Author Topic: 20 litre drum wash tower  (Read 14483 times)
Re: 20 litre drum wash tower
« Reply #30 on: August 20, 2012, 01:11:30 PM »
Well initially it's the weight more than anything. I want the whole lot supported on boards over my open top barrel so that if it does leak then the liquid only falls into the barrel it's above.  The bigger it gets the more precarious I feel about balancing it :) Doubly so when the bottom dishes out under pressure.
I'm glad I'm not the only one that's not so keen on screw tops.  I stopped using them when one fell over in the car and the top popped off.  Oil everywhere.  The clamp tops however, I've dropped those from height full of oil and they just bounce.  And I know from storing Meth in them on sunny days that they can take some pressure.
So perhaps a 30l clamp top is the way forward.  Even if I don't have enough medium then 15l at the bottom is fine by me - just got to find one!
« Reply #31 on: August 20, 2012, 08:13:21 PM »
I took eight clamp top 20,s to the BBB,they were for JulianF to collect,im not sure what happened to them
« Reply #32 on: September 03, 2012, 02:22:50 PM »
Another interesting possibility occurred to me after chatting with some friends into making their homebrew.
How about a beer pressure vessel?  Some come with 2" caps but some are 4" and that may be enough to scoop drywash medium out of (admittedly not as easy as upending a 20l bucket but even so...). It would definitely take the pressure at least.
