea-705-va-centrifugal-pump-94-p.asp
Logged
Brewing bio. And still not breaking cars!
Julian
Administrator
Oil baron
Reply #2 on:
September 29, 2012, 04:23:49 PM »
Can't help much as I've not got any experience with Lowara pumps but the tech sheet on the page above gives some good sections.
Nige, can you take photos during the strip down and write a few notes then we can add it to the pump section of the wiki.
Logged
Used Cooking Oil Collection website ...
http://www.surreyusedcookingoilcollection.palmergroup.co.uk
nigelb
Wiki Editor
Grand Gunge Master
Reply #3 on:
September 29, 2012, 05:28:37 PM »
If I end up stipping it down I'll do as requested. I'm waiting for a responce from Sir Pumpalot before deciding what to do. Thanks for the link Andy.
The pump is off the reactor again and I've given it a reverse flush with a hose pipe on full jet with the drain plugs out. Not totally convinced that it's all out.
Nige
Logged
Julian
Administrator
Oil baron
Reply #4 on:
September 29, 2012, 06:12:14 PM »
Thanks, Nige.
The Sir Pumpalot title's probably going to stick ... very creative, Andy, we like it!
Logged
Tony
Administrator
Oil baron
Fo' shizzle, biodizzle
Reply #5 on:
September 29, 2012, 10:22:14 PM »
You've got to be able to take these pumps apart for cleaning, as fibrous stuff will jam in the closed impeller over time. Disassembling it shouldn't be a problem, aside from the big o-ring that seals the pump outer case to the pump motor body, which can expand with veg/bio use. I have a couple of common sizes spare which might fit your pump but worst case is buying some spares here:
http://www.polymax.co.uk/o-rings/rubber-viton-oring/
They do sell Teflon encapsulated o-rings too but I got quoted about a tenner a piece which is a bit steep... so all my spares are Viton.
Logged
Print
Pages: [
1
« previous
next »
Biodiesel
Biodiesel equipment
Lowara ceam 70/5-V
