Author Topic: Yet another pumps thread  (Read 229435 times)
Re: Yet another pumps thread
« Reply #45 on: August 02, 2012, 09:59:42 PM »
Id give a fiver for the quick releases
« Reply #46 on: August 03, 2012, 08:43:18 AM »
Pump may not be a lot of use as it's 110v, but if the bidding doesn't go to high, this may be worth a punt for the enclosure alone!
http://www.ebay.co.uk/itm/280931606116?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
The flojet pump enclosed is a 4.5lpm diaphragm pump running at 24v.  So I guess there is a 110V to 24V PSU in there too - if you're lucky it might be switchable for 230V but wouldn't count on it.  So if you wanted to use the pump for circulating wash water or something, you might have to pick up a 24v PSU for it.  Nice pump though, can self prime and run dry :)
« Reply #47 on: August 03, 2012, 08:45:45 AM »
Mono pump ...
As I already have three, I thought I'd flag this up to stop myself bidding ...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=221081529201&ssPageName=ADME:B:SS:GB:1123
Could be useful as spares or replace/repair the motor.
Mono pump guy got back to me about the courier so I'll be bidding on this one for spares for my current pump (can't live without my mono!)
« Reply #48 on: August 12, 2012, 12:29:56 PM »
Didn't win the mono...
Anyway - anyone know anything about these compact petrol pumps?
http://www.ebay.co.uk/itm/Homelite-Petrol-Waterbug-Pump-Ideal-for-Ponds-Pools-Floods-Boats-Etc-/251126614548
« Reply #49 on: August 14, 2012, 09:10:37 AM »
This thread has some useful links about the pump
http://www.houseofhomelite.proboards.com/index.cgi?board=tech&action=display&thread=2052
Sounds like a right screamer of a pump that runs permanently flat out!
« Reply #50 on: August 16, 2012, 11:47:38 AM »
Just won this - might be good for drywash or general low-energy circulation (I'm still convinced that agitation helps soap settling).
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=221097029477
« Last Edit: August 16, 2012, 01:16:19 PM by tony »
« Reply #51 on: August 16, 2012, 07:30:04 PM »
Nice one,body looks similar to a Stuart Turner
« Reply #52 on: August 17, 2012, 08:33:27 AM »
This is the two stage version of the Calpeda pumps I use:
http://www.ebay.co.uk/itm/290759391155
All stainless.  Hopefully with non-EPDM wear rings but no guarantee. Seller says the company area code on the label is five digit so not as old as the one I had with EPDM rings (which aren't mentioned any datasheet I've seen so maybe just an old model?)
I would've bid for it myself for spares for mine if it was a three stager.
« Last Edit: August 17, 2012, 11:39:23 PM by tony »
« Reply #53 on: September 03, 2012, 01:18:13 PM »
Psssst Keith... want spares for your pump?
http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=300773588565
IIRC that's very similar to the one you got (but 110V).
« Reply #54 on: September 04, 2012, 10:53:29 PM »
Maybe Keith doesn't want it?  With a 110V transformer it'd make a cracking self priming mix pump - would be tempted myself but I've seen the bore of pipework needed for them and don't fancy that!
« Reply #55 on: September 05, 2012, 06:47:03 AM »
I would love to build another reactor with extra large bore and massive flow rates, that looks like it would be an ideal candidate at 149 Lpm.
« Reply #56 on: September 05, 2012, 08:30:57 AM »
It's "liquid ring" so self-priming in that respect though I'm sure Keith can fill us in on how well that works with veg oil.  He's got a 240V one and I've seen it in action on his old rig - it was impressive!
« Reply #58 on: September 05, 2012, 07:29:30 PM »
It looks slightly different from mine,my switch is on the back and its 240 lpm,i think mine is a AL model,it copes with veg and bio fine,feel free to buy it,should be a good pump
« Reply #59 on: September 11, 2012, 01:41:09 PM »
Mono up Chelmsford way currently at a fiver:
http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=140847709936
Needs suitable motor to drive.
