Author Topic: 60l clamp top drum seals  (Read 6021 times)
« on: November 26, 2018, 11:00:37 AM »
My decade old 60l clamp tops have slowly been losing their lids seals, either because they tear apart eventually or get lost when they fall out on-site.
I've experiments with silicon and various types of other seal (UPVC window seals, car door D seals) but finally found a suitable replacement - 10mm neoprene cord - this stuff:
https://www.ebay.co.uk/itm/rubber-cord-o-ring-cord-neoprene-black-sponge-10mm-diameter-x-1M/221723146189
1m is enough for one drum.  The first time fitting the lid requires a lot of compression to get it to close, but once that's done and it sits for a while the neoprene deforms into what looks exactly like the old seals it came with.  So far it's done a great job at keeping WVO where it should be and no slopping out of the tops of drums in transit.
Re: 60l clamp top drum seals
« Reply #1 on: November 29, 2018, 08:43:33 AM »
Good work there Tony. A useful item to put in the tips and wrinkles.
I've only ever used the silicon sealant method.
« Reply #2 on: November 29, 2018, 09:44:35 AM »
Would that we could!
« Reply #3 on: November 30, 2018, 02:38:08 PM »
Yes I should try and do something about that.
« Reply #4 on: October 02, 2019, 08:45:18 AM »
I've used several lengths of neoprene foam and it's been great for gaskets.  But at £3 a hit (1m => 1 drum) I was wondering about cheaper alternatives.  I've found this stuff:
https://www.ebay.co.uk/itm/323809499217
Everbuild JOINT BACKER ROD Sealant | Polyethylene Foam | Gap Filling | 10mmx10m for £3.95
That's enough for 10 drums, at a fraction of the price.  So I've ordered some, see how it compares to the neoprene.
« Last Edit: October 04, 2019, 08:43:05 AM by Keef »
« Reply #6 on: October 04, 2019, 01:32:56 PM »
In theory polyethylene should be better than neoprene, as neoprene is better for permanent seals and polyethylene for seals that will keep being broken.  It's definitely oil resistant.  So the question is more about the mechanical properties (does it squish into the right shape OK when the clamp is put on?)
I've got several drums with 10mm neoprene in service and they are absolutely fine.  Just have to see how the new stuff goes.
