Author Topic: My PID has broken, and ive forgotten all i ever knew about them.... :(  (Read 3227 times)
I have always used the n2006p units in the past with an SSR relay.
All i can find now are the rex-c100 units, but i have in mind that these do not have a (i think?) DC feed to drive the SSR.
I think they have relays or AC?  I found half an old post on VOD about it also.
What id like is just a drop in replacement, ie a n2006p, but it seems if i get a REX unit, ill need to add a DC psu somwhere also, if im to retain the SSR?
I used to know this stuff, but its gone now  : (
Thank you.
Re: My PID has broken, and ive forgotten all i ever knew about them.... :(
« Reply #1 on: February 23, 2018, 11:11:13 AM »
They must have changed them, as it seems there are kits about now, with SSR outputs, eg -
https://www.ebay.co.uk/itm/401483254019
which i have just purchased.
« Reply #2 on: February 23, 2018, 03:46:46 PM »
Manual  here ... https://www.mpja.com/download/rex-c100.pdf
Had a very quick read and I think some versions have a 0/12v DC output dictated by the full model number which I cant see in the advert.
Not the end of the world to add a power supply, just use a plug in jobbie from a printer or the like ... most Womble minded people have at least half a dozen kicking around in the "too useful to throw away box".
Good luck with it.
« Reply #3 on: February 23, 2018, 05:35:52 PM »
The ebay item is sold with an SSR, so you would hope...
My bio setup is such that any extra electronics will increase the failure rate.  I mean, thats always the case, but most electronics get an easier life...
