Author Topic: Cartridge heater/Melting stick  (Read 17427 times)
Re: Cartridge heater/Melting stick
« Reply #30 on: August 08, 2012, 09:13:35 PM »
Got another element today,600w 14mm,big spanner time again
One for Julian - someone said it should be called a s**t stick!
« Reply #31 on: August 10, 2012, 10:25:10 PM »
Mk 2
CLIP
« Reply #32 on: August 10, 2012, 10:57:12 PM »
Tosser tube.
« Reply #33 on: August 10, 2012, 11:03:37 PM »
Tosser tube.
At least tosser towers is fully built  ;D
« Reply #34 on: August 11, 2012, 01:04:46 PM »
You sound just like my wife!
« Reply #35 on: August 14, 2012, 09:28:12 AM »
We tried these last year as an inline heater by soldering one into a 22mm T fitting and keeping the flow running throught the other two connections.
It worked well until the heater melted the solder and the flow of oil pushed it out of the fitting!!  It would probably work fine using compression fittings though.
Is there a reason that you're not buying the 15mm ones that wouldn't need a big spanner?
http://www.ebay.co.uk/itm/Stainless-Steel-Tube-Cartridge-Heater-Heating-Element-220V-600W-15mm-x-180mm-/290750228465?pt=LH_DefaultDomain_3&hash=item43b21067f1
« Last Edit: August 14, 2012, 09:31:33 AM by max.print »
« Reply #36 on: August 14, 2012, 08:27:06 PM »
Oooh nice find... might have to pick up one of them :)
« Reply #37 on: August 14, 2012, 08:34:53 PM »
The reason for using the slightly smaller version is a bit complicated and to do with optics,
RM might have a go at using the smaller one in the block heater i made or make another version of it
« Reply #38 on: September 08, 2012, 08:35:10 PM »
Anyone done anything with there cartridge heaters?
« Reply #39 on: September 12, 2012, 06:32:01 AM »
all the good stuff seems in hong kong  ::)
« Reply #40 on: October 11, 2012, 09:48:26 PM »
Well actually mine are being subverted from the intended bio lark to go in my friend's beer brewing kit as an inline heater for the mash stage.
I'm sure I'll get to enjoy the results :)
