Author Topic: Checking your NaOH titration solution.  (Read 4241 times)
Offline countrypaul
Re: Checking your NaOH titration solution.
« Reply #15 on: July 13, 2022, 01:22:44 PM »
A pipette is used to dispense a fixed amount of solution such as 10ml, 25ml etc. I have never seen a proper one with a scale on it, they are also calibrated at a fixed temperature usually 20C (though I believe that can vary hotter countires may use 25C for example).
When titrating you should use a burette which is calibrated to measure in, for example, 0.1ml (for a 25ml version).
Using a burette does make it much much easier and can allow you to run multiple tritrations one after another with ease.
