Author Topic: Yet another pumps thread  (Read 233272 times)
Re: Yet another pumps thread
« Reply #585 on: November 17, 2015, 11:07:40 AM »
Ged, do you know if it has a plastic or metal impeller? I'm just wondering how they would stand up to pumping bio.
I've been using a similar pump on my bio dispensing rig for several years ... very infrequent use but the business end sits in bio all the time.
I think the vanes are a white plastic possibly Nylon or similar.
Why, are you looking for one, Chug?
« Reply #586 on: November 17, 2015, 11:17:03 AM »
If I was still pump hunting, I'd be after this bad boy:
http://www.ebay.co.uk/itm/Calpeda-Vertical-Multistage-Pump-MXSUM-405-0110005527-/161889258099
133lpm multistage, tasty.
Ooo ... shiny!
It's difficult to see from the photos, but is that a four core cable ... possibly 3ph?
However, if it's the same Surbiton, that's quite close to me ... happy to pick it up if anyone is interested.
« Reply #587 on: November 17, 2015, 01:51:26 PM »
On the label it states 220/240 volts and requires a capacitor.
That's probably what the forth wire is for.
« Reply #588 on: November 17, 2015, 02:29:01 PM »
dunno, but i can strip it and see on saturday mate.
« Reply #589 on: November 17, 2015, 03:16:25 PM »
Ah, well spotted, that bit of the label was covered by the bar with thumbnails of the other photos when I looked ... I must pay more attention!
« Reply #590 on: November 17, 2015, 04:28:24 PM »
I was just wondering Julian, I've got two spare pumps for my processor, well three if I count the clarke fuel transfer pump
« Reply #591 on: November 27, 2015, 06:50:10 PM »
Ooo ... shiny!
OK there's only so much pump porn I can take before I blow some cash, he relisted it at £80 BIN, and I offered him £70, so it's on the way to me now.  I'm sure Jim's 80lpm eductor and venturi that he made for me really won't mind a bit of extra oompf behind them, I've got plenty of 1 1/4" steel pipe and a 1 1/4" die kit so bring it on (when I get the time!)
« Reply #593 on: April 04, 2016, 10:29:55 AM »
5 stage stainless steel Calpeda, Swaffham, Norfolk way - £30
http://www.ebay.co.uk/itm/Calpeda-Pump-With-Idromat-Regulator-/162021419246
(Could get £20+ back on the regulator, done that before).
« Reply #594 on: April 08, 2016, 02:27:24 PM »
In case anyone is (like me) eyeing this Mono stator and wondering if it will fit their ML:
http://www.ebay.co.uk/itm/291732390145
...don't bother - I asked Mono and it's not compatible.
« Reply #595 on: April 08, 2016, 04:38:29 PM »
That surprises me ... I always thought the "G" range was just a bare shaft version of the "MM" or "ML" with only the "MS" being a different design.  Did they say why it wouldn't fit?
« Reply #596 on: April 09, 2016, 11:26:52 PM »
No... perhaps it doesn't fit for profiteering reasons?
« Reply #597 on: April 10, 2016, 12:22:39 AM »
I think that's a distinct possibility.
If you want to give it a shot, I've got an a couple of MMs or MLs (can't remember which they are) in the garage that I can easily take apart and measure the critical dimensions of stator for you.
« Reply #598 on: April 10, 2016, 11:16:36 AM »
I've looked at a lot of datasheets for the G range pumps, and the exploded diagrams show very clearly exactly the same head arrangement, even the rotor has the same number of "bumps" so I think it's a fair bet that it'll fit.  I've got a new rotor so I can twiddle that down the stator and see if it all looks OK.
My only concern is that perhaps the stator (and rotor) are slightly different diameters for some reason.  But why go to the effort of tooling for the manufacture of just slightly different parts?  I can't imagine that the rotors are cheap to manufacture.
So, I've bought it.  Worst case is sell it on again.
My ML works OK, it's just that it's had many hours used as a water pump before I got it, and it's pumped tens of thousands of liters of manky veg over the years that I've owned it.  The poor thing is a bit overdue some TLC.
« Last Edit: April 10, 2016, 11:21:17 AM by Tony »
« Reply #599 on: April 10, 2016, 11:44:01 AM »
Good move ... I'd be very interested to see if it fits ... I'd go 95% sure on it fitting.
I don't even think there's a difference between an MM and ML ... I believe one just has a faster (possibly more powerful) motor.
Manky, slippy, slimy oil is probably the kindest thing you can run through a Mono!
